Old 02-22-2007, 04:41 PM   #171
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Re: Update
Originally Posted by Elliot Naess
Update. . .Read the owner's manual!
But if I pull it out from under the table leg, I'll spill my coffee!
Griff is offline   Reply With Quote
Old 02-24-2007, 10:48 PM   #172
Elliot Naess's Avatar
Engine: 5,9 Cummins
It seems like I’m always jumping back and forth between various areas of the
bus, never quite finishing anything. Oh, wait... it doesn’t SEEM that way -- that IS
what I’m doing.
I’ll claim that it is all a wondrous plan to finish all aspects of the project at the
same time.
The first part of the front cap skin went on today. Millicent’s “forehead”. This skin
goes behind the top part (the raised roof), and in front of the bottom part (the
windshield header), like shingles on a roof. That way, maybe the rain won’t get in
quite so easily.
This sheet of aluminum is a big remnant of .032 (or thereabouts) that I have had
laying around for a couple of years. So it’s easier to bend than the other material
I used, which is around .050 and seems to be a harder alloy or temper. Sure,
today’s piece is entirely flat, but tomorrow I have to do the corners.
Here is the inside of the top left corner of the new panel. I drilled holes 1” apart,
then transferred those to the roof and drilled those, and here I’m lining it up with a
few rivets backwards in the holes for alignment, plus tape to hold it there.
Similar at the bottom (just above windshield). Holes in the bus first here, between
all the old rivets (which are ground flat).
Then transfer to the skin and drill that. All told, there are something like 268 holes
drilled, plus most have to be “chased” for perfect alignment to get the rivets in.
These are 3/16 rivets. By fluke, they happen to be steel rivets, and Boy Howdy,
they clamp a LOT better than the aluminum ¼” ones. I’ll probably switch to steel
for the rest of the bus.
That was probably the easy part. The corners should be more interesting.
You may wonder about such a large surface being so flat. Oh, yeah buddy, it “oil
cans”. But it won’t after I install a bulkhead a couple of inches behind it, and
fill that cavity with expanding foam.
Elliot
Old 02-25-2007, 08:40 PM   #173
Good gawd, that beast is gonna be fugly. I'll bet my house is more aerodynamic.
Did you ever think of putting some sort of slope in that forehead? My forehead's got plenty of slope and I'm one handsome fella.
pete c is offline   Reply With Quote
Old 02-26-2007, 10:08 PM   #174
Engine: 5,9 Cummins
So... In between the rain showers, we complete that proud forehead.
The zigzag is on account of the door mechanism, but I’m more worried about the curve. (One of the structural
cross braces is missing in this picture -- it was in the way of the (future) interior paneling, so I’m repositioning
it.)
After measuring and cutting, the panel... does not quite want to go in there. Luckily, the panel is not in charge...
...Mr. Hammer is in charge. This trick of clamping two lengths of angle to the sheet works very well -- all the
force of the hammer is still delivered, but over a MUCH larger area.
Now, here is a bigger scrap of angle (just one), and it is used to hold the new sheet tightly in place at the rear
edge as I start riveting. I expected it to be difficult to get the upper edge of the sheet tightly into the corner, but I
wedged a well-used 2x4 between the new piece and the opposite wall and voila! I did not pre-drill anything on
the corners. I just clamped, wedged and otherwise forced the sheet into place and drilled as I went.
The last step was to rivet the corners to the middle sheet. To keep this joint nice and smooth, I installed a piece
of flat stock behind the seam, then riveted.
It still doesn’t look like a Prevost, but it’s good enough for the girls I run with.
Now, if I had a dollar for every time I climbed my step ladder today, I could buy a Prevost!
The other corner is also done, but it’s raining too hard to take pictures of anything.
Final verdict -- alright, maybe not final, but... -- Getting this all smooth and gorgeous and even from side to side
and... would probably require assembling everything, then disassembling to deburr holes, remove chips,
correct poorly aligned holes and so on and so forth before final assembly. Which is what they get paid to do up
there at Prevost.
Millicent now has a proud tall forehead with some odd vertical wrinkles-- maybe I should rename her Worf.
Elliot
Old 02-27-2007, 07:54 AM   #175
it.)
there at Prevost.
Lookin' good elliot. You are one fabricatin' fool!!! I'd say that your fabricating skills are nearly as impressive as your bravery/foolishness for undertaking such a project.
As for worf uhhh millicent's forhead character lines, how about using 1/4 plywood behind it? I would think that if you placed a piece of plywood there you could use some sort of adhesive and roll the sheet flat against it. You might want to drill a bunch of whole in the plywood to allow air bubles to escape.
Old 02-27-2007, 10:34 AM   #176
Engine: 5,9 Cummins
As with much of this project, the flaws are the sort of thing that (most likely) nobody will
notice. I know they are there, but the overall "foolishness" will overwhelm most
bystanders. I think/hope. That's why I happily drill holes and slap bolts anywhere --
--only I will know.
It works like this: When I lived in a crowded subdivision in Sacramento, I always put on a bit
of a show for the kids on Halloween. Not the worm-infested-eye-socket sort of stuff, but
technical, interactive things. (The standard feature was a G scale model train that delivered
the candy to the kids -- after they earned it by hitting a target with a bean bag.) One year, I
had two gadgets out front; a nine-foot diameter flying saucer in a recreation of the 1947
Roswell Incident, and The Two Ton Tricycle. I had people WALK RIGHT PAST THE
“CRASHED” FLYING SAUCER AND NOT NOTICE IT because they were looking at the
more visually attractive Tricycle.
(The front wheel is unfinished in this shot from a different occasion.)
Same with my first bus. It was white with red rub rails. In a week’s time I had two people
refer to it as the RED bus.
That’s why I don’t sweat the little appearance stuff. It’s the overall impression that matters.
And there will be something behind this forehead to support it. Stay tuned to this station --
we are going to play with volatile chemicals, and I don’t mean cappuccino!
Elliot
Old 02-27-2007, 07:14 PM   #177
Griff's Avatar
Year: 1982
Chassis: IH S1723
As with much of this project, the flaws are the sort of thing that (most likely) nobody will notice. . .only I will know.
Yeah, but now you've shown US, so WE know. . .I guess yer just gonna have to kill us. . .we know too much!
And there will be something behind this forehead to support it. . .
. . .wish I had something behind MY forehead to support it. . .I jarred it severely and my two remaining brain cells are now in an asynchronous orbit. . .I keep going around in lop-sided circles. . .
Old 02-27-2007, 08:23 PM   #178
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Have been following along, and it looks great. Sheeting an open space on a bus is very difficult to get looking perfect, and you've done a great job.
My wife even commented on what a great job you're doing. I say "even" because her esthetic standards are higher than mine.
-Richard
captainkf is offline   Reply With Quote
Old 02-27-2007, 08:42 PM   #179
Engine: 5,9 Cummins
Thanks, Cap'n, but I wish you had told me earlier that it was difficult!
Didn't get much done in the rain today, but got a good start on the panel above the door.
This gives us our first view of the new proportions up front.
Elliot
Old 02-27-2007, 08:53 PM   #180
the_experience03's Avatar
That thing needs some Rogaine...the forehead is getting mighty shiny.
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 23 06-10-2015 01:15 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 02:07 AM
Roof raise: TMI !! thommassey Everything Else | General Skoolie Discussions 15 12-09-2011 01:58 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 05:51 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
