Old 06-12-2007, 02:00 PM   #231
trentet's Avatar
Engine: INternational DTA 360
Re: Millicent; Crazy Man Tries To Raise Roof 2 Ft On 40 Ft BB
yay!! the continuing adventures of the big headed bus continue, I await your next progress photos with baited breath. speaking of breath, (weak transition, I know) I tried some of that Indica ale, pretty tasty, if a little hoppily bold, I would suggest you try a Lagunita's Czech style pilsner, not as hoppy, barely, but oh so refreshing. I would like to point out at this time that I am in no way advocating consumption of alcohol in ecsess or as a way of life, I am a beerist, I am content to enjoy, on occasion, one or two of my favorite beverage merely for the pleasure of taste and not for it's inebriative effects. Having spent a good part of my childhood in an Aleutian native village and having seen firsthand the destructive potential of substance abuse within my own family, I know the seriousness of that condition for many folks. Through some fluke of genetics and I suppose my own lack of serious emotional issues I can continue to enjoy one of my great passions, the consumption and enjoyment of finely brewed ales and pilsners. This has been a preemptive public service announcement. Anywho hope it all comes through smooth as a cats belly.
"Beer speaks people mumble" (lagunitas beer bottle)
trentet is offline   Reply With Quote
Old 06-17-2007, 12:17 AM   #232
Elliot Naess's Avatar
Engine: 5,9 Cummins
A manager, that’s what I need. Somebody to drag me out of bed and keep me working on one project until it is complete. Waaaaayyyy too many projects going on here now -- all at once, and I’m only one man. Let it be a lesson. (Hey, I make a very good bad example, don’t I!)
But here is a shot from the troublesome Window Installation Day, a week ago:
RV windows are installed by a “sandwich” method, where the window itself and its inner molding are the bread, and the wall of the vehicle is the meat. The stoopid thing is, that the “meat” has to be an exact thickness, to match the window. Excess thickness can be filled in with some sort of spacer, I suppose -- and I will be doing that, with cardboard or spray foam or something. But the screws have to be exactly the correct length, which is fine on the known wall thickness of a factory built RV -- and not so fine on the jerry rigged walls of Millicent. For good measure, my salvage windows are all different thickness. Oh well -- I’m allowed to whine once a year, right?
So I used some plywood I had laying around and made three big sandwiches. I suppose it will be fine, but I’m not proud of it. So there’s another lesson -- design your walls to be an even thickness, and make sure you have plenty of exactly the right length screws on hand -- if you are going to use RV windows.
Next, I have worked on the tailgate. It needs to be counter weighed so it can be opened and closed by hand. My first idea was to simply run a garage door spring in the little gap along the sides of the gate, but this proved inadequate. There isn’t room for a thick enough spring, and if I attach the spring far enough out on the gate, the spring will be over-stretched. So I’m running a cable from the gate over a pulley to the inside of the bus, where the cable attaches to the spring with a moving pulley and then to the ceiling. That way, there is all kinds of room for a big spring, or even two springs doubled up, and the spring will stretch only half the length of the gate movement.
There. Finally some progress, even if minor!
Elliot
Old 06-25-2007, 06:10 PM   #233
Engine: 5,9 Cummins
And it works!
With both springs installed, the gate can be lifted with one hand. In fact, the gate stays in place in any position. It took only three tries to get the leverage right, so today I'm not whining about anything -- I'm bragging about my eyeball engineering talent!
Last week's shots showed a skinny cable and some make-shift fastening. Here is the 1/4 (quarter) inch cable with thimble, and clamps with nylock nuts, finally installed. The eye-bolt will get a nylock nut also.
Next time, I'll see if I can really show off that gate.
Elliot
Old 07-01-2007, 10:29 PM   #234
Engine: 5,9 Cummins
All right, no "showing off" yet, but there it is, holding position by itself:
Now it just needs finish work -- and latches.
Bicycle repair stand slips into square tube that holds tailgate hinges:
That the sort of thing you have in mind, VeloHauler?
Elliot
Old 08-08-2007, 05:24 PM   #235
Re: The Millicent Chronicles; two foot roof raise, big tailgate
You haven't posted recently, so I dunno if you've been prepping for Burning man or just working (my real life sometimes gets in the way too!) but sweet ramp! You have found the way of KISS, grasshopper! DO you plan to re-attach the end cap to make it look pretty again? (I kinda like the redneck look without it!)
fwchiro is offline   Reply With Quote
Old 08-08-2007, 06:34 PM   #236
Engine: 5,9 Cummins
Oooo... there's an idea -- a clamshell end cap that completely hides the tailgate until... POP!... out rolls "Henry Ford Goes Surfing"! I like your devious way of thinking!
Alas, that ain't gonna happen. I cut the tail end off in bits and pieces. And I'm even happy with the way it looks. Eventually I'll paint it, and then it should look fine.
Been busy otherwise, yes. Working for a living, yes -- that too. But Millicent WILL go to Burning Man! Leaving here Friday 24, picking up friends in Sacramento then arriving BRC mid-morning Saturday with Early Entry passes to set up camp.
Odds are Millicent will not have running water at BM. Everything takes lots of time.
Elliot
Old 08-08-2007, 10:04 PM   #237
hehe....I'm in the medical field and when you wrote BM, I immediately thought "bowel movement"...ahh, the mind wanders occasionally... I'm thinking that a huge smiley face with a 'have a nice day' would look great on your back door! Whatever you put back there probably shouldn't include anything about bodily functions though
Old 08-08-2007, 10:14 PM   #238
Engine: 5,9 Cummins
Right, but a giant... uh... transom of some kind might work.
I do indeed need to be more careful about abbreviations. "BM" is routine shorthand for Burning Man around many of my friends, but of course not to everyone. Same with any specialty. A medical neighbor of mine rattled off "UTI" the other day, and I had to think a long time before I caught up. (Urinary Tract Infection)
All right, enough medical talk. Let's paint a gigantic Horse's Ass on that ramp!
Elliot
Old 08-09-2007, 11:44 AM   #239
the_experience03's Avatar
My mom is a nurse so BM was a common utterance growing up. I immediately though bowel movement as well.
At the same time....when you said UTI I thought Universal Technical Institute....the place that cranks out high dollar mechanics.
Old 08-09-2007, 12:52 PM   #240
Engine: 5,9 Cummins
Clearly, we need to do something drastic to get this thread uh... regular again.
Lets try this:
That should do it.
And now:
Thats Old #35 (white with red stripe) -- Millicents predecessor -- at Burning Man last year. Just two weeks and a day before I leave....
Elliot
Roof Raise - Building My Own Flat Roof iverSUN Conversion General Discussions 26 02-18-2019 10:41 AM
Roof Raise ~ Cutting Roof ABOVE Windows ?? chev49 Conversion General Discussions 3 12-04-2012 02:07 AM
Roof raise: TMI !! thommassey Everything Else | General Skoolie Discussions 15 12-09-2011 01:58 AM
Roof raise Rod Conversion General Discussions 1 03-08-2008 05:51 PM
Roof Raise ~ Cutting Roof ABOVE Windows ?? pixemoss Skoolie Conversion Projects 6 12-31-1969 07:00 PM
