09-21-2016, 06:34 PM
#781
for all the Hate it gets im really impressed by my International 5.9 (DT-360).. it moves my bus along nicely.. it will run it at 68 if I really wanted it to...
displacement is part of it but how the engine is set up is a bigger part of what it can do.
09-21-2016, 08:10 PM
#782
Who's hating on the DT360?
09-21-2016, 08:23 PM
#783
all I ever hear is "its too small get a DT466".. even though people get 5.9 cummins all the time and have no issues... they have about the same HP / TQ ratings as a DT-360 (esp a later DT-360)...
while we all know the DT-466 and the 7.3 / T444E are excellent powerplants.. I see some DT-360 busses going at really low prices on the auction sites...
point being that for someone looking for a budget bus the DT-360 isnt going to limit them to 40 MPH on the freeway... Granted its not gonna scream up the hills like a 466 (though the redline on the DT-360 is safe at 2700-2900)...
im in 100% agreement that one of the best drivetrains out there is a DT-466 coupled with a 643 or 2000 series allison.. but those busses also often demand premium prices ...
just like buying busses with road A/C all so it can be yanked out and thrown in the garbage by many converters.. A/C busses command a premium.. dont buy it unless you plan to keep it and use it...
09-22-2016, 05:00 AM
#784
Right. But having been on this site pretty regularly, I can't say I've ever heard any ill spoken of the smallest of the DT's. I certainly think its better than a 5.9 Cummins, too, fwiw.
09-22-2016, 12:15 PM
#785
Engine: 5,9 Cummins
Annnd... this is beginning to resemble "thread drift".
Yes, of course the tiny 5.9 is pathetically under-sized/powered for 38,000 pounds going over the Sierra Nevadas and such climbs.
On the other hand, it gets us there, and the downside is only that it takes a couple extra hours. Well... and creates a traffic hazard.
I keep toying with the idea of a larger engine. Of course, I would have to find it at a "highway robbery" price.
And a big stick-shift transmission.
And the REALLY cool thing to do would be to install such an engine under the floor, like the old Crowns. Cummins does make "horizontal" versions of some engines, such as the L10 and M11. Many of these were sold to England. But maybe a normal vertical engine can be converted with a few parts that can be bought over the counter?
09-22-2016, 02:05 PM
#786
Coachwork: Crown / Pusher
Sent you a pm.
09-22-2016, 03:14 PM
#787
Engine: 5,9 Cummins
I do not see it in my Inbox.
09-22-2016, 08:27 PM
#788
Just tried again.
09-23-2016, 12:11 AM
#789
Engine: 5,9 Cummins
PM received and reply sent.
09-23-2016, 10:24 AM
#790
Engine: 5,9 Cummins
Stu, I sent a second reply. I may have found the man in question.
09-23-2016, 10:40 AM
#791
Engine: 5,9 Cummins
Why am I not able to post photos today?
09-23-2016, 06:29 PM
#792
Year: 1994
LOL its like disney but four times the price.
now that's funny
09-23-2016, 07:02 PM
#793
Coachwork: Crown by Carpenter
Rated Cap: 16
Right on, Elliott! I went to BRC in 1999 and 2009 - wish I go go back more often, but at least I have Flipside(Austin regional burn) and Myscheivia (North TX regional burn) to be able to keep my burnin' on! A great way for newcomers is to check out a regional burn to "test the waters". We are always welcoming to new people and you can enjoy it on a smaller, less-expensive scale...
11-21-2016, 07:16 PM
#794
Engine: 5,9 Cummins
A couple months ago, I mentioned that the power steering is failing.
So far I have replaced the filter in the reservoir, and also the supply hose from reservoir to pump, which could be subject to collapsing inside from low pressure. (You may have noticed that bottom radiator hoses have a coil spring inside. That's to keep it open if there's a bit of a vacuum in there.) But both were fine.
Then I remembered... in September... I inadvertently lowered the tilt steering column to lower than usual, and the steering became worse. I drove a dozen miles at no more than 40 mph because it was downright difficult to follow the road.
When I returned the column to its usual mid-position, it acted like before -- power steering failing at idle but OK at speed.
And then I forgot about that episode.
Now I'm thinking.... I must take her for a spin with the column all the way up against the dash -- with the U-joint at the bottom of the column straight.
What if it's the U-joint binding up? It's under a rubber bellow, so my next step is to loosen that and take a peak under it.
11-21-2016, 09:08 PM
#795
a U-joint when bent.. in fact the further bent.. has points in its turn where the velocity is higher and the the velocity is lower..
if you bend that U-joint closer to the 90 degree mark.. the steering wheel will be harder to turn at the point of High velocity ..
its hard to explain in words.. but open up your socket set.. pull out your U-joint and put an extension on each end of it.. hold it in 2 hands.. imagine the left hand is the steering shaft and the right hand is the steering wheel side of the shaft.. if you hold the U-joint straight and pin the right hand you will notice the shaft in your left hand spins at a constant speed and at the same speed as your right hand..
now move the right hand so that the U-joint is bent like a wheel tilted down and turn it... you will notice that the right hand gets harder and easier to turn and that the shaft in the left hand speeds up and slows down as you turn...
if it were a steering wheel then whe the left hand is trying to spin faster, it will take more torque input at the wheel to turn the shaft.. meanign the wheel is harder to turn.. continue to turn the wheel and you'll notice that the wheel gets easier to turn for part of the turn... then hard again...
thats how a U-joint acts...
sorry for my poor explanation, I do not have a picture or diagram to show you.
11-21-2016, 09:20 PM
#796
Engine: 5,9 Cummins
You are of course right. And I know this from decades ago, in my automobile technician training. Also, I once built a street rod where I would feel the steering ratio change as I turned the wheel -- too much angle. So I reworked it to better alignment. Never take shortcuts, yes.
And this is why the U-joints of a driveshaft -- any shaft with two u-joints -- must be phased correctly, and have the same angle at both ends.
Yup.
But if this U-joint is binding up, it must be failing -- bone dry, worn, whatnot. Bet I'll know something as soon as I lift that rubber boot.
11-21-2016, 10:46 PM
#797
Coachwork: Blue-Bird
Engine: 5.9
New first post
I was wondering if with the roof raise would there be room to add a bunk over the drivers area. Possibly that hinged at the front and could be angled up out of way when not needed. I am hoping to relocate my entrance door.
11-21-2016, 10:57 PM
#798
FWIW...when I was building my steering system (from scratch), my research indicated that the absolute difference in angle on any steering segment joined by U-joints should never exceed 30 degrees. That was the number I consistently found among everything from rat dodders to F1 chassis builders. And they all agreed...less was better. Might check those angles. Maybe someone else has some more data.
11-21-2016, 11:21 PM
#799
Engine: 5,9 Cummins
Oh absolutely. 30 degrees is an awful bleepin' lot for any U-joint.
Yeah, I built two cars from scratch -- meaning I designed and fabricated the frame and where everything went on it -- and learned all kinds of useful stuff in the process. Great fun.
Millicent does in fact have a bunk over the driver's seat. Though it is lengthwise. It is hinged to the left wall and folds up to clear the driver's head. It's kind'a my Captain's bunk.
I have had it at three different heights, and nothing is satisfactory. This is one of the factors in my decision to raise the roof further.
With the ceiling high enough, I could put this bunk sideways as you suggest -- and also other bunks sideways, safely above people's heads.
And... in that case, I could make a bunk or two movable -- slide fore and aft on simple tracks -- to make single and double beds as needed. This is desirable with our varied assortment of travel companions, but not realistic now.
All that said, I am fond of the lengthwise Captain's bunk, and will probably keep it that way. But as always, I enjoy experimenting, so anything is possible.
11-21-2016, 11:26 PM
#800
Engine: 5.9
With a little more height you could put in a loft
