06-15-2017, 12:57 PM
#881
The idiot light is part of the charging circuit. If it's burned out, no charge happens. If it comes on when starting then goes out momentarily after starting, the alternator should charge. Could be a bad rectifier or diodes etc but they don't last forever either.
Good luck, let the pro's decipher it.
06-15-2017, 02:07 PM
#882
Engine: 5,9 Cummins
Depends on the type of regulator in the alternator. Some units are "One Wire" -- all they need is the one "Battery" connection.
And I have now spent hours online, and am still not sure which type mine is.
(With the older type GM alternator -- the one that has been popular with hot rodders for decades -- you convert it to one wire by installing a "self exiting" regulator, also know as "marine" regulator, because this is common in boats. Quick and cheap, and I've done several.)
Anyroad.... This unit failed the bench test, and I ordered one just like it. We leave on a trip in eight days, and there simply is no time to round up the needed parts for converting to the 22SI.
By the way... here is useful information for everyone:
I looked up the price on NAPA's website -- $115 (reman.). At the store, he quoted me $140. So I mentioned the online price. And he said "Aha!" and poked around a bit in his computer, and sold it to me for the online price.
It may help that I'm a regular customer, and always a cordial one.
06-23-2017, 03:51 PM
#883
Generator
In your VERY interesting chronology is the anything about installing a generator? I have to mount a 12500KW gen set under a long nose Thomas bus. Any ideas. Please PM me.
Bruce
06-23-2017, 07:35 PM
#884
12,500 in a Long Nose? Heck, just pull the engine and drop in the genny. It probably has bigger displacement anyway.
06-23-2017, 09:21 PM
#885
HA HA!! A friend of mine want to make his bus a transport vehicle for rescue dogs. Trying to figure out/get ideas for genny mounting.
Sorry- did not mean to hijack the thread-I'M out.
Bruce
06-23-2017, 11:05 PM
#886
Most of the 12.5's I have seen are huge. All I can suggest is to start with some measurements to see if it will fit below the floor and still leave reasonable ground clearance. If not, then either cutting through the floor or putting it on a trailer will get it done.
PS..I have seen both options in action.
06-23-2017, 11:18 PM
#887
One guy put a 10k inside his bus with a sound muffling box built around it. He pulled a trailer and ran the generator in the bus for the AC in the trailer.
Robin
Nobody's Business
06-30-2017, 02:38 AM
#888
Engine: 5,9 Cummins
Sorry, the only generator I use is a portable one, which I set up outside.
That does not mean I would not like to have one onboard. And a bigger one than my Honda EU-3000. But... not yet.
On the way back from Klamath Falls a couple days ago, a shrill sound began slipping out of the engine compartment, from the area of the (new) alternator.
Good bet it's the idler pulley, which felt rough when I turned it (when the belt was off). Reckon it is next up for replacement, and also the tensioner to be safe; and the water pump, which is surely due.
Snapshot from Klamath Falls last weekend. "Obstacles", my foot. We f-l-e-w thru that gravel-mud-pit-obstacle.
06-30-2017, 08:12 AM
#889
You are coming for 2018 right? RIGHT???
Baltimore Kinetic Sculpture Race
06-30-2017, 09:57 AM
#890
Engine: 5,9 Cummins
Alas, too far. $3,000 just in fuel.
But that's my "how to" article at the bottom of the page. Very old and needs updating, but I "have a presence" in Baltimore.
07-05-2017, 05:32 PM
#891
In that case, I'm just going to leave this here and a reminder that you've got some catching up to do.
https://www.facebook.com/amsoil.inc/...9595824052401/
07-25-2017, 04:27 PM
#892
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
I saw you driving on the interstate out of Sacramento the other day! I told my passenger, hey I know that bus!!!
My build thread:https://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
07-25-2017, 04:49 PM
#893
Engine: 5,9 Cummins
Yup. Drove to Davis late Friday. Left Davis early Saturday for Oakland, where we participated in the annual PedalFest, held in Jack London Square. Back to Davis late Saturday. Home Sunday mid-morning.
Prior to that trip, I had replaced the fan-belt tensioner pulley, because a noise had appeared on the previous trip, and the pulley felt... not rough, but dry. It spun TOO freely.
Alas, that was not the culprit.
Reckon I will replace the water pump next. That's a good preventive move anyway, as it will fail sooner or later. Better to replace it before it fails.
Next would be the fan and fan-clutch bearings.
I sure hope it is not the new alternator making that noise! LOL
09-17-2017, 12:29 AM
#894
Engine: 5,9 Cummins
Millicent made... not just "a" trip to Burning Man this year, but TWO TRIPS!
And this with that chirping noise up front, much of the way.
I brought a new water pump with me, but the noise did not change, and no water leaked out.
Let's see.... She grossed, with the trailer, 33,400 pounds going up there originally.
Then 35,680 coming back the first time.
Coming back the second time, it was only 29,980. This was with nothing but junk bicycles -- 181 of them. They had to be removed, so I volunteered. Hopefully, I can harvest enough parts to make it worth the trip. But I would do it just to help clean up the Playa.
Other than the chirping noise, she never missed a beat.
Except.... The gray-water tank is shifting back and forth a bit -- maybe half an inch -- and the vent pipe has pulled loose. This is easily remedied, but I ought to have checked the bolts once in a while. They have nylock nuts, but 60,000+ miles of travel can shake things loose a bit anyway.
That sort of thing is worth keeping in mind for all of us.
09-18-2017, 08:09 AM
#895
I hate those things because they work too well. But then the only time I'm removing them is after whatever has rusted as well.
Even after 60k miles they ought not be loose. If for no other reason than the first 30k gave it time to rust and grime.
09-18-2017, 11:42 AM
#896
Engine: 5,9 Cummins
I should have pointed out that the bolts and nylock nuts did not loosen. The plastic tank flattened a tiny bit.
09-18-2017, 12:03 PM
#897
Ah ok, that makes sense. Still hate the nylon. Don't know that they are any worse than Loctite tho.
10-21-2017, 11:41 PM
#898
Engine: 5,9 Cummins
Pictured below is a $650,000 tow truck. And I just made a payment on it.
Actually, Good Sam Road Service paid $866 and I paid $484.
Good thing I was only 70 miles from home, and not on my way to Burning Man or other vital event.
Millicent's engine is pumping oil into the radiator faster than I can pour it in. Close to a gallon per mile.
Perhaps it is "only" the head gasket, but....
So, for now, I have started keeping an eye out for a bus or truck with suitable engine (and maybe stick shift, while I'm at it). Mechanical Cummins 5.9. But if I get a deal on a larger engine, I may be interested. Must be cheap, though.
Most likely, this failure was triggered by the engine overheating severely a few weeks ago. And that was almost certainly caused by the thermostat not having an air bleed hole -- or it is clogged.
After changing the water pump, I failed to fill the system properly. I ran the engine a bit, and let it sit overnight, but there was still an air pocket in there -- about seven quart's worth.
Normally, I would have warmed it up fully, and gotten all the air out, including from the heaters. But it wasn't a normal day, and Peter took off with it as it was. After two or three miles, alarms went off. So he turned around and drove her back. When he pulled up, I could hear it boiling all the way from the house.
Well, Stuff happens. But Millicent will be laid up for a while.
10-22-2017, 09:23 AM
#899
OUCH! Sorry to hear that old gal was having hot flashes. Hope the recovery goes well.
10-22-2017, 10:21 AM
#900
yeooow!!
hopefully a gasket!!.. thoiugh ive never had a head gasket pump oil into the coolant..
is there oil pressure going into the head on this engine?
