Old 09-23-2016, 01:04 PM   #381
Ya...2-300 RPM can make quite a difference in MPG.
Old 09-23-2016, 01:43 PM   #382
Chassis: International S3800
im sure my MPG numbers arent entirely fair as I did lower the speed and thus the wind resistance.. so my numbers may be a little more dramatic than would be achieived by simply dropping the RPM..
I suppose a more fair test would be running the bus in 'D3' and reaching its max speed.. then run the bus at the same speed in D4 and measure the difference... thus removing wind resistance from the equation..
Old 09-26-2016, 10:19 AM   #383
Jman6631's Avatar
First, not terribly exciting I know but after a fire truck slipped its parking brake at the shop and smashed out my rear door upper window, dented the center and nearly smashed out the lower window I had to install this treated plywood in order to seal her back up again after pounding out the dent. Then I installed a hidden shackle lock for security.
The good news is that since my design calls for skinning over the entire rear anyway and adding a truck tailgate for access to the garage it really doesn't impact me at all. The shop was really apologetic so I declined the offer to repair the door and told them to just forgive the $325 diagnostic fee instead, to which the readily agreed.
Otherwise I decided to postpone the roof raise until the spring. With the divorce pending there is just too much chaos right now which will only worsen as the untangling gets underway.
Instead I will continue to learn the systems, do the engine and chassis maintenance, continue collecting build-out materials and work on the design, especially the electrical where I'm weakest.
Sorry to disappoint you doods who really wanted to see another roof raise happening but what can I say, life does happen sometimes!
Jman6631 is offline   Reply With Quote
Old 09-26-2016, 10:21 AM   #384
Jman6631's Avatar
Market for windows?
One question I have right now is whether or not there is a market for the stock windows I'll be removing. Does anybody buy these things?
Old 09-28-2016, 10:30 AM   #385
Jman6631's Avatar
Quick update on the roof raise that I am now postponing until the Spring. I finished the farm jack raising jigs ala Millicent (THANKS again dood!) that I thought you might find interesting.
This is the top-most fitting that will attach to the ribs. My welds are getting better. Note the crisp edge penetration and flatter dimes on the beads. They're a little crooked I know, more than usual, I think because these are two pieces of 2" tube steel joined at the rounded edges. I put in a small filler bead first and then came back over it with these two wider beads.
The four complete assemblies:
Top-most fitting attached to the vertical lifting 2" tube steel:
Here is the top of the assembled jig (might be kind of hard to make out with everything in the background, sorry). I did it a little differently than Millicent. I used 2"x1/4" angle to connect it to the top of the jack (vs the two pieces of tube steel that he used), using the same bolt and hole that came on the jack when I bought them.
The one concern I have is how good the top connection at the ribs will be. As you can see I drilled out the top flange of the top fitting twice and plan to use a two sheet metal screws on each side to connect it to the ribs, for a total of four at each of the four locations. Will that be strong enough?
I studied Millicent's closely and just can't quite tell exactly how he made this top connection at the rib. I could weld it and screw it but since I am doing a two level raise (with the rear ~6"-12" lower than the front) I will do it in two stages, meaning I will have to reuse each jack and rig so I don't want to attach it in such a way on the first raise that I'll ruin it when taking it off for the second raise.
Thoughts?
Old 09-28-2016, 12:01 PM   #386
Should be fine. Much more elaborate than when I raised my 40' BB. Remember to stabilize everything above the cut line before cutting. Bolting or tacking something like 1" square tube from side to side will prevent the roof from torquing out of shape. It has a fair amount of stress built in and can often be really difficult to re-align if allowed to move when cut.
Old 09-28-2016, 12:08 PM   #387
Jman6631's Avatar
Right and thanks, I will do that and will also put in some ratchet strapping from corner to corner to keep her really square...
Old 10-25-2016, 10:50 AM   #388
Jman6631's Avatar
Hey guys,
I'm having another non-start issue. When hitting the key to start her there is a voltage drop and so far that's all I know. Yesterday I noticed the top right warning light was on, but no others. I tried starting it again and no dice. I had my daughter stand outside and watch it and when I pressed and held down the warning light switch it would turn off. When I released it the light would slowly come back on and then stay lit. I disconnected the positive cable to the crank batteries and left it for now.
Do you think it's just a matter of the switch going bad? Since I won't need these lights in the future can I just unplug them at the switch and leave them until I gut all of the unnecessary wiring later?
This is the inside and outside of the switch:
Old 10-30-2016, 05:00 PM   #389
Year: 1994
Originally Posted by JA Savage View Post
Ya we all leave out first steps. I found elbows with 1 barbed end and a threaded end at a local hardware store, it may have been ace or another chain I don't remember exactly, but they are out there. I can't help you with getting them out of the way into to the cabinet because I am not sure yet whether I will put a chair or something else to cover it up, so it is still poking out a bit. If I do not cover it with something else then I think there is enough slack to push it under the cabinet and seal it off if I wanted to. I hope this helps.
I know this is late to the forum here but if you just slide under the bus and take the hose coming down from the front bus heater core and cut it to length you can just put it on the out put fitting for the rear heater and its completely disconnected with no extra hoses to ever fail. the coolant will drain in to a five gallon bucket and its the two clamps and cut the one hose shorter. just look under it and follow the hoses you 'll see the flow route. but its the one coming down from the front bus heater core. I'll try and post some pictures of mine its very simple.
Geo Jeff is offline   Reply With Quote
Old 02-24-2017, 06:22 PM   #390
Jman6631's Avatar
Hey Doods,
Been away for a bit and just got back to my non-starting issue.
A couple of months ago I had a large voltage drop (down to 11v) and preventing me from starting. I replaced the batteries, which were old and low and in need of replacing, and no-go.
I turned to the starter, jumped it and found it suspect so I replaced it. Now after replacing it she still won't start.
The voltage doesn't drop nearly as low (stays at 13v) but it won't turn over. I'm not sure what to test next. ANY input is appreciated.
Thanks in advance!
