Old 09-12-2011, 09:25 AM   #21
Diesel Dan's Avatar
Engine: DT466/AT545
Re: THE ORIENT EXPRESS
I started out using acetone and steel wool, but ended up just using an orbital air sander with 100 grit paper to get the gunk off, then came back with 220 grit to blend edges. The sandpaper does fill up with gunk, so I had to change disks a lot; and I ended up going down to bare metal in most areas so had to primer right away, but overall I found it was less work than using chemicals. It was totally worth the cost in sanding disks!
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 09-12-2011, 10:49 AM   #22
bus-bro's Avatar
Engine: 3208 na boat anchor
I've used alcohol on the goo with some success. It worked better than acetone, but I still had to rub and scrub.
Old 09-12-2011, 11:43 AM   #23
bus-bro's Avatar
If your paint is basically good I wouldn't remove it. It's the best paint job your bus will ever have.
Old 09-17-2011, 12:53 PM   #24
browncrown's Avatar
Rated Cap: 79 at Birth
You've been busy! Progress looks good
BC
Old 09-19-2011, 08:19 AM   #25
Diesel Dan's Avatar
Engine: DT466/AT545
Looking good! So are those drawers on slides? What's your plan for keeping the drawers in place while you are driving?
Gallery:
Conversion Thread:
Old 09-19-2011, 10:09 AM   #26
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
just wait and you will see how good there are.when you are going down the road and make a trun,they well always come open,so you need to make an inter locking way to keeping them close...there are no flat road in the USA..trust me i have build three bus's ..
keith is offline   Reply With Quote
Old 09-23-2011, 10:18 AM   #27
pipopak's Avatar
I think that if you paint ALL the exposed surfaces in a particle cabinet (like Ikea) BEFORE assembly (all faces and edges) with a good quality wood sealer; and touch up all mating surfaces (where 2 or more pieces intersect) after assembly you should not have issues with humidity.
pipopak is offline   Reply With Quote
Old 09-24-2011, 10:08 AM   #28
lornaschinske's Avatar
Rated Cap: 89
You will need to find a way to keep the door and drawers shut while traveling. ANYTHING that opens, will.
Fulltime since 2006
Old 09-24-2011, 07:41 PM   #29
Rated Cap: 89
Just an idea....
Push button Latches No knobs needed as they are the knobs when unlocked. Easy to see if any cabinet drawer or door is unlocked.
More Push Button Latches lower priced ones.
Fulltime since 2006
Old 09-25-2011, 12:04 PM   #30
MikeyBskunk's Avatar
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Hey spence i got to ask what did the lamminate flooring cost ya?? iv been looking at some diffrent patterns and really just cant gather the strength to buy some
Mike
MikeyBskunk is offline   Reply With Quote
The Belltown Express BelltownBikes Skoolie Conversion Projects 18 05-13-2013 06:17 PM
Suspension, Struts, Springs - Chevy Express 2002 chev49 Short-Bus Conversion Projects 2 06-13-2012 11:25 AM
And so the "Redneck Express" is born...... eggman Skoolie Conversion Projects 20 04-16-2007 12:42 AM
The BLOSSOM EXPRESS - let's paaaaaarty! jpf411 Skoolie Conversion Projects 10 09-28-2006 07:40 AM
