01-20-2016, 06:00 PM
Engine: Navistar t444
Rated Cap: 71 miserable kids
The Ritz Slackjaw
This is the beginning of my project. Codename - The Ritz Slackjaw. It will be made into a utilitarian camper with room for at least 6 people. It will have no bathroom or bedroom. Open floorplan with beds, counters, and a stove. I bought this bus from Midwest Transit in Swansea, IL. 2001 International with an Amtran body. T444 with a 5 speed and air brakes. 136,722 miles on it when I picked it up from the dealership. How much??? I think I got a smokin deal. I got them down from $2,600 to $2,250. I have yet to find a lightbulb that is burned out.
My pappy said son you're gonna make people fuss if you don't stop drivin' that hot rod bus.
01-20-2016, 06:22 PM
It won't let me upload pics.
01-20-2016, 06:38 PM
... so it never happened!
01-20-2016, 06:39 PM
See the Album "The Ritz Slackjaw" for pictures.
01-21-2016, 12:55 AM
Year: 1978
Chassis: Lifeguard
Engine: 366 Chevy
That place knows me well. They're just up the road from me. When I buy new parts, I start there first.
11-24-2016, 01:15 PM
11-24-2016, 01:21 PM
11-24-2016, 01:23 PM
After the seats were gone.
After seat removal, i wanted to protect the metal from rusting anymore so i painstakingly wire wheeled the entire floor. This took hours but I feel was well worth it.
11-24-2016, 01:36 PM
Painting the floor
Rustoleum paint that bonds to the metal. Actually leaves a decent finish.
11-24-2016, 01:41 PM
Patching the floor
On each side of the fender well, the floor was rotted thru. Not a huge area but enough that I wanted to put more metal down so the finished floor would not sag in these areas. I painted over the welds with the same paint as on the floor.
11-24-2016, 01:55 PM
Engine: Navistar 7.6L
I like how you eliminated the rusted out joint between the floor and the wheel well.
11-24-2016, 02:03 PM
Insulating/framing the inside
I decided to take the metal off the inside after a bit of water showed up on the floor after a rain storm. I didn't want to chance mold in the yellow bat insulation from the factory. I took out most of the screws normally and ground off the ones that were stuck. Turns out, it's a 1.5 inch pocket behind there...perfect fit for the 1.5 inch hard insulation (mold resistant) that i was going to use anyhow.
As you can see, I painted all the windows black, except the four emergency windows that swing out. I figured I don't need that many windows on the inside, especially these since they are about as energy inefficient as it gets. From the outside, it looks like a full tint and is a clean look. I was gonna blank out the windows with sheet metal, but this was so much work and material that just the thought was daunting.
I screwed 2x2's directly to the ribs of the bus, pre-drilling holes and using #10x2" sheet metal screws. I ran one piece of blocking between each upright. The 1.5" hard insulation is just 'friction fitted' between the framing. The finished wall will hold it in just fine.
11-24-2016, 02:06 PM
Thank you. Just some sheet metal (maybe 3/16" thick) from some old commercial printers waiting for scrap. I bent it with a 2x4 on the side of a work bench. Nothing too technical but well worth the time. I will be spraying it with undercoating spray before the bus goes anywhere.
11-24-2016, 02:07 PM
