Old 07-10-2014, 08:40 AM   #11
Chassis: B3800 Short bus
Re: The Rocketship
Originally Posted by rocket_kitten
my only fuse box. i feel it should be bigger? or maybe another one?
Yep, I'm pretty sure there is only that one fuse box. There will also likely be 2 fuses coming off of the fat cable down by the batteries and the couple fuses you see scattered throughout the switch panel. All those little silver boxes in the switch panel are breakers, which take the place of fuses. They will self-reset themselves when thrown, which is sort of cool, but, depending on what they power, can be annoying. I had one breaker powering my defrost and heater fans and they would periodically turn off, then back on when they were both on high. I initially thought it was a wiring problem, but it turns out they were throwing the breaker, then the breaker would eventually reset, then get thrown again, etc... Separating the fans to be on separate breakers did the job.
Old 07-10-2014, 10:32 PM   #12
big_bertha's Avatar
Chassis: TC/2000
Engine: Cummins 6CT8.3
Rated Cap: 76
Re: The Rocketship
I dig your windshield. And your scraper. Good luck and welcome!
YouTube | Facebook
big_bertha is offline   Reply With Quote
Old 07-11-2014, 05:09 AM   #13
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Re: The Rocketship
anyone travel with cats? we have two, ZombieCat and Disco.
Some good info here and here, as well as what Lorna suggested
Captain Obvious on deviantArt
Old 07-11-2014, 12:29 PM   #14
Re: The Rocketship
thanks! we love our windshield too. mainly because there are 2 pieces, cheaper to replace. and it totally helps to have friends with tools!
rocket
The Rocketship
viewtopic.php?f=9&t=467631
rocket_kitten is offline   Reply With Quote
Old 07-11-2014, 12:35 PM   #15
Re: The Rocketship
those are great! thanks!
rocket
The Rocketship
Old 07-11-2014, 06:04 PM   #16
browncrown's Avatar
Rated Cap: 79 at Birth
Re: The Rocketship
Welcome!!! and it looks like you're off to a great start
BC
Old 07-27-2014, 10:34 AM   #17
Re: The Rocketship
Hi, not a lot of progress, but..
remember when i said i thought we blew a fuse in the switch panel? an electrician friend said he thought we fried this:
which is connected to all the things!
does anyone know what this thing is called? all my internet searches fail. a supplier would be good too, but all i really need to know is what it's called.
thanks!
in other news, we ground off the side walls and removed the insulation.
ground off the rest of the bolts in the floor, and took a steel cover off this hole.
seemingly it's above the fuel tank. should we leave it accessible? not really sure what it's for.
i really wish we were moving faster, this high humidity really makes it hard to do anything for more than 2 hours!
rocket
The Rocketship
Old 07-27-2014, 10:43 AM   #18
Re: The Rocketship
thanks!
That would be a solenoid. Looks like a White Rodgers 100 amp solenoid: http://www.amazon.com/124-105111-Sol...rds=124-105111
If you know what your doing, you can use a cheaper 100 amp solenoid such as this one: http://www.amazon.com/CONTINUOUS-SOL...0+amp+solenoid
Old 07-27-2014, 10:53 AM   #19
Re: The Rocketship
thank you, jatzy!
and links! you're swell!
rocket
The Rocketship
