Old 07-05-2015, 12:08 PM   #31
Originally Posted by browncrown View Post
Love working with the LED Light Strips...and really friendly to the batteries too
that last one had 9 inch tall letters, I just got in a hurry stapling and soldering it to board.. it was too hot in garage
can you imagine a 9 inch tall LED STOP sign in the back window of a suburban every time you hit the brakes??? add a flasher, so it blinks
If someone still rear ended me, I'd be rich!!!
I agree, extremely battery friendly!
Old 07-05-2015, 05:46 PM   #32
Chassis: Blue Bird
Engine: ISC 8.3
Originally Posted by milkmania View Post
the 3M adhesive on this stuff sucks!
We're talking about Made in China, no brand name, $10 on eBay including free express shipping from Shenzhen, LED tape right? You don't believe that's really 3M mounting tape, do you..?
I agree, it's been junk on every roll of LED tape I've used too. I got an inexpensive crazy-long roll of 1/16" thick foam mounting tape at a sign-making supply place and it works pretty well.
Old 07-05-2015, 09:07 PM   #33
Coachwork: IC
Chassis: CE300
Rated Cap: 32
10 minutes, HIGHLY RIGGED, and my P looks like a question mark.... I nicked a wire
but, you get the idea... board sitting on Vortec engine air cleaner ... letters 5-1/2" tall
Reminds me of Lite Brite
Old 07-31-2015, 01:03 PM   #34
Love your bus! Did you spray foam your ceiling as well? I am planning on using Bus Kote and spray foam insulation but want to leave the original bus windows in. I was a little worried about heat transfer through the windows. Is the one ac unit enough?
Emidd27 is offline   Reply With Quote
Old 08-03-2015, 08:11 PM   #35
USMCRockinRV's Avatar
Chassis: Safe-T Liner MVP
Engine: 12V Cummins
Rated Cap: 75
Thank you
I only used Bus Kote and I have no heat transfer with the original insulation in the roof.
For the windows I first put the Bubble Foil then 3/4"'Foam Board then paneling... Then Aromatic Cedar Closet Planks
I got the Coleman Mach 15 - 15,000Btu and its too big but it's nice to cool down quick
Thomas
Safety Liner MVP
USMCRockinRV is offline   Reply With Quote
Old 11-28-2015, 05:13 PM   #36
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I got mine from Superbrightleds.com. Each strip is 1 meter long and can be rigged with an optional dimmer. They already run on 12VDC.
