Old 12-06-2013, 03:34 PM   #21
Re: The Silly Been (my new bluebird)
Does anybody know anything about turning the stock rear heater into a hot water heater?
abacak is offline   Reply With Quote
Old 12-06-2013, 03:43 PM   #22
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
That would be a lot of work. Check out these units:
http://www.jamestowndistributors.com/us ... d&type=pla
They use engine coolant to make hot water while your engine is running (or in my case, when the Webasto heater is running too) and plug into 120 volt shore power when the engine isn't running. They aren't particularly expensive, either.
porkchopsandwiches is offline   Reply With Quote
Old 12-19-2013, 05:55 PM   #23
I NEED HELP
I cant find any information on the site about the aluminum runners that the seats lock into. They are through bolted to the bottom of the bus. There is an allen head on top and bolts underneath. They are a pain. We had a drill with an allen on it and I was underneath holding the bolts. Every 3 were stripping, although the allen bit is not stripped. I got a drill bit and started drilling the heads off but that was eating up $5 bits, and I can't afford that. I pulled out the dremel with a cut-off wheel and crawled underneath, it is going through wheels every 1-2 bolts.
Does anyone have any experience with these? There are about 100 bolts.
Old 12-20-2013, 02:56 AM   #24
Engine: 190hp 5.9 Cummins
Bigger grinder.
Old 12-20-2013, 08:13 AM   #25
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
Man I'm glad the seats were gone in my bus when I got it.!!!!
An angle grinder is your friend here!
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
