Old 01-10-2012, 06:52 AM   #51
browncrown's Avatar
Rated Cap: 79 at Birth
Re: The Sloth
Looks like you have a great place for your bus and lots of room to work. And love your "partner in crime", she's beautiful.
BC
Old 01-10-2012, 07:46 AM   #52
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: The Sloth
Mikey, Congratulations on getting the wood stove in your bus. I had one just like that one in my first bus. It will certainly heat up the place.
Your dog is beautiful. She reminds me of my first dog that was part Collie and part Coyote. She was the smartest dog I have ever had. Here is a pic. She lived to be 15 years old.
Old 01-16-2012, 12:05 PM   #53
MikeyBskunk's Avatar
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Re: The Sloth
I got my Dinettes Built and they are Great! thanks Jespers!!
MikeyBskunk is offline   Reply With Quote
Old 01-16-2012, 05:21 PM   #54
browncrown's Avatar
Re: The Sloth
Won't be long you'll be serving dinner there and then a sleeper for someone Bet you're beautiful dog is already eyeing that up as a place to curl down and get comfortable. Nice work.
BC
Old 01-17-2012, 09:45 AM   #55
Diesel Dan's Avatar
Engine: DT466/AT545
Re: The Sloth
Nice! I'm looking forward to seeing how you upholster the seats and finish the table. This could be overkill, but you might want to screw a 2x2 board across the width of the underside of the seat bottoms to act as bracing to prevent bowing. It would also probably help to straighten the bow that you already have in that one seat bottom in the rear seat. And if you get a nice tight fit against the sides of the seat when the lid is closed, it would act as additional lateral bracing as well and keep everything lined up properly. Just chamfer/round off the ends a bit on the side that faces down so it will easily slide into place when you close the seat.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 01-17-2012, 01:32 PM   #56
Coachwork: Ford
Chassis: Carpenter
Re: The Sloth
Ya i have been pondering something like that, i know the only 1/2'' sheets home depot had were super curved and bowed : ( so i obivously put the bow up therefor when people sit on it in time hopefully it will correct its slef? we will see. Thanks tho for the idea
Mikey
Old 01-27-2012, 09:56 AM   #57
Coachwork: Ford
Chassis: Carpenter
Re: The Sloth
I built another bench, and extended the one that houses my water tank just to flush things up, heres some pics
Old 01-27-2012, 09:57 AM   #58
Coachwork: Ford
Chassis: Carpenter
Re: The Sloth
hahaha oops wrong pics that was my first bus, 1977 VW
Old 01-27-2012, 10:02 AM   #59
Coachwork: Ford
Chassis: Carpenter
Re: The Sloth
Lets try this again
Old 01-27-2012, 10:08 AM   #60
Coachwork: Ford
Chassis: Carpenter
Re: The Sloth
I Also started to put up some paneling that i garbage picked/collecting for a wile now
