06-09-2016, 07:53 PM
#161
Chassis: TC2000 RE
Engine: 8.3l Cummins
This is great. It sure is satisfying to get those rivets in and have a solid panel in after isn't it?
Are you getting all the trapped metal chips from drilling out between the layers?
I see you are squrting some sort of sealant between the layers. Spray both the facing surfaces with the cold galv compound, let it dry (it dries really fast) then add your sealant. You may even want to hit each empty rivet hole with a shot of cold galv for extra corrosion protection.
Originally Posted by MuddaEarth
Hello everyone....I hope you guys are enjoying the videos of my progress. Here's Episode 15 coming at ya!!
06-09-2016, 09:12 PM
#162
Rated Cap: 66 Passenger
Yep....it feels real good to see it finally going back together after so long.
Yes.....I'm drilling the holes and removing the panels, deburring, sealing and installing. My sides skins are galvaneal, so they should be good. I did have them outside and they got rained on a couple times holding the moisture between them. I've sanded the corrosion off and will treat them with a metal prep and apply a good coat of epoxy primer after they are installed.
Hopefully that'll keep them preserved from the weather.
“If you want to teach people a new way of thinking, don't bother trying to teach them. Instead, give them a tool, the use of which will lead to new ways of thinking.”
― Buckminster Fuller
06-09-2016, 09:34 PM
#163
Nice work! That is shaping up nicely. The more raises I see, the more I am convinced that's the way to go.
Are you using aluminum rivets? Any worries about galvanic corrosion? Or am I being a mother hen about the whole thing?
Also, has anyone here ever used steel rivets? I would think that bucking steel rivets would be a whole new world of hurt.
06-09-2016, 09:55 PM
#164
Thanks....Raising the roof really isn't hard, it's just a lot of work. I say "Do It", you will be amazed at how much bigger it feel inside.
I'm using steel rivets and they aren't bad at all to buck. My girlfriend did a great job. You're right..dissimilar metals would be a problem in the long run.
06-15-2016, 05:56 PM
#165
For those of you following along....Episode 16 is now showing for your viewing pleasure.
06-15-2016, 06:39 PM
#166
Year: 92
Engine: DTA360 5.9L
Great work, watched all of your videos. ive learned quite a bit from you, so thank you.
06-15-2016, 09:27 PM
#167
Thanks for watching....I've never considered myself a very good teacher,
I'm more of just a do'er, But I'm super happy these videos are appreciated and inspiring others.
06-15-2016, 11:26 PM
#168
Engine: GMC
Rated Cap: 42
Great job and I loved the video! If you are in western Kansas maybe you can come to our next Colorado Skoolie meet up.
06-16-2016, 08:55 AM
#169
Thank you....A meet up in Colorado would be great! When is the next one? It'll be a while yet before Transcendence will be on the road.
06-16-2016, 03:33 PM
#170
Engine: GMC
Rated Cap: 42
We try to get together about once a year, so probably next year around this time would be our next meetup. We talked about meeting at the Great Sand Dunes National Park, but we have not finalized anything yet, so it may be somewhere else. I will try to let you know when we actually plan something.
06-18-2016, 12:53 AM
#171
Very cool.......Transcendence may be close enough by then!! Let me know!
06-18-2016, 12:55 AM
#172
Here's another update video........
06-18-2016, 06:24 AM
#173
Year: 92
Engine: DTA360 5.9L
damn man, did you get that done in one day??
06-18-2016, 10:43 AM
#174
About a days worth of work spread out over 3 days.
06-18-2016, 05:00 PM
#175
Year: 1987
Engine: 6.9L Diesel
Great build, great craftsmanship. I'd love to check out your bus if you ever hit up Seattle/Portland.
06-19-2016, 12:35 AM
#176
Thanks.......I believe my first destination will be around the portland area. Keep in touch!
06-19-2016, 06:04 AM
#177
Chassis: Chevy P-30
Engine: Chevy 454 Big Block
WOW!
I just checked out your latest video, now I have to go back and start from the beginning! Super rad build, skills, and attitude, bro! I will be pestering you with all kinds of newbie questions as time goes by! Keep up the good work, you are definitely inspiring me and the rest of the fam up here in the frigid North!
06-19-2016, 12:30 PM
#178
Originally Posted by mightymainermite
WOW!
Definitely start from the beginning......it's been quite the adventure! Thanks for the kind words and I'll be happy to help out anyway I can as you attack your project! I wish some of those frigid temperatures would make their way down here....it's been super hot here!!
06-23-2016, 05:49 PM
#179
Hello again everyone....Here's the latest on Transcendence.
06-23-2016, 06:44 PM
#180
You tha man, Lewis!
