Old 06-21-2012, 03:04 PM   #101
Engine: 466DT
Re: the wait is over
Your right though, would work like a giant potatoe gun.
Hvbuzz is offline   Reply With Quote
Old 06-25-2012, 08:45 PM   #102
Engine: 466DT
I finally got most of my plumbing finished up. I have a working toilet and shower. The one vavle not hooked to anything, is for future water tanks on the roof. Not going to happen this year though.
City water input on the outside of the bus.
Dump valve installed on my carwash black tank.
Black tank finished
Old 06-25-2012, 08:59 PM   #103
Engine: 466DT
I made a reciever carrier couple years ago to haul my snowblower on the back of my pickup. Works good on the back of the bus to haul the generator. My plans are to eventually mount generator under the bus, but I really want to use the bus now. So that will wait. I did however make a kennal for the generator so it doesn't run away on me.
Before
Now
Old 06-25-2012, 09:18 PM   #104
That makes sense. Now all you need is a gernade with a trip wire----but I digress. Your holding tank installation looks good and as it is close to the axle you won't have to worry about high centering.
Old 06-26-2012, 07:21 AM   #105
browncrown's Avatar
Rated Cap: 79 at Birth
I envy your welding skills. Your generator kennel looks great...i'm sure it won't be able to run away
BC
Old 06-26-2012, 09:16 AM   #106
"Behind every great welder is a great grinder..."
Old 06-26-2012, 11:49 AM   #107
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Make sure you weld some tabs next to the ends of your hinges so that thieves don't tap the hinge pins out. Also weld the hinges to the kennel frame. At the hitch receiver, use a locking hitch pin.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 06-26-2012, 12:29 PM   #108
Engine: 466DT
Check, check, and check
Bolt/hinge pin welded in one bushing
Tab to keep kennel from sliding out the hinge pins when closed
Mounted on bus. I have a locking hitch pin too.
Thanks for the comments guys! Sometimes its easy to over look things and is nice to catch them early.
Old 06-26-2012, 08:10 PM   #109
How about a couple of reflectors at tail light height on the cage? Just a thought.
Old 06-27-2012, 12:53 AM   #110
Coachwork: ElDorado
Chassis: Chevy P30
Engine: 7.4 liter 454 Chevy
Rated Cap: 24
WOW nice.
Question?
One your black tank of doom; the "let her rip" valve sticking out yelling "knock me off?
Have you thought about "protection around it in case your wheel goes to pieces or kicks up something and nails it?
Kinda be a major eeewwwww if that happened.
Bullwhacker007 is offline   Reply With Quote
Cant wait for the public option... Ob1 Everything Else | General Skoolie Discussions 6 10-15-2009 12:56 AM
