Old 08-15-2015, 04:01 PM   #221
Engine: 466DT
Hard to believe its been almost a month since we got home. Work has been real busy, so I haven't had anytime to work on bus since we got home. I did find a little bit of time last night and today to try and work on the valances. I didn't get them finished before we left. I got the front two mounted up today. I just temporarily wired up the passenger side, to see what it was going to look like.
Took me awhile to try and figure out what to suspend the led's behind my cutout. Finally decided to use an old wooden yard stick. The led strip is sticky backed, but figured it would eventually want to separate. So I ran some extra tape around it too. Then the bottom lights I carefully stapled them in by hand.
20150815_142315 by Hvbuzz, on Flickr
Here is all led lights. Front facing and the down strip.
20150815_150114 by Hvbuzz, on Flickr
It has a very cozy feel, mostly just back lighting though. At times I think it will be nice, but when I want to really see something, I guess I like the flourescent lights I already had in there.
This pic has the flourescent light on too, which is on the drivers side.
20150815_150200 by Hvbuzz, on Flickr
Top light only
20150815_150058 by Hvbuzz, on Flickr
Bottom light only
20150815_150130 by Hvbuzz, on Flickr
The only other thing I guess I wish I would have made the skirting alittle longer to hide the bottom leds. They have a pretty good glare if you look right at them.
20150815_150435 by Hvbuzz, on Flickr
Originally, this was just to hide the cheap roll up shades. So, I guess I'm pretty happy with the outcome. I get the option of some different lights at times now too.
Hvbuzz is offline   Reply With Quote
Old 08-15-2015, 04:24 PM   #222
Chassis: Blue Bird
Engine: ISC 8.3
That does a fine job of hiding cheap roller shades! It looks great. I don't remember whether you mentioned what color temperature those LEDs are.. warm white, cool white, maybe some RGB, or a blend?
Old 08-15-2015, 04:46 PM   #223
Engine: 466DT
Thanks Family Wagon,
They are just the warm white. Just the cheap ones on Amazon.
Amazon.com: LEģ 16.4ft 12V Flexible LED Strip Lights, 3000K Warm White, 82 Lumens / 1.5 Watts per foot, 300 Units 3528 LEDs, Non-waterproof, Light Strips, LED Tape, Pack of 16.4ft/5m: Home Improvement
The other nice thing about these is that they are 12volt and will be running off my converter or battery bank.
Old 08-17-2015, 07:06 AM   #224
Chassis: I.H.
Looks real good from here! You could route a line along the bottom inside edge to create an inset for the lights if you don't want to look straight at them.
Old 06-12-2016, 08:15 AM   #225
Engine: 466DT
Well its been a long time since an update. Mainly because I haven't done anything to the bus. Last week I finally replaced the fan clutch. I priced one from International, $500 out the door. I then contacted Vanderhaag's, where I have gotten parts from and had them replace my clutch last year. They carry Borg warner fan clutches. $270 out the door price. Pretty easy change out. So that leads me up to the last couple days. We made a small 300 mile road trip pulling the new trailer. Perfect time to test out the fan clutch. 95 degrees and high humidity. The water temp of the bus never got over 210*, most of the time just sitting there at 195* which is where the new thermostat opens, I put in last year. One problem solved. It was a big change. I believe the fan clutch has not been working right since I bought the bus. The engine actually sounds different now. I'm still planning on upgrading the radiator, intercooler, and turbo this year. That will probably be after summer though.
Old 06-12-2016, 08:28 AM   #226
Chassis: International S3800
is your fan clutch an air clutch or a standard thermal fan clutch?
Old 06-12-2016, 09:02 AM   #227
Engine: 466DT
Just the standard thermal
Old 06-12-2016, 09:38 AM   #228
Engine: 466DT
I started a project last fall that was going to be just a winter project to keep me out of the house. A new trailer to pull either one of my jeeps around with the bus. I wanted a small light weight trailer that I could jack knife behind the bus for help getting out of tight situations. Light enough, that I could use the one DD jeep to pull around like a utility trailer. Well, the winter project turned into hurry up and get it done last week, so I could use it for our first short trip this week. 300 miles with it, and I have to say I love it over my car trailer. It follows the bus tire tracks and I no longer have to make extra, extra wide corners. So any way a few pics, even though they are not bus pics.
It started with a $150 craigslist find. 6000lb dexter axle. I bought it from Ring O Matic manufacturing plant. Later on, I might upgrade the axle to something bigger. For the price, it was worth trying out.
00D0D_4KGfuNXjMDC_600x450 by Hvbuzz, on Flickr
I am tired of buying cheap trailer tires that don't last. Orginally I was thinking of going with 17.5 tires. Until, I priced them. So 19.5 tires seemed more like a better fit for me. That meant changing a few things.
8 bolt hubs
20151101_095823 by Hvbuzz, on Flickr
Single wheel 19.5 rims
20151120_174325 by Hvbuzz, on Flickr
Buying steel, and getting started
20151123_145341 by Hvbuzz, on Flickr
20151124_124040 by Hvbuzz, on Flickr
20151124_162513 by Hvbuzz, on Flickr
20151125_170533 by Hvbuzz, on Flickr
This is a very dedicated trailer. So I wanted everything to have its place.
20151129_160529 by Hvbuzz, on Flickr
20151204_164815 by Hvbuzz, on Flickr
20160207_120944 by Hvbuzz, on Flickr
Drive over fenders, and recessed storage for holding spare tires, including the bus spare
20160529_175121 by Hvbuzz, on Flickr
Final weights. I was hoping for right around 1000lbs. Real world. 1300Lbs
20160605_152750 by Hvbuzz, on Flickr
Final axle weight with little jeep loaded. 4460lbs.
20160605_164443 by Hvbuzz, on Flickr
Lots of lights
20160605_205435 by Hvbuzz, on Flickr
Bus Pics!!
2016-06-11_08-35-44 by Hvbuzz, on Flickr
2016-06-11_08-36-32 by Hvbuzz, on Flickr
2016-06-11_08-37-01 by Hvbuzz, on Flickr
2016-06-11_08-36-49 by Hvbuzz, on Flickr
Old 06-12-2016, 09:52 AM   #229
Nicely Done!!!
Old 06-12-2016, 11:08 AM   #230
Engine: 466DT
Originally Posted by Tango View Post
Nicely Done!!!
Thanks!
Bus tire between the fenders
20160612_102310 by Hvbuzz, on Flickr
20160612_102255 by Hvbuzz, on Flickr
Trailer spare for now. Plus the ramps.
20160612_102242 by Hvbuzz, on Flickr
Cant wait for the public option... Ob1 Everything Else | General Skoolie Discussions 6 10-15-2009 12:56 AM
