Old 10-02-2010, 07:46 PM   #21
Engine: 466DT
Re: the wait is over
After a long hard week the bus is painted. Just a glimpse of early photos in the paint booth. I know, I know, dont paint it black, but I really wanted it black. I figure I can make up the difference in insulation and roof top airs. It is only a recreational bus for us. So here it is
Hvbuzz is offline   Reply With Quote
Old 10-02-2010, 11:23 PM   #22
Engine: DTA360
Rated Cap: 16
Originally Posted by CAMO-MONSTER
Originally Posted by dirtygoat
Nice looking bus...
X2 on the child labor, my 15 year old son has played a huge part in building the bus and the Blazer/Buggy...
Speaking of Blazer, I saw the link to the 4x4 site... I'm a wheeler as well... Gonna use the bus as my tow rig for wheeling trips...
Good luck with the build...
you should see the BEAST of my truck 71 k10/k20 on 40s
Nice... We should start a thread about wheeling rigs that skoolie owners have...
dirtygoat is offline   Reply With Quote
Old 10-02-2010, 11:26 PM   #23
Engine: DTA360
Rated Cap: 16
Hvbuzz, nice progress... I had a couple of weeks without working on the bus... Kinda nice to get away from it... Had to work on the Blazer for a wheeling trip... It was a buddies bachelor party trip, had a blast... Like I mentioned in the post to Camo, we need a wheeling thread for those that are using their skoolies as tow rigs...
Old 10-03-2010, 09:14 AM   #24
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
Nice looking bus...
cool i'm game!!!!!
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 10-03-2010, 11:00 AM   #25
browncrown's Avatar
Rated Cap: 79 at Birth
Paint job looks great!
BC
Old 10-03-2010, 12:33 PM   #26
Engine: 466DT
Thanks. I really like what you did with the carpet on the ceiling on your bus. I think I might do the same kind of thing, but maybe even run it on the walls too. I have my eye on two different shades of carpet, one for the walls and one for the ceiling. I want to thank you, because of your bus, and showing the wife, made it for an easy sell on converting our own.
Nate
Old 10-03-2010, 01:16 PM   #27
browncrown's Avatar
I haven't finished out my bathroom area yet, but some of that will have carpet on the walls too. It's easy to work with and helps to give some added insulation. I like the look of it too. I have a lot of paneling in the bus, so the carpet helps to break the pattern and give it a special look. It's easy to put up with Liquid Nails. The only thing that sticks better is the gum the kids left behind when the skoolie was a school bus
BC
Old 10-03-2010, 05:11 PM   #28
Engine: DTA360
Rated Cap: 16
I'm on the carpeted walls and ceiling band wagon as well... I'm actually gonna carpet the bunks and seats after they're framed in... Then garage floor shop padding for the flooring...
Hvbuzz, are you looking at the indoor/outdoor stuff at Home Depot???
Old 10-03-2010, 05:53 PM   #29
Engine: 466DT
At menards they have two different shades of a light beige and and brown indoor/outdoor carpet. I was thinking the darker(which is still pretty light color) on the ceiling and the lighter color on the walls. I think I will be pulling up the old plywood flooring now. Smitty's right, easier now then wishing I had done it later. Paint and seal floor. Here's a question/comment, I see everybody using the red rosin paper, I actually have a huge roll of tyvek from a old housing project. I was thinking of using it on the floor under the pink insulation, and maybe even on the walls. Any comments? Then plywood over the foam. I've also been debating,,, I'm going to do a cheap laminate floor, but was thinking it would be alot easier to just do the entire floor of the bus while its open, and then build on top of it for walls. I'm not sure that is a great idea, but it seems it would be alot easier than cutting and fitting pieces later. Cons I see are, wasted material, if the flooring is ever damaged it could be real pain to fix, also I believe the stuff is meant to be used as a floating floor and having walls and such on it might not be great. Pros eaiser now. Any suggestions?
Old 10-03-2010, 06:18 PM   #30
browncrown's Avatar
I have wood laminate in the center portion of my bus in the kitchen area. It makes for a great floor, but you are right, it is meant to be a "floating" floor. The cold and the heat does make the section I laid down expand and contract. I didn't build any walls over mine, so I don't know if that will be a problem or not. The movement of the floor is minimal in the expansion/contraction, but all materials are going to do that anyway.
BC
Cant wait for the public option... Ob1 Everything Else | General Skoolie Discussions 6 10-15-2009 01:56 AM
