Old 06-10-2012, 02:46 PM   #91
Year: 1979
Coachwork: superior
Chassis: intl loadstar 1653
Engine: D150 V8 diesel
Rated Cap: 48
Re: the wild blue yonder
HEY! OL TRUNT, CHEV49, TANGO, ANY OF YOU BODY GUYS.... I NEED SOME ADVICE
I have an idea for the rear "fenders / wheel archs";
buses are pretty flat, boxy things, so I've been looking for flat donor fenders to use. so how about using some polished diamond tread plate like is on jeeps and old broncos? Thinking to cut some to fit similar to below , only I won't use painters tape to hold it on, that is clearly a duct tape job.I could cut my own radius, plus the old girl would have some flash.
Just thinking that this might not look so bad after being done by someone with a medium/low skill level such as myself.
Allen,
atcc77 is offline   Reply With Quote
Old 06-10-2012, 02:55 PM   #92
atcc77 --- are you thinking of running the diamond plate full length along the bottom or only around the rear wheels? I'm thinkin' full length would look pretty cool.
Old 06-10-2012, 04:20 PM   #93
as long as it clears the tires it should look very good if you round your outside corners a bit..
come to think of it, the last one ton dualie that i had, i took two 1950 (i think) stude starlight coupe rear window shelf pieces which the outside nicely fit inside the wheel well arch and all i had to do was weld up four tabs to hold it in place... that wont work for you of course, because your wheel arch isnt round.
Old 06-10-2012, 05:38 PM   #94
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by atcc77
I have an idea for the rear "fenders / wheel archs";... only I won't use painters tape to hold it on, that is clearly a duct tape job.... Just thinking that this might not look so bad after being done by someone with a medium/low skill level such as myself.
May I suggest that you use the "Gorilla Tape" Duct tape. It's really "sticky". Let's not forget, in the immortal words of Red Green... "Spare the Duct Tape, Spoil the job."
Fulltime since 2006
Old 06-10-2012, 09:03 PM   #95
I like what the new wheel arch does for the lines but I am not sure I'd go with diamond plate. Are the original "fenders" plastic or fiberglass? If so, I would consider simply extending them as necessary rather than mixing and matching. If they are metal then just weld in what you need to achieve the look you want.
Old 06-10-2012, 09:38 PM   #96
Year: 1979
Coachwork: superior
Rated Cap: 48
Ol Trunt- the wheel openings are just stamped into the lower body skin, 16 ga I ,think. If you look at the profile pic you can see the offset difference between the lower skirt area and the top of the wheel arch (the problem area for me). My problem is that while I can do some welding,my skill level isn't good enough to make it look good. Thought I would at least run this idea up the flagpole. I do have some scraps around so I can practice before committing on the bus.
Tango- I initially thought to use it just on the 7' panel, BUT, you are correct sir, would look much better as a rockguard down the full length of the skirt and would be easier to cut doors for belly bins, could possibly do away with the bottom rub rail all together..
Chev49- I LOVE 40's and 50's studebaker pickup rear fenders, thought of using some on my next teardop project... if I could find them that is. If they would work on this bus I would be a happy man
Lorna- Red Green? REALLY? I wondered if I was his only fan... I won't tell anybody if you don't.
Thanks for the input
Allen,
Old 06-10-2012, 09:50 PM   #97
Year: 1979
Coachwork: superior
Rated Cap: 48
profile of the wheel arch
Allen,
Old 06-10-2012, 10:06 PM   #98
Rated Cap: 89
... Lorna- Red Green? REALLY? I wondered if I was his only fan... I won't tell anybody if you don't.
I loved the "humdinger" car (two cars taped together with..... DUCT TAPE! And they drove it! Amazing. Thank you CBC.
Fulltime since 2006
Old 06-11-2012, 08:34 PM   #99
Year: 1979
Coachwork: superior
Rated Cap: 48
Thanks to the rain and a helper with a bad knee, I got to spend some bonus time in the Yonder today. My metal floors are RUSTY!!!, so I checked on the cost of new 16ga sheet metal -$57.00 per 4 x 8 sheet, need 5 of them; hmm, if I can keep the cost of tearing out the old to under $100.00 I should be ok, and I can also really clean up the underside - almost a " frame off" opportunity! Seems like a plan is coming together, I'll bet that floor will come right up so lets get started! ........
HOLY CRAP! this floor has officially kicked my ass today. I attacked it with a combination of grinder, air chisel, and floor chisel / 2# hammer. THERE HAS TO BE A BETTER WAY , I spent a quarter of the tear out budget on a wheel well and a very little bit of floor. I wonder if a torch would work?
Another problem, when I try to attach photos now, I get a red message that says " Sorry, the board attachment quota has been reached." WTF?
I'm sure there's a way around this as well.
Allen,
Old 06-11-2012, 08:43 PM   #100
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
ha attc77 when u are up in ellijay come by and see it,let me know ill send u my number
keith is offline   Reply With Quote
Wild Blue Seeria Skoolie Conversion Projects 80 03-04-2013 06:27 PM
How wild is your A/V setup? NewSkewlHauler Conversion General Discussions 16 07-06-2010 01:13 PM
Into The Wild (The Movie) josetann Everything Else | General Skoolie Discussions 6 08-08-2009 09:44 PM
Question for Wild Goose Davilance Conversion General Discussions 0 11-25-2006 08:39 PM
The Wild Goose ? soused moose Everything Else | General Skoolie Discussions 1 01-21-2004 08:37 AM
