Old 05-13-2012, 08:53 PM   #51
Re: the wild blue yonder
No to epoxy--it won't allow for flexing. Are your tanks front to back parallel to the frame rails or do they mount side to side across the rails? I once connected two gas tanks in the same manner as you show in your drawing and because they were parallel to the frame front to back everytime I went up hill all the gas ran to the back tank and I would run out of gas Running out of gas is one thing--having poo comming up the throne is quite another. Just a thought.
When asked "what do you think?" I usually answer "not very much and not very often" Ha.
ol trunt is online now   Reply With Quote
Old 05-13-2012, 09:22 PM   #52
Year: 1979
Coachwork: superior
Chassis: intl loadstar 1653
Engine: D150 V8 diesel
Rated Cap: 48
I'm thinking the tanks will be mounted front to back. I haven't got my toilet yet so I'm not sure how well the flapper will work as a check valve. Since the thrones I've been looking at are the," fill with water before the dirty work" type, I'm counting on the toilet to stop any backsplash. One thing is certain though, nothing gets installed until all the peices are here and I understand how they work (or don't).
Allen,
atcc77 is offline   Reply With Quote
Old 05-20-2012, 07:54 PM   #53
Year: 1979
Coachwork: superior
Rated Cap: 48
The plumbing is just gonna have to wait. She who must be obeyed has spoken," If its going to stay here, get it painted."
We went to pick colors at one of the big boxes and and as agreed, Suzy and Ian picked the color scheme..... blue and purple with a white top. Didn't see that coming. I decided to start with the wheels because they are double ugly now. Also maybe I can find the mystery brake fluid leak as well as repack the wheel bearings and check brake pads. I've not worked on these type wheels before so removing it proved to be tricky, the lug nuts and bolts just spun around, something that doesn't happen on most anything else, wound up taking the spindle nut off and removing the wheel and brake drum off as one unit.
Sandblasting was another 1st for me today, got some playsand to use with the blaster nozzle, but took a while to realize that it needed to be screened to remove the bigger pieces that clog the tool. Once the sand was sifted through a window screen, the stripping process went fairly quick.
Got the wheel painted for the most part, but couldn't get it back on the bus today.
The job that been taking all my time for the past 2 months will be over tomorrow, so I'm looking forward to getting the sheet metal for the windows put up this week, thus closer to painting the outside..... blue and purple. This thing is going to look like a big bruise.
Anyway heres some pictures of the work today
Allen,
Old 05-20-2012, 08:56 PM   #54
The Kid sure was right about the blue--it looks great. I like the white detail as well. Maybe (if you are anything like the rest of us) the purple will be displayed about your being rather than on the bus Oh well, if a little purple paint is the only toll being extracted you've got nothing to worry about. Have fun with the paint job and keep the pics comming.
Old 05-21-2012, 09:51 PM   #55
Year: 1979
Coachwork: superior
Rated Cap: 48
Finally have a few days off so it time to get some bus stuff done!! Going tomorrow to get some sheet metal and some rivets so I can get my windows skinned, maybe some paint and solarflex as well. Also have my eye on some other things on craigslist, like a glass tabletop. I'll try to post a pic of it.
Allen,
Old 05-21-2012, 10:07 PM   #56
Year: 1979
Coachwork: superior
Rated Cap: 48
So this is what I'm thinking about this table;
Since it already has mounts attached for securing to a base, I will weld up a metal frame with a single support pole under the center of the table. Because the table will only be supported by the center pole, the table should not be subject to breaking due to body flex. I'm still working out how to absorb other jarring shocks, such as potholes and the like, maybe some sort of fluid dampener between the pole and square table base. I know this seems alittle complicated for a school bus, but a glass table would be extremely cool don't tha think?
Allen,
Old 05-23-2012, 12:32 AM   #57
Year: 1979
Coachwork: superior
Rated Cap: 48
Today, Ian and I spent the day together gathering materials for the Yonder, some sheet metal ( 2 pcs 20ga- 4x10, 1 pc 18ga- 4x10), a rivet tool, some sealant tape, and some gasket material(so I can put the wheel back on) . We also priced a few other things at a couple of camper stores where we could actually see them up close. I had just about made my mind up to buy a new toilet and water pump along with a few other plumbing parts just not to have that "ick" factor of using used plumbing until I saw how much this stuff cost. . We are now planning to visit the used RV parts guy way across town to look for a used throne.
Hopefully tomorrow we can get the windows skinned and get the painted wheel back on. I think I've been pushing my luck with the neighbors having a three wheeled bus at the front of the neighborhood; now, if we just take out a few windows for a couple of days, I'll bet the county code enforcement guy will be by for a visit.
We are planning to get some paint on her over the weekend, will post pics as soon as there's something to see.
Allen,
Old 05-23-2012, 09:32 AM   #58
i have never seen a 3-wheeler bus before...
Old 05-23-2012, 11:03 AM   #59
Take a batch of home baked cookies to each of the neighbors who have had to live with your tripod bus and try to get them to agree to some type of time frame in which you promise to do thus and so--once the CODE guy gets there your life will never be the same and they don't eat cookies
Old 05-23-2012, 09:15 PM   #60
Year: 1979
Coachwork: superior
Rated Cap: 48
We didn't make any cookies for anybody yet, was alittle busy today. I wanted to get the sheet metal over the selected windows. After seeing the way Rainbow Boxer did his, I thought I would try the same method with one change, I got a metal fab shop to cut my pieces and brake a one inch lip on the bottom edge that sits on the window opening. Trying to spread the crack between the roof and top wall rail has proved slightly difficult but not impossible.
The funny thing is, today is the first day of doing anything on the side visible from the street and I had 4 people pull in to ask what I was doing to the bus, and at least half a dozen honk as they drove by. I guess we"ll be ok.
Allen,
Wild Blue Seeria Skoolie Conversion Projects 80 03-04-2013 06:27 PM
How wild is your A/V setup? NewSkewlHauler Conversion General Discussions 16 07-06-2010 01:13 PM
Into The Wild (The Movie) josetann Everything Else | General Skoolie Discussions 6 08-08-2009 09:44 PM
Question for Wild Goose Davilance Conversion General Discussions 0 11-25-2006 08:39 PM
The Wild Goose ? soused moose Everything Else | General Skoolie Discussions 1 01-21-2004 08:37 AM
