Old 06-11-2016, 06:20 PM   #1
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Too Freakin' HOT!
Interior temps climbed to immediately south of 100 the other day - with a lot of windows open. So I tightened the belt and headed off to Wally World to purchase a 10K BTU window AC unit. It only draws 8.2 amps, so it won't overload shore power.
The fun part? Removing a window in order to install the AC. I've cleared the caulking on the inside using a linoleum knife, but fear that there's some outside that may be holding the window in the opening.
Any suggestions to help me in removing said window?
Old 06-11-2016, 09:18 PM   #2
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
maybe get a can of dust off or freeze spray and blow it like crazy on the stubborn spots so they get crazy cold (frosty even) and it just might make the caulking brittle enough that a pair of flat bars (one on each side) will pop it loose??
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 06-12-2016, 08:26 AM   #3
Chassis: International S3800
I was working inside my bus yesterday.. I bought a 12K Inverter style soft-start Portable 2 Hose A/C to use while working in the bus and then also to use when im parked since i got ripped for talking about idling my bus ...
in full sun with a stock bus that unit did NOTHING.. well i wont say nothing.. it was 94 outside with a dewpoint of 68.. full sun.. non tinted windows... and it made my interior temps 90...
the unit uses dual 6 inch hoses and the air coming out of the oiutput hose was burning hot so I know it was moving heat.. makes me rethink the whole A/C thing... now when running my engine and the portable A/C of course it cooled down inside.. but at idle im estimating im pushing out about 30,000 BTU of A/C plus the 12,000 on the portable..
makes me think I need to tear out my ceiling, insulate and then install tinted windows.. though that will be a next summer thing as I want to run my bus and not have it in pieces the rest of this year..
Old 06-12-2016, 08:39 AM   #4
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Yeah buses really are about a worst case scenario for insulation. At least the way they come they are.
Here in HOT and sunny FL, hardly any of us locals buy/use those portables. We tried using one for ONE room in an apartment. Totally worthless.
I guess they're more useful in places that don't get quite as hot.
Roll Your Own Build Thread
Old 06-12-2016, 09:41 AM   #5
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Don't call them worthless! Poor little A/C that could!
For real though, on mine, the exhaust plastic NON-INSULATED duct gets super hot...as if i'm burning a heater and an A/C unit at the same time. So my plan is to stick the portable unit with the exhaust right up against a window, on a shelf
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 06-12-2016, 10:36 AM   #6
you NEED a 2 pipe unit or you are just bringing in more hot air and exhaisting some of your cool air...
I took and used 6 inch insulated flex duct for my exhaust tube and it didnt make much difference...
im going to have to re-think alot of my A/C strategies since I prefer warm weather and my bus will generally be travelling from cold weather toward warmth... in winter of course I'll have to deal with heat.. but theres probably a reaosn my bus stock came with 200k Plus in total Heating BTU
Old 06-12-2016, 10:55 AM   #7
For what it's worth...I know a couple of local folks who tried using top of the line portable A/C's in fairly small spaces and wound up tossing them because they didn't cool worth a squat.
Old 06-12-2016, 01:53 PM   #8
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Let's try this again. I HAVE ALREADY PURCHASED A 10K BTU home window unit. My problem now lies in removing a single window so that I may install said AC unit in the hole now left vacant.
HOW DO I REMOVE THE WINDOW? I'll try the cold spray, but I need more suggestions.
Old 06-12-2016, 04:25 PM   #9
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
I can't say about a Thomas, a Bluebird has the windows basically held in with putty. There is one large screw on each side, the bottom sits in a channel. Steady pressure inward at the top was enough to get the putty to start releasing.
Old 06-12-2016, 04:30 PM   #10
Chassis: IC CE
Engine: T444
This is why i am insulating the floor the ceiling and sidewalls. I also plan to have some insulated "curtains" ive seen a few people make.
Azuleslight is offline   Reply With Quote
