Old 09-27-2010, 08:58 PM   #91
CAMO-MONSTER's Avatar
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
Re: Toyhauler/camper project:
wish my sides looked that smooth
hd d44 4.56, eaton ff 4.56
CAMO-MONSTER is offline   Reply With Quote
Old 10-23-2010, 01:50 PM   #92
Chassis: C60
Engine: Chevy 7.4l 454 FI
Rated Cap: 59
Finally got the spray foam kit and got it sprayed in today. when they tell you to wear the disposible suit, do it, I forgot to get it and didnt want to wait any longer to spray cause the weather is getting colder and I wanted it sprayed before it got too cold. Still got to shave it down but here it is. I missed a couple spots I can hit with can foam later.
ramairws601 is offline   Reply With Quote
Old 10-23-2010, 02:14 PM   #93
browncrown's Avatar
Rated Cap: 79 at Birth
Looks like it will be insulated to the max. Going to be nice
BC
Old 10-23-2010, 03:37 PM   #94
Chassis: C60
Rated Cap: 59
Thanks for compliments!
http://www.betterenergystore.com/
I used the 600 bd ft kit and used all of it today. I started spraying and never stopped till it was out. It's not hard to do but it is slightly costly and messy. I am sitting here picking foam bits of my arms and hands thinking I should have bought some sort of disposible suit and gloves. hindsight is great isnt it?
Big improvement in the tin can sound of the empty shell. The walls are more solid and dont flex much at all which was one of main reasons for using spray foam. the other reasons were I have no patience at all to cut all those pieces of foam board to fit around the braces I welded in. I was worried foam board may rub the metal and squeak unless I glued it in place but if I was going to do all that then I might as well spray foam it. This is closed cell foam and is designed as a sealant as well. no water or pests can go thru or around this.
I have about 1 - 1 1/2" of foam build up in the walls and about 1" on the ceiling. I may add more insulation going in the ceiling. cost me $630 for the 600 bd ft kit w/ 15ft gun. to do 600 ft of sheet foam 1" thick was going to run 475 or so (plus tax) then I would have to cut it, glue it in place, & tape the joints up. so for just a little more $ I got a much better result. I am out of foam, actually one cyl still has a good bit of chemical in it strangely?? the gun is reusable so I could use it for something else or even sell it. The kit can be bought from the site above without the gun assy.
7.3l Shuttle Bus 4x4 toyhauler headinthetrees Short-Bus Conversion Projects 39 03-09-2015 05:45 PM
Flatbed toyhauler? Tofer Conversion General Discussions 2 11-17-2011 05:57 PM
toyhauler bus conversion -MOVING- MUST SELL ASAP! ramairws601 Classifieds | Buy, Sell, Swap 1 09-12-2011 12:53 AM
GMC 8100 Motorhome Toyhauler Abbott Everything Else | General Skoolie Discussions 6 08-13-2010 08:07 PM
PLEASE LEAVE FEEDBACK TOYHAULER/CAMPER PLANNING jkindt Skoolie Conversion Projects 4 04-22-2010 09:04 PM
