02-21-2010, 10:03 PM
#41
Engine: 5,9 Cummins
Re: Toyhauler/camper project:
Yeah, please put those rub rails in an envelope. I'll reimburse you the 44 cents.
"Not building a watch" is something I say here also. I believe that phrase was coined by one Otis Gudenov. (Oh, t'is good enough.)
Carry on.
02-22-2010, 03:02 AM
#42
Year: 1974
Coachwork: CARPENTER
Chassis: GMC-6000
Engine: 454 CHEVY
[quote="ramairws601"]Planning to skin the entire bus to make it smooooooooth. 20 ga is what I plan to use, $33 for a 4x10 sheet. 6 sheets per side is what it will take. I got it laid out so most of the seams will fall within a window/door/fender well area and the seem down the middle I can hide behind a pinstripe! I do plan on butting the pieces together so if I dont weld then I will have a backing strip and 2 rows of rivets and that takes away from the smoothness!
for todays progress.......
Chevy Silverado steering wheel from todays swap meet $6
Dash removal
rest of round corners in rear gone, gonna extend and square off the rear to the end of the floor
and wire wheeled the floor in prep for primer.
Looks like you might have the same rear end as my skoolie a gm t170
two speed judging by the shifter and we have the same steering wheel.
hd d44 4.56, eaton ff 4.56
03-20-2010, 07:57 PM
#43
Chassis: C60
Engine: Chevy 7.4l 454 FI
Rated Cap: 59
well, I got my roof taper started today and got some skinning in of the rear gate area, not cut to final shape at top yet.
04-03-2010, 09:27 PM
#44
Chassis: C60
Rated Cap: 59
More destruction today!
also, does anyone need these rib inserts?
04-03-2010, 10:51 PM
#45
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Originally Posted by ramairws601
...also, does anyone need these rib inserts?
Uh...yes, those would come in very handy to fill the holes around my refridgerator access panel. I was going to fill them with urethane after I paint them, but actual inserts would be much more professional looking.
04-04-2010, 10:20 PM
#46
Chassis: C60
Rated Cap: 59
Oh, my God! You skinned Kenny! You BASTARD!!!
not to worry, I am re-skinning him! picture looks bad cause it was getting dark.
04-04-2010, 10:27 PM
#47
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
How do you plan to drive with your windshield skinned over??? Looks like it is coming along nice!
04-05-2010, 12:27 AM
#48
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
i think it looks like the mad max bus skinned in like that man you r cuttin that thing all up keep it coming and a cool old chev to boot keep on pounding!timbuk
04-05-2010, 07:32 AM
#49
Chassis: C60
Rated Cap: 59
had to take the taper piece down to do some trimming on it, got it back up the windshield and the wind was gusting 35+ so I left it there strapped. it is actually back up there now but it was too dark to take a pic.
smitty is this the one? heres a link to more pics of this bus, http://www.pirate4x4.com/forum/showthread.php?t=298476 I have plans to do the same, stainless from the point my metal stops at now down the rest of the way, all hinged to provide access to storage, tanks, batteries, etc. will taper the bottom back up for clearance like this one as well. Like the stainless, also thought diamondplate aluminum would be cool but cost may be the deciding factor along with the pain of maintaining that diamondplates shine, Smooth stainless would be easier.
04-05-2010, 07:41 AM
#50
Chassis: C60
Rated Cap: 59
also while crawling around I had found my LR axle seal leaking and it looks like one of the tires did some cracking on its way home, of course they are only 20 years old, guess that is expected huh?
04-05-2010, 02:31 PM
#51
Coachwork: ward
Chassis: IH
OMFG..... Beautiful, I just got a woody..... Wait.... what did I just say? Brings a whole other meaning to the rank of "Bus Nut".....
Cheese, I'm woodied up with you on this. JUST FREAK'IN AWESOME!!!!!!!!
"I've never been lost, but I been mighty confused for several days"
04-05-2010, 03:47 PM
#52
Chassis: Safe-T-Liner MVP
Engine: CAT3116
WOW, that's a lot of sheet metal. I'll be eagerly checking the progress on this build, that's for sure. Nice job so far!
1. Always use the right tool for the job.
2. A hammer is the right tool for any job.
3. Anything can be used as a hammer.
04-05-2010, 09:21 PM
#53
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
I agree...nice looking bus. I hadn't even seen it before I came up with this...
...very classy!
04-06-2010, 07:41 AM
#54
Chassis: C60
Rated Cap: 59
heres a couple better pics,
04-07-2010, 03:54 PM
#55
Rated Cap: 79 at Birth
Damn, I have metal siding envy! Wish I had the talent to do that. The side in this last pic and the transition on the top looks totally perfect
04-07-2010, 05:16 PM
#56
she is looking good!!! like the staggered roof setup!
you are not alone on the "not getting home first try" thing. I got my bus in Prince George, BC. I made it 3 blocks and the front right caliper seized up on me. Limped it to a KAL-Tire and got the front calipers and discs replaced and some fresh pads in them. Also put new drums and pads on to. Almost turned into a "1000 miles from home and not going anywhere fast" problem lol
04-07-2010, 06:16 PM
#57
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Looks like a big armoured....skoolie! Very mean and tough looking! I like it!
04-07-2010, 08:25 PM
#58
Chassis: C60
Rated Cap: 59
thanks for all your compliments on this. I went back and forth on wether to re-skin the whole side or not but by your responses I am feeling better about spending the extra time and money on it!
I have alot more spot welds to put in, probably another days worth of that before I can move onward. I have to weld in cross supports at the seams between the sheets of metal to stiffen it up some more and figure out where my windows will be and add some metal in those areas. then its on to the insulation/wood sheets for the floor and walls. I will be using this as a open design inside for awhile this summer with bare essentials to get us by till winter time when it gets too cold to ride anymore.
04-18-2010, 11:13 PM
#59
Chassis: C60
Rated Cap: 59
been a busy week, I got my floor primed and bolt/nail holes sealed up. got the corner skins formed today and will be riveting them in this week sometime. also replaced the temporary floor panel with a permanent piece that is fully welded in. got my patch panels for the gas sender hole in the floor and the flasher covers done. oh and I cut off all the original skins lower supports.
04-19-2010, 08:30 AM
#60
Chassis: C60
Rated Cap: 59
Originally Posted by Smitty
You must drink the same brand of triple-caffeine that Wildcat does Looks like you've been busy, looks great, I especially like the front-view
Smitty
Thanks Smitty,
It's Mountain Dew when I am working on the bus, does that count?
I am faced with a ATV ride and camping trip in 2 weeks, bus not ready, gonna be in a tent on the ground again this year.
2-3 hrs loading up, 1.5 hr drive (that I dont mind) unload, setup the tent (wind blowing no doubt) sped 2 nights and then do it all in reverse.
When the bus is ready I can just keep it loaded up and all I gotta do is drive the ATV's off when I get there.
Gotta get ready for the outing after that cause this first trip of the year will be a refresher course on why I am doing all this work!
