Old 12-29-2012, 08:50 PM   #181
Re: Transmogrifie and Me
Funny how diferent our views can be. I've had several shower/potties over the years and I just wiped them down after each shower--big deal. I use an industrial type shower curtain in my shower at home because it works better than a glass shower door at keeping the floor dry and it cleans up good in the wash. I also wipe down the shower in my home after each use as it keeps things looking good and keeps mold at bay. I'll be using a combo again in my '35 because it is a space saver--and much more pleasurable to use than some rented NASTY communal bath. Each to his own I guess. Jack
Old 12-29-2012, 09:55 PM   #182
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I think too it depends on if it's one person or not. I am a short person, (so I wouldn't have to stick my feet out the door to put my socks on). I would be the only one taking a shower or going to the bathroom. Although if my cat had his way we would have double sinks in the morning. And it seems to me that I have the issues of wet socks in the morning even in my big bathroom.
Any suggestions where to find one Jack? And your bus is even smaller too.
I think this guy's looks really neat but I'm not that talented. http://gmc.dwinchester.com/Wet_Bath_...onversion.html
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 12-29-2012, 10:17 PM   #183
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
OK.. this guy has to be an engineer or has too much time on his hands or something but this shower assembly in a pop-up tent trailer is awesome. I likey. http://www.fiberglassrv.com/forums/e...13484782597618 Have to select to go to the external link.
The whole thing is under his dinette bench seat.
Linda Kay
Old 12-30-2012, 07:21 PM   #184
lornaschinske's Avatar
Rated Cap: 89
Well, with a all-n-one wet bath, you can always say that you pee in your shower!
Fulltime since 2006
Old 12-30-2012, 09:20 PM   #185
Shadol, WOW! that is a really impressive bath! I'd be hard pressed to come up with something like that. I pulled the combo unit I'll be using out of a dead 5er I was given. After some cutting and pasting of its fiberglass I'll have just what I need in about 4 square feet of floor space. You might want to try to find a fiberglass combo unit in the junk yard. Fiberglass is EASY to work with and the learning curve ain't all that steep. As for peeing in the shower--I don't know. Ha! Jack
Old 12-30-2012, 11:22 PM   #186
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Wish me luck. I know I have to 'travel' about 90 miles to get to a real RV surplus/recycle place. Or maybe I'll call around first. The local one here I am going to make an appointment with but I don't think he has much at all. Much less anything that I'd want.
Linda Kay
Old 12-31-2012, 10:40 AM   #187
In my case, space available dictates a combination toilet/shower. Simply no room (inside, anyway) for two separate units. And I have to say...I'm not looking forward to that part of the build. It will require custom construction of preferably a one-piece unit. Would be simpler to do in pieces but water leak paranoia has me at least hoping for a one piece fiberglass product. Will likely have to build a form to lay the whole thing up in and may or may not leave the plywood in place. To make matters worse (more interesting?)...it will have to sit atop the driver-side rear wheel well further complicating the shape (yes...you will only be able to take a "sit-down shower"). Times like these make me almost wish for a slightly bigger bus. And since I have zero experience with fiberglass beyond small patching jobs, I am looking for some local expertise. Not much luck so far. The few people I've spoken with who have the skills are in the boat business and real busy with better paying work. It will also require a final finish of sprayed on gel coat. Yet another process beyond my means & skills.
Oh well..."life is for learning"...at least according to CSN&Y.
Onward!
Old 12-31-2012, 04:27 PM   #188
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Onward!
Yeah.. what he said.. all of it. *lol*
Linda Kay
Old 12-31-2012, 04:28 PM   #189
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
And this is my bus today...
Linda Kay
Old 12-31-2012, 05:21 PM   #190
Mmmmmm...must be northern Florida...but ya really oughta sweep all that pretty white sand off the roof!
