04-02-2015, 04:41 PM
#481
I have found my soul sister I believe!
I logged in this morning with the intent of searching for others/builds that incorporated a workroom of some kind and living space for one. I never got there. Transmogrify caught my eye in new posts. One of the first posts mentioned 'I work with fabric.' Really??? And you're a one woman work force? Sweet! I went right back to the beginning, and many hours later have gotten through all 450+ posts. You go girl!
My medium of choice is also textiles, but most any are likely to turn up somewhere. I never thought about using the toaster oven in the bus for the clay... Brilliant. Needless to say workroom design is going to be a big consideration for me. I'm contemplating putting it in the rear of the bus for better natural lighting. One thing for sure, there will be a fold out/piano-hinged top on at least one counter/work station to extend it for pattern cutting and wide fabric!
I also have grandchildren. I'm trying to design said table so it will double as a game table for game-night or possible traveling - that one is down the road though.
I can't wait to giterdun. I'm in the downsizing stage now, and selling, donating, giving away everything that won't fit. That is a project in itself. I'm afraid the majority of my sewing room stash will have to be re-homed. <sigh> I suppose all dreams require some sacrifice as payment, right?
Keep up the good work! Warrior strength and energy heading out to you woman! I look forward to following your journey!
~Pamela
04-03-2015, 03:34 PM
#482
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Soul-sister
Awesome Sassy Lass. I will find and read your string as well. I do tend far too much in the commentary.
My sister's name is Pamela. Interesting.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
04-04-2015, 12:01 AM
#483
Unfortunately, I don't have a bus yet, so no build thread, but I have lots of ideas ready for one! My vision is much the same as the way you worked on yours. Strip it down, take care of rust, insulate, then attack it bit(e) by bit(e).
I've lived OTG before, and also lived-aboard on boats for a few years. I know my way around small spaces and minimal amenities. That helps with the space planning for me. It also helps in the "thinning down" process too. I still have a long way to go on that project though. In the process, I can collect and stockpile things I can use- like the tools I don't have yet.
~Pamela
04-04-2015, 07:17 PM
#484
This made me think of you. All this stuff is great for small spaces, and pulls double duty too. There's some neat sewing-room related ideas in here. Check out the ironing board, the pull down closet rod, the desk, and the sliding panel.
~Pamela
04-06-2015, 05:21 PM
#485
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Oh yes, love the ironing board idea, the lighted closet with the pull down clothes rack. WOW. And that tiny dishwasher was interesting, I won't be having one but still.
Linda Kay
04-06-2015, 06:46 PM
#486
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
I think it is your brake light switch.
Jump the two wires and see if the brake lights come on. Good luck.
Hopeless Busaholic!
04-08-2015, 10:44 AM
#487
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
brake lights
Happy accident, we did find that out. Brake lights were going off and on.
Linda Kay
04-08-2015, 10:50 AM
#488
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
carburater
Well crap! Now my Edelbrock carburater is toast. Fuel pump in and pumping plenty of fuel.. drowning the carb. When I parked the bus it ran.. very frustrating. Rebuild or buy rebuilt? Or new? decisions decisions. My dad would have just rebuilt it.. why can't I?
Linda Kay
04-08-2015, 11:22 AM
#489
sounds like either the needle/seat in carb are dirty and not sealing when float moves up, or float in carb is bad, or too much fuel pressure causing needle to come off seat
did you put an electric pump on or manual?
04-08-2015, 11:38 AM
#490
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Manual. Said the gas rose up in it too much and was going to overflow. I was on the ignition and friend was under the hood. I'm sad because it was my fault that I didn't start it more often that all of this happened. But I've seen cars sit for long, long periods of time and this doesn't happen. I think like Tango? said earlier.. she is an old girl.
I don't think the carb is that old (it's the only thing shiny on the whole bus).
Linda Kay
04-08-2015, 11:41 AM
#491
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
brake lights
And yes... it makes the brake lights come on when we messed with the wire. Leaking air bad, never noticed it before. Brakes probably won't load pressure now? Or would this be auxiliary air? Looking for the part.
Linda Kay
04-08-2015, 11:53 AM
#492
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Smog control
Linda Kay
04-08-2015, 12:50 PM
#493
all it takes is 1 small pc of junk to get into fuel bowl and not allow the needle to seat
when you replaced the fuel pump on the engine, is there a chance that dirt got into the line to the carb? normally you would have a filter between pump and carb, do you have one?
try tapping side of float bowl with plastic handle of a screwdriver
04-08-2015, 02:21 PM
#494
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
We tried the tapping, helped a little. There is no air breather on it yet up top. We didn't take out the screen on the intake of the carb but we did have the fuel filter on. All new hose from tank to carb. Not saying that it didn't pick up any dirt in installation.
I was wondering if blasting it with carb cleaner would help at all but if it is the gaskets being dry (as someone suggested).
There was a canister fuel filter just outside the tank (which I saved) that my friend bypassed and put the fuel filter on top before the carb. Easy to see but scares me a little being over the engine.
Another friend at work is suggesting that I buy a used one off Ebay. I'm saying I have a used one.. He says "but theirs works" and I'm saying How do I know they haven't let it sit on a shelf for 2 years?
I think I've decided that I'm going to take a part, wire, hose, switch at a time into the auto parts store and say "I need a new one of these".. and slowly I will have everything new.
If my carb is junk, I'll take it apart and see if I can fix it.
Linda Kay
04-08-2015, 02:39 PM
#495
I would take carb off and just take it apart, clean and reassembly
kits are not expensive, make sure to get a complete kit, with needle/seat/float/gaskets and accelerator pump assy.
the numbers should be on the carb, do not take it apart to clean and reuse the old gaskets and such, not worth it
that carb is easy, not as easy as say a 2G rochester, and alot easier than old Quadrojet (which was worse I think) double pump holleys where easier than them
take your time and clean is clean...no open flames around work area, DO NOT use easy off oven cleaner(or similar) to clean parts...
04-08-2015, 03:21 PM
#496
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Thank you Bansil dude. How you been? I want to try this. I think I can I think I can. Thanks for the vote. My job as a kid helping my dad was washing the parts in gas.
Linda Kay
04-08-2015, 07:27 PM
#497
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
How old is the fuel?....been there.
04-08-2015, 09:47 PM
#498
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I had a little gas in it when I parked it but it's sat for 2 years. I have added more gas with stable in it but I think it might need to be drained.
Linda Kay
04-08-2015, 10:09 PM
#499
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Carb
Dirty Boy....
Identified
1407 so 750 (more carb than I think I need)
Manual... yes... choke...
Choke cable... is.... oh there it is..
And Transmission confirmed... (and I'm still itchy).
Learn something every day.
Linda Kay
04-13-2015, 12:30 AM
#500
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Wall shells
I decided, after much deliberation over long period of time, that I would take the metal walls off and add more insulation and paneling (instead of over the metal). I thought no problem because the other one wasn't hard (not as hard as people said it was).
I know now why that first panel wasn't as hard and why it had so many holes in it. Someone had to have taken that panel off and put it back on again.
Welds every 2 inches or less I had to drill out. (one drilled a bit too hard). Got one panel off.
So, now added more spun insulation to fill in the gaps and sized up the lumber I'll need.
Linda Kay
