Originally Posted by Shadoll
I decided, after much deliberation over long period of time, that I would take the metal walls off and add more insulation and paneling (instead of over the metal). I thought no problem because the other one wasn't hard (not as hard as people said it was).
I know now why that first panel wasn't as hard and why it had so many holes in it. Someone had to have taken that panel off and put it back on again.
Welds every 2 inches or less I had to drill out. (one drilled a bit too hard). Got one panel off.
So, now added more spun insulation to fill in the gaps and sized up the lumber I'll need.
you are making progress, on my bus every were i can i have been using foam as well
