Old 10-11-2013, 07:37 PM   #421
wmkbailey's Avatar
Engine: 3126
Re: Transmogrifie and Me
His thread is Best Home Yet http://www.skoolie.net/forum/viewtopic.php?f=9&t=10764
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 10-11-2013, 08:15 PM   #422
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Originally Posted by wmkbailey
Thank you so much. Went right to the glue posts. Saw that thread but I thought it was older.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 10-13-2013, 10:14 PM   #423
roach711's Avatar
Rated Cap: 19
I used some carpet adhesive that I got from Home Depot. It was quite a mess to spread on the ceiling but holds my carpeting like grim death. Spreading on the walls wasn't too bad. It cleans up with water if you don't let it get tacky.
My carpeting was some lightweight outdoor/indoor carpeting much like Accordian used on his. The wet adhesive would hold the ceiling carpeting without any additional support.
The Roach Motel
Old 10-14-2013, 07:45 AM   #424
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
I am glad that that glue is working for you.
Old 10-15-2013, 12:51 PM   #425
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Does anyone have an opinion on this solar panel for me? A guy at work thinks it's a good deal. Looks like plastic frame to me. http://www.ebay.com/itm/100W-Watts-1...item3a85951352
Wondering about running 4 of them along the top of the bus. I did like Travelin with Us Harbor Freight one too, but am hearing that Harbor Freight is iffy on quality from one thing to the next. (Although, on Ebay you're probably taking a chance as well.)
Am thinking I should get one to keep my starter battery up. I have to disconnect it when not in use.
Linda Kay
Old 10-15-2013, 12:53 PM   #426
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Thank you I did buy the contact cement but I'll look into this one, perhaps less caustic to breath.
Linda Kay
Old 10-26-2013, 12:51 PM   #427
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I think this is a good deal at $200. Any comments on this brand/size etc?
Linda Kay
Old 10-26-2013, 01:54 PM   #428
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
I have panels made by Sharps. I was told by an old timer in the van dwelling world to buy brand name panels if you can afford them. They'll be around a lot longer if warranty work is needed. Two 160W panels would charge 5_600 ah of batteries pretty easily; I would think. I have one 160W Sharps panel that charges 300 ah of batteries relatively fast. Even on the short days we're experiencing in ND this time of year.
I don't use a lot of juice but I have a 12v fridge w/freezer and my batteries rarely go below 12.5v over night. No TV but I guess the LCD TV's don't use much juice anyway. I do carry a small genset to run a charger if needed but the gas is getting old in that. I don't use it much.
Just my $0.02,
Gus
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 10-28-2013, 09:19 AM   #429
they work.....very noisy (engine not exhaust) same one I have...it works all I can say
Old 10-28-2013, 10:26 AM   #430
Chassis: Ward
Rated Cap: 1
If you are going to live in the bus full time you may be able to use some of the information on this web site. It is geared toward people that live in various rigs on wheels full time. There is a lot of good advise on living inexpensively in whatever you choose to live in. A lot of the members live out of vans full time and travel with the weather to different locations and altitudes to have the most desirable climate year round. Wit ha bus that is hard to do because of the cost of fuel of course but there is still a lot of good advise on battery bank size depending on need, solar panel size, generator size and type yadda yadda yadda.
http://www.cheaprvliving.com
gus
