Old 11-07-2013, 11:13 PM   #441
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Re: Transmogrifie and Me
Heater hooked back up for the winter. On low, first night 60 in the morning.. cool. Only it wasn't a cold night I guess. Next night 42 when I woke up and ice on the inside of my bedroom windows. Got a good deal on 3/4 inch styrofoam (denser stuff) 2 sheets already cut. Put around the walls more, temporary still. 50 degrees when I wake up. better. Got more styro board because I can feel now where the 'cold' is creeping in. A lot more insulating to go but I'm making progress. Not sitting on my computer with 5 pairs of clothes on now, only 2. Might be a long winter.. just kidding.
I need to get an outside thermometer so I an 'compare' but at a guess I'd say almost 30 degrees warmer inside than out with the heater on low.
Refrigerator is WONDERFUL.
Landlady/friend has been building a chicken pen with inside coop, ceiling the whole works. Should be able to move the chickens over this weekend (think I mentioned before about the donation of chickens. We've been going over to the neighbors and feeding them). The young ones he gave us are just starting to lay eggs now. Bigger eggs.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 11-07-2013, 11:37 PM   #442
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Thirty degrees higher than the outside temperature is usually the norm on boats and buses. Although my bus is fairly well insulated, that is about what I get.
I have insulated coveralls that I wear in the winter (inside the bus).
I also have an electric heating pad that is made for putting inside a dog house. It is 100 watts. I have it under my desk.It keeps my feet warm.
Old 11-08-2013, 12:55 AM   #443
Diesel Dan's Avatar
Engine: DT466/AT545
I've had the same experience as Rudy (Accordian). I get a 30+ degree rise by using two heaters set on low.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 11-08-2013, 10:29 AM   #444
Chassis: Ward
Engine: 6.6L Brazilian Ford
Rated Cap: 1
My bus is going in for under floor spray foam insulation next week. Four inches worth?
Bus Transformation: My CHEAP project >>> viewtopic.php?f=9&t=466640
gus
gusbus is offline   Reply With Quote
Old 11-08-2013, 11:39 AM   #445
eyedeal.ink's Avatar
under your bus or under the "flooring"?
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 11-08-2013, 11:48 AM   #446
Chassis: Ward
Rated Cap: 1
Under the bus floor; under the bus. I live in mine in winter in north Dakota. Need lots of insulation. Thinking strongly of in floor heat but haven't pulled the trigger yet. We'll see. The cost would be about 700.00 for electric in floor heat. I can put a propane stove in much cheaper. I have not decided yet!
gus
Old 11-08-2013, 03:49 PM   #447
roach711's Avatar
Rated Cap: 19
Here's a nice indoor/outdoor thermometer for about $25 shipped. It has an indoor display and an outdoor temperature sending unit and both run off batteries so you can put them both anywhere you want. I bought this model for our bus but we've been using it in the house so far. The display unit can be wall hung or set on a table.
http://www.mackspw.com/Item--i-LCT9160? ... MwodR1EAZw
The Roach Motel
Old 11-08-2013, 07:15 PM   #448
wmkbailey's Avatar
Engine: 3126
Great idea, just ordered it. It was 45 today and running my Wabasto diesel heater with an un-insulated bus, I swear it was above 70 inside. Curious to use this and see. At 45,000 btu I should be good when I get the bus insulated. I will also use it to heat the floor.
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 12-04-2013, 04:14 PM   #449
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Good ideas there. I do have an electric blanket I can wrap around me. Need to dig that out of storage.
Rudy, good to see you around, hadn't seen anything from you in a while.
Linda Kay
Old 12-04-2013, 04:15 PM   #450
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Good idea.
Linda Kay
