Old 04-08-2015, 11:41 AM   #491
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
brake lights
And yes... it makes the brake lights come on when we messed with the wire. Leaking air bad, never noticed it before. Brakes probably won't load pressure now? Or would this be auxiliary air? Looking for the part.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 04-08-2015, 11:53 AM   #492
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Smog control
Stay or go? We don't test for emissions in my town but ?
Linda Kay
Old 04-08-2015, 12:50 PM   #493
all it takes is 1 small pc of junk to get into fuel bowl and not allow the needle to seat
when you replaced the fuel pump on the engine, is there a chance that dirt got into the line to the carb? normally you would have a filter between pump and carb, do you have one?
try tapping side of float bowl with plastic handle of a screwdriver
Old 04-08-2015, 02:21 PM   #494
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
We tried the tapping, helped a little. There is no air breather on it yet up top. We didn't take out the screen on the intake of the carb but we did have the fuel filter on. All new hose from tank to carb. Not saying that it didn't pick up any dirt in installation.
I was wondering if blasting it with carb cleaner would help at all but if it is the gaskets being dry (as someone suggested).
There was a canister fuel filter just outside the tank (which I saved) that my friend bypassed and put the fuel filter on top before the carb. Easy to see but scares me a little being over the engine.
Another friend at work is suggesting that I buy a used one off Ebay. I'm saying I have a used one.. He says "but theirs works" and I'm saying How do I know they haven't let it sit on a shelf for 2 years?
I think I've decided that I'm going to take a part, wire, hose, switch at a time into the auto parts store and say "I need a new one of these".. and slowly I will have everything new.
If my carb is junk, I'll take it apart and see if I can fix it.
Linda Kay
Old 04-08-2015, 02:39 PM   #495
I would take carb off and just take it apart, clean and reassembly
kits are not expensive, make sure to get a complete kit, with needle/seat/float/gaskets and accelerator pump assy.
the numbers should be on the carb, do not take it apart to clean and reuse the old gaskets and such, not worth it
that carb is easy, not as easy as say a 2G rochester, and alot easier than old Quadrojet (which was worse I think) double pump holleys where easier than them
take your time and clean is clean...no open flames around work area, DO NOT use easy off oven cleaner(or similar) to clean parts...
Old 04-08-2015, 03:21 PM   #496
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Thank you Bansil dude. How you been? I want to try this. I think I can I think I can. Thanks for the vote. My job as a kid helping my dad was washing the parts in gas.
Linda Kay
Old 04-08-2015, 07:27 PM   #497
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 8 Assengers 2 ATV's
Originally Posted by Shadoll View Post
Well crap! Now my Edelbrock carburater is toast. Fuel pump in and pumping plenty of fuel.. drowning the carb. When I parked the bus it ran.. very frustrating. Rebuild or buy rebuilt? Or new? decisions decisions. My dad would have just rebuilt it.. why can't I?
How old is the fuel?....been there.
Old 04-08-2015, 09:47 PM   #498
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
I had a little gas in it when I parked it but it's sat for 2 years. I have added more gas with stable in it but I think it might need to be drained.
Linda Kay
Old 04-08-2015, 10:09 PM   #499
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Carb
Dirty Boy....
Identified
1407 so 750 (more carb than I think I need)
Manual... yes... choke...
Choke cable... is.... oh there it is..
And Transmission confirmed... (and I'm still itchy).
Learn something every day.
Linda Kay
Old 04-13-2015, 12:30 AM   #500
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Wall shells
I decided, after much deliberation over long period of time, that I would take the metal walls off and add more insulation and paneling (instead of over the metal). I thought no problem because the other one wasn't hard (not as hard as people said it was).
I know now why that first panel wasn't as hard and why it had so many holes in it. Someone had to have taken that panel off and put it back on again.
Welds every 2 inches or less I had to drill out. (one drilled a bit too hard). Got one panel off.
So, now added more spun insulation to fill in the gaps and sized up the lumber I'll need.
Linda Kay
