Old 10-15-2014, 09:07 AM   #71
Re: TRusty Bucket .. since the thread is not going away lol
With any flux core welder, make sure you have really good ventilation where you are working. The flux (coating on the wire) gives off some pretty noxious fumes along with quite a bit of spatter. They are a bit messy to work with but will get the job done. Just do a fair amount of practicing on metal the same type & thickness as what you'll be working on. Once you get the settings right (heat & wire speed) then you have to also find the right speed for your hand to move. With sheet metal, you need to be careful how much heat you put in any one area. Begin by tacking small spots around the workpiece and alternate where you put them. Kind'a like the way you alternate torquing down bolts. Just take your time, move from spot to spot and fill it in slowly. There are tons of tutorials online.
One more tool that is handy for this kind of work is a set of "butt weld clamps" to hold the metal flush until you get it tacked. Cheap and handy...like these...http://www.harborfreight.com/8-piece...mps-60545.html Magnets are handy too.
Best of luck on the build. Once you begin welding you will likely start coming up with all sorts of things you wouldn't have otherwise.
Old 10-15-2014, 09:45 AM   #72
Chassis: International Amtram Genesis
Rated Cap: 87
I looked at those clamps.. but how do you clamp when you're welding a floor?
DUH.. never mind.. I see ..
Theresa
"Great Spirits Often Encounter Violent Opposition from Mediocre Minds" -- Einstien
My Conversion Thread: viewtopic.php?f=9&t=467774
My Facebook Blog: http://www.facebook.com/sliceoflifeRv
missingTexas is offline   Reply With Quote
Old 06-04-2017, 04:07 PM   #73
water boy's Avatar
Year: 1987
Engine: 7.3 IDI
Wife and I came to town today and saw you parked next to the old athelitic center. What a surprise to see a fellow skoolie! That is quite a solar array you have what kind of power are you putting out?
water boy is offline   Reply With Quote
missing thread DizzyIzzy Forum Admin | Account Help | Suggestion Box 1 09-23-2010 12:42 PM
Storage Thread TygerCub Conversion General Discussions 10 11-05-2009 09:47 AM
The Beater Thread the_experience03 Everything Else | General Skoolie Discussions 83 09-14-2008 07:20 PM
Cummins 5.9L Thread KC10Chief Conversion General Discussions 15 11-06-2007 09:51 PM
