Old 10-16-2014, 02:45 PM   #121
Re: *Two Birds* - 1992 Bluebird TC2000 - Updated 10/13/14
Been calling all day... finally got a straightforward answer from a guy across the state
Basically, he says fall is the busiest time of the year for these guys. He said the reason nobody likely wants to do it is the shaving involved with the foam. He said it's tedious and in his quote, he gave $400 just for time shaving. He quoted approximately $1660 based on our measurements and said it could be possibly a little more or less. Also, said if we drove to him, he could take off $200-300 (granted, he's two hours away). He gave us a number of a local guy to call first that he does work with, and then said if he doesn't reach me, to call him back.
That works out to approximately the same price as DIY.
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 10-17-2014, 10:57 PM   #122
For the longest time, we researched high and low about our heater. What fuel source, model, etc. In the end, it came down to a Olympian Wave 8 Catalytic Heater and a FATSCO stove (Tiny Tot, PET, and a new, bigger model that I can't remember their name... not on the site yet). FATSCO is nearly local to us, so that was a big contender. In the end, we decided on neither, but rather a vent free, blue flame heater. Procom Thermostatically controlled 10,000 BTU unit to be exact:
http://www.menards.com/main/heating-coo ... c-6867.htm
We decided on this after reading a lot of great reviews and decided we wanted to heat our air rather than radiant heating. It will be put into heating duty shortly after it arrives, to warm the inside of the bus while we continue building in the winter. First comes first though... insulation.
More to come!
WVO Powered!
Old 10-20-2014, 10:51 PM   #123
We got our date booked with a spray foam contractor! It seems most quotes in our area came around $1400-1600, which is cheaper than we could have done it ourselves. Also, I estimated foam board to be about $900 to $1000 to do the whole bus as thick as we wanted.... spray foam was a no brainer for us! Starting the strapping of the walls tomorrow morning. We are excited to see how the next phase turns out.
Also, our heater came in and I picked up some parts for our propane system.
In addition, I made a propane system thread, because I need help with some resources on designing the system and can't find much on the site. Here's the propane thread. Any help is much appreciated!
viewtopic.php?f=11&t=468077
WVO Powered!
Old 10-21-2014, 07:58 AM   #124
r_w
Re: *Two Birds* - 1992 Bluebird TC2000 - Updated 10/20/14
Don't forget to put in a conduit chase or two before you foam, just in case you need to run wires later (like roof vent, solar, extra outlets in the bedroom, whatever).
r_w is offline   Reply With Quote
Old 10-21-2014, 08:48 AM   #125
Thanks for the tip! It was not in my plans. PEX? PVC? Any preferences?
WVO Powered!
Old 10-21-2014, 09:32 AM   #126
r_w
I like pex--one piece, thin wall, and follows the curve of the roof. But it doesn't have junction boxes that fit easily.
Old 10-21-2014, 10:39 AM   #127
Kype's Avatar
Hey guys - fellow Michigander here - I'm loving following your progress here!
Can't wait for the next update!
Wielding the written word as an instrument of change is difficult when you write about fly fishing :)
http://www.examiner.com/fly-fishing-.../brian-cavasin
Kype is offline   Reply With Quote
Old 10-21-2014, 12:59 PM   #128
Coachwork: Startrans
Engine: 5.4 litre
Rated Cap: 12
FYI I had a similar nonvented heater on my porch and it would make the ceiling drip with condensation. The vented unit I used to replace it worked a lot better.
Old 10-22-2014, 07:54 AM   #129
Chassis: B3800 Short bus
Do you know the product name and model # of your vented heater, by any chance? Would it be suitable for a bus?
Old 10-22-2014, 08:17 AM   #130
I'm curious also
WVO Powered!
1992 74 passenger Bluebird for sale in AZ djhonea Classifieds | Buy, Sell, Swap 0 09-26-2014 01:29 PM
1992 BlueBird in Missouri Accordion Classifieds | Buy, Sell, Swap 2 10-31-2012 04:42 PM
1992 BlueBird - Auction ends 10/5 lornaschinske Classifieds | Buy, Sell, Swap 0 09-23-2011 03:28 PM
New guy, building a 1992 TC2000 adamsstreetauto Skoolie Conversion Projects 17 03-24-2010 09:26 AM
Our 1992 B-700 Bluebird project wtom24 Skoolie Conversion Projects 6 11-08-2007 02:44 PM
