Old 04-15-2014, 08:22 PM   #21
Chassis: IH
Engine: 466
Rated Cap: 64
Re: A Bus at Last!!! *Two Birds*
Jeremy- I went and watched some of your YouTube videos when you play the handpan (I still think it looks like a flying saucer- but then what do I know? ) That is a very interesting musical instrument and a very soothing sound! I had never seen or heard one before. It is really cool!
I just undid all the bolts that hold the seats down in my bus yesterday, I am waiting to pick up a trailer that I bought so I can take the seats out of the bus and load them on the trailer to take to the scrap yard. My wife held a wrench on the bolt heads inside the bus, and I was under the bus with an DeWalt cordless impact driver undoing the nuts. It went fairly well and only took about two hours to undo all the nuts off the bolts and pull the bolts out. Luckily my bus has zero rust, so there were no 'issues'! The last bus I removed the seats from required me to grind the heads off the bolts on most of them since they were 'rust welded' to the nuts underneath. That took a long time- what a drag!
Looking forward to more progress on your bus as you go along! A caution- be sure and wear gloves so you don't cut/slice/mash/get a sliver in/ your hands or fingers. (Ask me how I know- since my hands and fingers are sliver
magnets!)
dburt is offline   Reply With Quote
Old 04-15-2014, 10:28 PM   #22
magnets!)
That's how my partner's father and I took out the seats! Me underneath with an impact and him up above with a wrench. Fortunately, we didn't have any issues with rusty bolts. But... there was surface rust under the wood floors from water splashing up from underneath in the bolt holes (I presume) and/or years of wet boots. All surface though with no major issues. I will be taking care of that this week and next as well as laying down a coat of paint over the floor, putting new subfloors down, etc.
Just about to order parts for the veggie oil conversion too!
I am glad you enjoyed the music!!!
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 04-17-2014, 09:12 PM   #23
Scored a massive aluminum tank for the clean WVO today. It was off an ex-military vehicle! Also the rust converter came in so we can start on the floors next week after the weekend festivities! I'll be out of town or I'd get started tomorrow! I have mapped out most of the design of the WVO system too and we will order parts soon!
WVO Powered!
Old 04-19-2014, 10:24 PM   #24
I would like to hear some thoughts. I've been doing lots of reading but having trouble choosing.
The bus will be full time living space in ideally warm places. Our income is mostly location independent so we have the freedoms to follow the sun. The ceiling and walls are completely full of rivets.
To remove the ceiling or not to remove? That is the question! I love the look of tongue and groove planks but could also be happy with carpeting the ceiling like (I think) the brown crown.
Walls?
We were settled on keeping the panels and putting foam board insulation over the walls with wood over top like "Jeremy's conversion project" and then carpeting like the "Brown Crown" but now we aren't so sure!
I'd love to hear your thoughts.
WVO Powered!
Old 04-19-2014, 11:38 PM   #25
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Well,
On my first bus I sealed the roof and walls from the outside and started building inside. I REGRET doing that, but was time limited..... My next bus, a diesel pusher, I'm removing ALL of the over-head and side wall panels, and reworking the skin to be water tight from the INSIDE. More work, but well worth the effort!!!! Reinsulating with a higher quality insulation (pondering sprayed-in foam now) is SO worth it!!!! No matter the climate, a GREAT insulation barrier will always cut down on your need to use energy to keep warm/cool no matter where you are. My next project will be starting in about two years or so when they retire the bus I'm now driving.
My two cents... For what it's worth.
M1031
M1031 is offline   Reply With Quote
Old 04-20-2014, 06:41 PM   #26
Well... My girlfriends uncle just gave us 10 full sheets of 2" thick foam board insulation. It think that means it's time to start pulling panels. I can't pick it up til next week as he is a ways away from us.
Nat_ster... I know you have recommended a chisel with a hand guard and 4 lb hammer. But... I have access to an angle grinder and also air compressor... I don't know anyone that has an air hammer though. So... What's the verdict on busting ceiling and wall panel rivets? What's going to be the most efficient method?
WVO Powered!
Old 04-20-2014, 06:54 PM   #27
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
There are many ways to bust rivets. Remember sparks ruin the windows in the bus.
I opted to drill mine out with a nice titanium dewalt drill bit. You have to get the
remnants off the bit, but no sparks.
just my .02
-Doc
My build thread - viewtopic.php?f=9&t=467197
Old 04-20-2014, 08:34 PM   #28
Wow! Air chisel
Found this on youtube...
WVO Powered!
Old 04-21-2014, 04:18 PM   #29
Picked up an air hammer and chisel today. The demolition starts tomorrow
A question arose in my mind today... where do you guys attach interior wall paneling once the metal skin is off the inner wall? The support ribs?
Also, many conversions I have seen where they attach cabinetry to the ceiling panels. I really like this look for the bus. But... if I remove the ceiling panels, what would be the best place to attach overhead cabinets to that would hold up to the rigors of driving down the road?
WVO Powered!
Old 04-21-2014, 08:50 PM   #30
Chassis: AmTran
Re: *Two Birds* - 1992 Bluebird TC2000
White~ I am eager to hear more of your WVO part of this build. Your questions are good. I have had the same thoughts and questions. I still have variations on those questions! I find it somewhat difficult to find answers to some specific questions I have. I usually have to vary my search keywords many, many times and SIFT through loads of threads. And, more than once, I finally found what I was looking for, but only when I intentionally misspelled something the way I thought others might!! LOL I have given up and posted a query to the masses when my searching brought back zilch. One thing that may help you, that I do, is copy and paste different ways to do parts of the build and email it to myself with that build part as the subject. You could also create a Pin board for ideas for your build on Pinterest.
This is one that has ideas or ways of doing the build that I liked: http://www.pinterest.com/mamapotato/...rv-conversion/
This is one that has all the builds I though were most helpful for me to refer back to: http://www.pinterest.com/mamapotato/...-photostreams/
Nat ~ Come on man, don't be grumpy, just give the man a link to the thread. We ALL need help! It was only a few days ago after all.
Conversion Thread:
viewtopic.php?f=9&t=467377
scgwagner is offline   Reply With Quote
1992 74 passenger Bluebird for sale in AZ djhonea Classifieds | Buy, Sell, Swap 0 09-26-2014 01:29 PM
1992 BlueBird in Missouri Accordion Classifieds | Buy, Sell, Swap 2 10-31-2012 04:42 PM
1992 BlueBird - Auction ends 10/5 lornaschinske Classifieds | Buy, Sell, Swap 0 09-23-2011 03:28 PM
New guy, building a 1992 TC2000 adamsstreetauto Skoolie Conversion Projects 17 03-24-2010 09:26 AM
Our 1992 B-700 Bluebird project wtom24 Skoolie Conversion Projects 6 11-08-2007 02:44 PM
