Old 05-06-2014, 10:21 PM   #41
PDBreske's Avatar
Rated Cap: 1
Re: *Two Birds* - 1992 Bluebird TC2000
Good job on the sponsorship!
Read about the "Camel" RV Conversion project!
My first passion is photography. Visit my website to see some of my work.
Old 05-06-2014, 10:56 PM   #42
Thanks! We are excited about it. It will really help us with our build
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 05-06-2014, 11:02 PM   #43
I am headed out again for a weekend of gigs in Kentucky, but when I get back next week, we will begin prepping the bus to skin over the windows. We decided to skin over the back 7 windows on each side, and eventually cut in Emergency Exit RV windows into the bedroom.
At the same time we begin to rivet in the metal skins, I will re-rivet the chair rail rivets that I busted out. I'm still upset about that one Live and learn!
Speaking of learning, installing the window skins will be the first time I have ever done anything of that type. I am sure I will have lots of questions when the time comes!
WVO Powered!
Old 05-07-2014, 01:47 PM   #44
Our veggie conversion parts arrived today!
WVO Powered!
Old 05-07-2014, 02:57 PM   #45
Kewl! --- I had no idea all you needed were a coupl'a cardboard boxes and some hose or I would'a looked into it sooner.
Old 05-07-2014, 04:10 PM   #46
I ordered manual valves separately. I still have to pick up fuel line, coolant hose, and fittings locally. Other than that, I think I am all set. Those boxes contain a centrifuge for filtering the oil and a transfer pump to get it from the bin to the bus. That hose is a PVC suction hose to transfer it from the bin to the bus. It also contains some parts for the veggie setup such as a heated fuel filter assembly, flat plate heat exchanger, and a coolant-heated tank heater/fuel sucker. I'll do a whole post on the setup once it's all said and done!
WVO Powered!
Old 05-07-2014, 06:54 PM   #47
eyedeal.ink's Avatar
We're definitely interested in your veggie conversion, please post lots of pics. Jealous on the spray foam thing, that's what I wanted in the first place but we decided not to remove the ceiling panels and just insulate under our roof rack, spray foam is probably the best you can do, especially if you add the thermal break to your ribs before reattaching your ceiling metal (if that was your plan). Lookin good.
"That's,. like,.. your opinion, man...." - the Dude.
eyedeal.ink is offline   Reply With Quote
Old 05-07-2014, 07:36 PM   #48
We won't be reattaching the ceiling metal... it's already at the scrap yard! We will either be doing wood paneling or some "Duraplate", which is what Wabash puts on the side of their semi-trailers.
I'll take lots of conversion pics too!
WVO Powered!
Old 05-07-2014, 08:51 PM   #49
kenny76's Avatar
I worked at Great Dane for several years building trailers. My job was to rivit up the first and last rows of rivits where the radius meets the body and the area where the body meets the rear frame. In my time there I also worked on their refer line. The trailers are insulated with a two part expanding foam made by BASF. I hope to get my hands on a porta pak that we used to touch up the foam when the interior fiberglass liner had to be removed. This would work great for insulating my bus. As for your duraplate idea, if I am not mistaken duraplate is a 1/2 or 3/4 inch thick aluminum sheeting. I dont think that would work well.
Not all those who wander are lost.
kenny76 is offline   Reply With Quote
Old 05-07-2014, 11:20 PM   #50
I have a friend that works there. He tells me it is two layers of sheet-metal sandwiched around a plastic core. There are a lot of different sizes and it goes down to a pretty thin size that is very flexible. He is sending me samples in the mail to be sure. He says there is a thin enough application that it could curve around the ceiling. Time will tell!
WVO Powered!
1992 74 passenger Bluebird for sale in AZ djhonea Classifieds | Buy, Sell, Swap 0 09-26-2014 01:29 PM
1992 BlueBird in Missouri Accordion Classifieds | Buy, Sell, Swap 2 10-31-2012 04:42 PM
1992 BlueBird - Auction ends 10/5 lornaschinske Classifieds | Buy, Sell, Swap 0 09-23-2011 03:28 PM
New guy, building a 1992 TC2000 adamsstreetauto Skoolie Conversion Projects 17 03-24-2010 09:26 AM
Our 1992 B-700 Bluebird project wtom24 Skoolie Conversion Projects 6 11-08-2007 02:44 PM
