Old 05-21-2016, 01:59 PM   #31
Coachwork: tc2000
Chassis: blue bird
Engine: cummings 5.9
You can see here, that some of the og walls are still up and you may find some of that inconsistancy throughout as I have a tendency to get to dead ends, where I need to do one thing, before I do the next, so I found myself jumping around a little.
If I ever do another bus, I'm sure I can streamline it white a bit.
I still have not moved that dang. heater. The long hoses are just thrown around the drivers seat....
scootie is offline   Reply With Quote
Old 05-21-2016, 02:03 PM   #32
Coachwork: tc2000
Chassis: blue bird
that VW Caddy is pretty crazy looking. Like a mini Transit. what makes you want one of those to tow? are they manual transmission?
Old 05-21-2016, 03:23 PM   #33
Robin97396's Avatar
What people are doing with the Caddy is taking out the old rabbit engine and replacing it with a current VW engine. Touted at an easy 45 mpg. It's pretty small for anyone 6' or better, but I know people here over 6' that swear by them. I think they're about $5k with a good body and an engine swap. The newer engines have considerably more power. It's just that a truck is needed sometimes, and this almost qualifies. It's a rabbit with a bed on the back.
Old 05-21-2016, 03:25 PM   #34
Robin97396's Avatar
Yes they are lightweight. You can get them fixed up with whatever you want in them depending on your engine/transmission replacement package. I don't know if VW still does a lot of sticks or not. I think most of the more modern VWs are probably automatic. Next best thing to a go cart, but legal on the road.
Old 05-21-2016, 05:50 PM   #35
Coachwork: tc2000
Chassis: blue bird
oh, you are talking about the VW rabbit truck when you say "caddy"
I never heard it called that, so I googled it, and there are alot of new vans called the caddy not in the us.
Yes. I would love a rabbit truck. there are a few good ones in ATL for sale right now. check it out.
80"S VW RABBIT DIESEL PICKUPS
Old 05-21-2016, 08:46 PM   #36
Robin97396's Avatar
Nice. That's a better price than this area. Yeah, that's the right truck, and it's so lightweight you probably wouldn't know you're towing it.
There really isn't much information on these. I have to assume those are the original engines and they usually have really high miles. Still needs a transplant. Drop a 2.2, I think, in there and I hear they're kind of squirly.
Old 05-23-2016, 08:11 AM   #37
Coachwork: tc2000
Chassis: blue bird
I'm sure it's way cheaper than Oregon. I lived in Portland for a number of years, and upon leaving I bought a s10 and drove to GA where I now live. Quickly found out Supply and demand in a real life way.
I've since thought it would be a great way to travel and make money. ie, buy a car thats cheap in one area, and drive it to an area that has a high demand for it and slap it on CL for a profit...
for instance, my opinion is those trucks probably have lower mileage, thats a farm town, and he is obvious a collector. If someone could snag one for say 3200 and drive it to SO CAL, I'm sure it would retail for 6-7-8k
Buy a beater VW bus say out there, and drive it back, and it's worth a fortune here, b/c the only ones here are really crappy. Even the bad ones in So Cal are Awesome out here.
Incase any of you guys are creative and have more time than me.
If you really know cars, and have some buy in cash, I think it would be fun.
Old 05-23-2016, 08:25 AM   #38
Coachwork: IC
Chassis: CE300
Rated Cap: 32
VW buses used to be fun. You could score a runner for $500.
I don't see the appeal these days though. Sure, they're funky and cool. But not at all worth the prices I've been seeing locally.
I remember when my complete, running 67 westy was hard to get rid of at an asking price of $800 due to some rust. I didn't wanna get rid of it, but you know how parents are when you're in high school and accumulating old cars.
Roll Your Own Build Thread
Old 05-23-2016, 08:49 AM   #39
Coachwork: tc2000
Chassis: blue bird
roof rack deck
ok, so next comes the roof rack/deck
I really wanted a couple of things and was not able to find much advice for the type of rack that I wanted.
-I know that Kayaks will be up there,
-I know that I wanted it to be streamline and kind of fit that profile of the safari racks of the VW Bus.
-as strong as I could build it
- no side mount through the ribs. (That is the type in which you bolt through the side of the bus with verticals then build across), I felt this would add to road noise and although tough looking, I wanted something sleek, where I think the side mount bars look more like the zombie apocalypse refuge vehicle, Or Mad Max style build.
-finally I did have fuel mileage somewhere in the back of my mind. So I wanted it close to the roof as I could.
Here is the framing start.
if it's not clear, What I did here is (once the interior ceiling was removed), I put the largest structural L brackets I could find on each of the ribs and through bolted them.
*structural brackets not standard, galvanized
I think they were 3/8" thick by 6" or 8" and about 10-12$ ea. (outch)
I thin I used 10 or 12 total.
then you can see, I've got my 2x10 on each side with the brackets inside them.
through bolt the 2x10 with 3/8 galvanized blots, nuts washers.
Then tie them together with 2x4's and wood glue. At this point it's important to remember what holds what together, ond once you think about that you should agree that it's worth the $$ to pre drill pilot holes, and buy "timber lock" 10" lag bolts and tie the rafters together that way. again with wood glue.
also you will see the strongtie brand joist hangers. those are always good, but in this case I used them to enable me to run screws through towards the outside wrap sucking everything together tight and square. b/c I was building this by myself.
Although, I had my dad come by and help me tighten the bolts through the ribs first. this requires two people. It's the first time I've had any help with my bus!!
Old 05-23-2016, 09:32 AM   #40
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Thumbs up
Looks great
Love the idea of a roof rack, I just dread doing it myself, as i'm not sure i'll be able to seal it properly :/
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
