Old 11-04-2018, 12:21 PM   #31
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
Front divider
Got all the seats out finally. 🤗
Should I leave the front divider in place or remove it?
I have a IC Fe300. I see some Bluebird builds have a structural tie in connected to the front divider. Any known issues if I take these out?
File Type: jpg AE048D78-E6AD-4107-A93E-5490B969D3AB.jpg (191.8 KB, 17 views)
File Type: jpg 21B545CA-6652-44A1-8185-2EA1FE0F3008.jpg (221.8 KB, 16 views)
File Type: jpg EC390CC7-E0C8-44C0-B14B-647227AAD9E2.jpg (193.7 KB, 13 views)
CMORGANSKOOL is offline   Reply With Quote
Old 11-09-2018, 02:31 PM   #32
Coachwork: IC
Chassis: FE Bus
Progress
All the seats are scrapped. Started taking the plywood subfloor out. Itís screwed to the sheet metal but itís pretty spongy so I think a pry bar and some time will get the job done. Floor looks pretty solid underneath.
File Type: jpg ECE28874-B920-407F-AA32-617614F43B0C.jpg (246.5 KB, 12 views)
File Type: jpg C0523F99-C470-4E26-980C-F1FC6A9E0681.jpg (278.5 KB, 12 views)
Old 12-14-2018, 01:01 PM   #33
Coachwork: IC
Chassis: FE Bus
Floor Help
Iím stuck at the subfloor. First piece popped right up with a pry bar. I only have a couple hours a week to work on the build so donít laugh at my next statement. Iíve been trying to pry up the second piece of plywood for three weeks. I cut the screw heads off and everything. Itís not glued down. Itís just magically attached at this point and wonít budge. Should I cut it? Whatís the opinion of the experienced group?
Old 12-14-2018, 01:03 PM   #34
I'd set a circular saw at jsut a hare short of the thickness of the plywood. Makes some cuts, pry out the old stuff.
Roll Your Own Build Thread
Old 12-14-2018, 01:40 PM   #35
Originally Posted by CMORGANSKOOL View Post
I’m stuck at the subfloor. First piece popped right up with a pry bar. I only have a couple hours a week to work on the build so don’t laugh at my next statement. I’ve been trying to pry up the second piece of plywood for three weeks. I cut the screw heads off and everything. It’s not glued down. It’s just magically attached at this point and won’t budge. Should I cut it? What’s the opinion of the experienced group?
I BATTLED with mine.
I started with a 30" crowbar and a circular saw. I sectioned a portion up with the saw and the tried to pull it out with the crowbar. Ha Ha....
A buddy came by with two 4' long bars with a claw hammer looking end.
We found that not cutting the plywood worked best for us. He would pry a corner up and I would slide my bar in and pry then he moved ahead of me and did the same. Repeat as needed.
I spent 8+ hours solo and made a small dent. The two of us working together finished the job in less than two hours.
Old 03-10-2019, 04:04 PM   #36
Coachwork: IC
Chassis: FE Bus
Progress
Finally making some progress on the floors. Still have to re calk the windows. Have a couple leaks.
File Type: jpg BC16F085-4652-47E5-8C5F-E681BD2ED80F.jpg (292.4 KB, 14 views)
Old 04-07-2019, 04:35 PM   #37
Coachwork: IC
Chassis: FE Bus
Floor
Itís been a long time coming but I got 99% of the plywood up and the ospho sprayed on all the rust. No major areas of concern as far as rust too so thatís good. Btw the ospho is absolutely awesome. Wish I had known about it before. Put it in a pump up big sprayer. Works on everything thatís rusty.
File Type: jpg 45D179D6-56BA-495B-A21C-BC668F9BCA16.jpg (346.8 KB, 12 views)
Old 04-23-2019, 10:43 AM   #38
Coachwork: IC
Chassis: FE Bus
Storage tanks
Got a few barrels from facebook market place.
Old 04-23-2019, 10:46 AM   #39
Coachwork: IC
Chassis: FE Bus
New parking spot
$100/mo at the storage lot right up the street from my house. #score!!
Old 04-25-2019, 07:16 PM   #40
Coachwork: IC
Chassis: FE Bus
Hereís some fresh build photos
cmorganskool, new build, new bus
