Old 09-30-2018, 03:16 PM   #21
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
I didn’t peel the second side off. Thanks. Now they’re crystal clear.
CMORGANSKOOL is offline   Reply With Quote
Old 09-30-2018, 04:33 PM   #22
Originally Posted by CMORGANSKOOL View Post
My doors are just rectangular glass. I’d imagine you can get safety glass cut to size anywhere. I think the trouble comes when looking for rounded corners or curved glass.
I need a rear door, nothing related to glass.
Old 10-06-2018, 03:49 PM   #23
Coachwork: IC
Chassis: FE Bus
Broken windows
Kids broke my emergency exit window and the plexiglass door windows again. Caught them this time but they fled before the police came. I parked it at the car lot I work at for a couple days while I repair it. I have to figure out a way to make it break proof and break in proof for the city.
Old 10-06-2018, 03:55 PM   #24
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Actually, any reputable automotive glass shop should be able to fab replacements for you.
Have you considered installing flattened expanded metal covers or perhaps some bar stock over the windows?
Old 10-06-2018, 07:50 PM   #25
First thing my granny said when I got my first bus was "the little hoodlum kids will break all the windows out in no time if you park it in town".
Old 10-06-2018, 07:54 PM   #26
Coachwork: IC
Chassis: FE Bus
I’m going to cover it in chicken wire, cameras and spikes. We’ll see who wins this battle 😶
Old 10-06-2018, 08:22 PM   #27
Coachwork: IC
Chassis: FE Bus
In other news got my Pa title back converted to Motorhome.
Old 10-10-2018, 05:28 PM   #28
sportyrick's Avatar
Chassis: F33695
Their mom and dad will pay if you work it right, you saw them didn't you?
Old 10-10-2018, 06:59 PM   #29
Coachwork: IC
Chassis: FE Bus
I saw them. Just haven tracked down where they live yet. The captain of the police district has lent his help. We’re going to get to the bottom of this.
Old 10-28-2018, 12:21 PM   #30
Coachwork: IC
Chassis: FE Bus
Some progress finally
Got 3/4 of the seats out so far after having some setbacks with the water pump replacement and vandalism.
Old 11-04-2018, 12:21 PM   #31
Coachwork: IC
Chassis: FE Bus
Front divider
Got all the seats out finally. 🤗
Should I leave the front divider in place or remove it?
I have a IC Fe300. I see some Bluebird builds have a structural tie in connected to the front divider. Any known issues if I take these out?
AE048D78-E6AD-4107-A93E-5490B969D3AB.jpg   21B545CA-6652-44A1-8185-2EA1FE0F3008.jpg   EC390CC7-E0C8-44C0-B14B-647227AAD9E2.jpg
Old 11-09-2018, 02:31 PM   #32
Coachwork: IC
Chassis: FE Bus
Progress
All the seats are scrapped. Started taking the plywood subfloor out. It’s screwed to the sheet metal but it’s pretty spongy so I think a pry bar and some time will get the job done. Floor looks pretty solid underneath.
ECE28874-B920-407F-AA32-617614F43B0C.jpg   C0523F99-C470-4E26-980C-F1FC6A9E0681.jpg
Old 12-14-2018, 01:01 PM   #33
Coachwork: IC
Chassis: FE Bus
Floor Help
I’m stuck at the subfloor. First piece popped right up with a pry bar. I only have a couple hours a week to work on the build so don’t laugh at my next statement. I’ve been trying to pry up the second piece of plywood for three weeks. I cut the screw heads off and everything. It’s not glued down. It’s just magically attached at this point and won’t budge. Should I cut it? What’s the opinion of the experienced group?
0265157A-656F-4A65-94EC-87895F268D90.jpg   7AB42503-BE96-494B-BC25-59D6E4FEE521.jpg   6082AC52-1F00-4B48-92E6-C2CB4309BDF3.jpg   730EE420-43C7-45EB-A12C-38375C330EFE.jpg   E5C109C8-486B-4AC9-A06D-68052E5A869C.jpg
Old 12-14-2018, 01:03 PM   #34
I'd set a circular saw at jsut a hare short of the thickness of the plywood. Makes some cuts, pry out the old stuff.
Old 12-14-2018, 01:40 PM   #35
I BATTLED with mine.
I started with a 30" crowbar and a circular saw. I sectioned a portion up with the saw and the tried to pull it out with the crowbar. Ha Ha....
A buddy came by with two 4' long bars with a claw hammer looking end.
We found that not cutting the plywood worked best for us. He would pry a corner up and I would slide my bar in and pry then he moved ahead of me and did the same. Repeat as needed.
I spent 8+ hours solo and made a small dent. The two of us working together finished the job in less than two hours.
Old 03-10-2019, 04:04 PM   #36
Coachwork: IC
Chassis: FE Bus
Progress
Finally making some progress on the floors. Still have to re calk the windows. Have a couple leaks.
Old 04-07-2019, 04:35 PM   #37
Coachwork: IC
Chassis: FE Bus
Floor
It’s been a long time coming but I got 99% of the plywood up and the ospho sprayed on all the rust. No major areas of concern as far as rust too so that’s good. Btw the ospho is absolutely awesome. Wish I had known about it before. Put it in a pump up big sprayer. Works on everything that’s rusty.
Old 04-23-2019, 10:43 AM   #38
Coachwork: IC
Chassis: FE Bus
Storage tanks
Got a few barrels from facebook market place.
Old 04-23-2019, 10:46 AM   #39
Coachwork: IC
Chassis: FE Bus
New parking spot
$100/mo at the storage lot right up the street from my house. #score!!
Old 04-25-2019, 07:16 PM   #40
Coachwork: IC
Chassis: FE Bus
Here’s some fresh build photos
C43B8D24-8B08-4F69-9A5A-33662230ABF9.jpg   8D509497-E285-4959-9214-3DD707B38DF9.jpg   8D13A944-B277-4944-9D9F-9D4C6CEB0457.jpg   51D57565-2401-49CC-8E06-DD96012DCEB4.jpg   C4D4F158-BFA7-4145-97AE-28BE0F9CAF4B.jpg
5F7CC6FE-D9DF-4BEA-96A5-04CF512EE379.jpg   84002A98-904A-40FE-B69D-E1AEFB80D19B.jpg   BD200891-DCDF-4D37-AA8B-D89892FB7F4A.jpg
cmorganskool, new build, new bus
