Old 03-04-2018, 07:53 PM   #1
Coachwork: international
Chassis: blue bird t444e 6 window at545
Engine: 7.3 international
warren and kim and the Burley bus
we bought our bus today,will be getting insurance and tags this week already titled as an motorhome hope all goes well:grin
Let the build begin
2000 t444e / 545 6 window
P.S. any suggestions on Insurance in michigan
burley bus is offline   Reply With Quote
Old 03-04-2018, 09:51 PM   #2
Robin97396's Avatar
Welcome
Congratulations on your new project. Is that a leopard paintjob?
Robin
Nobody's Business
Old 03-04-2018, 09:58 PM   #3
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
Welcome to the collective of free spirits who choose not to live in debt but experience life to the fullest!
Namaste
- Thomas
The Daily Driver Bus Build
Thomas1985 is offline   Reply With Quote
Old 03-25-2018, 10:14 PM   #4
robin 97396 jaguar paint job has to go
Old 03-25-2018, 10:25 PM   #5
so it begins
been getting some work done on the bus its in pretty good shape
20180309_160540.jpg   20180313_160236.jpg   20180315_135229.jpg   20180317_141000.jpg   20180323_171457.jpg
Old 03-26-2018, 11:30 AM   #6
Cool where you at in sw Michigan?
I am by niles
Seriousracer is offline   Reply With Quote
Old 03-30-2018, 10:46 PM   #7
I am by niles
Im over by cabelas dundee monroe area
Old 03-30-2018, 11:22 PM   #8
Not to far dad lives in sturgis.
I will have to bring the toter bus over
Old 03-30-2018, 11:29 PM   #9
got some more work done on Burley today I HATE RIVETS
It wasn't bad the way i did it is I knocked the center metal pin through the rivet and then used a rolled chisel in my air hammer started steep with the chisel and once under the head just rolled the chisel to lift and shear the rivet took about 10 minutes first panel and about 20 min for each additional row not as young as I once was.
decided Im going to do a roof raise only going to go about a foot or so maybee 15 inches want to stay under 12'4" need a little more height because there is going to be a bed in the rear that will raise up into the ceiling when not in use and also I'm going to loose about 4-5 inches for insulation.
I have a question has anybody ever put a 2 ton suspension under a short bus or even a one ton rear axle and front axle I would love to make this 4x4.
I HATE RIVETS PS, how can I make my pics come out right side up
thanks
20180329_121101.jpg   20180330_180502.jpg   20180330_180528.jpg   20180330_184654.jpg
Old 03-30-2018, 11:31 PM   #10
toter bus got a picture?
Old 03-31-2018, 07:59 AM   #11
BurlKing's Avatar
Year: 92
Engine: DTA360 5.9L
thanks
great bus and good plans you have! i raised 16 inches and im around 11' height.
for the sideways pics, if you are using your phone to take them make sure the auto-rotate is off and your phone is orientated correctly. if the problem is on your pc, open the picture in paint (if you have windows) then click the rotate button, which should be by the resize button and then just save the picture. hope any of that helps.
BurlKing is offline   Reply With Quote
Old 03-31-2018, 01:37 PM   #12
Yeh I have part of the build on here.
There are some Rockwell axles floating around in the area along with there is a an old tree trimming 4x4 chassis 25k gvw truck I can think of. 1ton stuff would be marginal. Even f550 19k maybe marginal.
Old 03-31-2018, 07:59 PM   #13
even for a 6 window
Old 03-31-2018, 09:09 PM   #14
Originally Posted by Robin97396 View Post
Welcome
Did you miss the upper light panel in the pic?
Old 04-01-2018, 09:28 PM   #15
even for a 6 window
Well I would take the bus down to the local grain co-op and weigh it. Before and after you get done converting it.
Than find axles that are up to the weight of the finished bus. It would suck to have a failure while driving. You also need to see if rims and tires are available to handle the weight Just my opinion.
