Probably not the intended use, but I found a spool of this stuff in the dumpster at work a while back...
GORE® Joint Sealant
I have wondered if it would work for window sealing around the bottom, but I think it's meant more for higher pressure seals, not the more loose fit of a window where butyl caulk tape seems to be the go-to stuff.
