Old 08-03-2014, 02:52 PM   #41
Coachwork: blue bird
Chassis: International, 3000, Blue Bird
Engine: Dt360
Rated Cap: 25000
Re: wheelchair bus for my wife
painted the floor now I can install the 3/4 plywood, 3/4 insulation and paper
Looking for that happy place, I've got a home on wheels and I'm going to find it.
Better Tomorrows is offline   Reply With Quote
Old 08-03-2014, 02:53 PM   #42
Engine: Dt360
Rated Cap: 25000
the paper goes down first, feels like I am making headway now!!!!!
Old 08-03-2014, 02:55 PM   #43
Engine: Dt360
Rated Cap: 25000
My shade tree workshop next to the bus
Old 08-03-2014, 02:58 PM   #44
Engine: Dt360
Rated Cap: 25000
painted the panel over the windows copper as well as the heater and dashboard, all my neighbors like the color
Old 08-03-2014, 03:02 PM   #45
Engine: Dt360
Rated Cap: 25000
made a lillte box of wood to hold the TV stained it a semi-transparent color called woodland green form Homedepot
Old 08-03-2014, 03:06 PM   #46
Engine: Dt360
Rated Cap: 25000
another wood box too, and a new fan for Shelby as we ride down the road...have to take more pics of the other things I have been up to reinstalled all the windows...things a going good these last few week...this is so much FUN!!!!!
Old 08-03-2014, 03:31 PM   #47
browncrown's Avatar
Rated Cap: 79 at Birth
Looking good on the progress!!!
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 08-03-2014, 03:46 PM   #48
Engine: Dt360
Rated Cap: 25000
Thanks, it is slow going some times with Shelby in the wheelchair, but I keep saying to myself if I can do a little each day I will get it done.
Old 08-03-2014, 05:11 PM   #49
browncrown's Avatar
You will get it done...keep going...all of us here are wishing you success
BC
Old 08-03-2014, 05:11 PM   #50
browncrown's Avatar
BC
Old 08-03-2014, 09:04 PM   #51
Location: Alachua County, Florida until we get out of there
My wife is also in a wheelchair, and we are looking at basically the same bus you have. Sooo....
I wanna aska buncha questionsa abouta your bus. Pluuuuueeeeesssseeee????
First, how long is the passenger compartment from in front of the lift to the metal kid-stopping bars?
How wide is the wheelchair door?
You and yours are sooo lucky! Major case of bus-jealousy here.
Looking forward to watching your build as we design our future home away from.
Thanks.
abwetzel63 is offline   Reply With Quote
Old 08-04-2014, 10:16 AM   #52
Engine: Dt360
Rated Cap: 25000
Thanks.
Analyzed63
The area for the wheelchair in front of the lift is 4x6 this puts her just behind the drivers seat next to the lift with space for me to walk through to get to the back of the chair and lock it down.
The wheelchair door is 39 inches wide, the life gate/floor is 29 inches wide.
The length of the bus from the back door to the lift is 17'5 feet. Total inside feet 25 feet. That gives me 22 feet of living space, to the drivers seat.
I plan on using some sort of Murphy bed systems for the two twin beds along the passenger side of the bus, this will allow me to us the hoyer lift to get her into and out of the bed and wheelchair. And by being able to fold the bed out of the way she will have more room to more her chair.
I am going to place the kitchen in the rear of the bus on the drivers side, from the back window to and over the wheel well. I will place the sink at the back door and window have 30 inches of counter top, under which will go the mine clothes washer/dryer, next step burner stove top, then atop the wheel well a small refrigerator with cabinets above, on the face of the wheel will go the wood stove.
As I said I will place the two murphy bed on the passenger side of the bus starting with the bed for my wife this will give lots of floor space to move her hoyer around. Then my bed followed by a small closet for clothes and at the back a compost toilet across from the sink at the back door.
I live in Valdosta Georgia, about 2 hour from you. If I can help let me know.
Old 08-04-2014, 04:32 PM   #53
Wow, sounds like you have the perfect bus. Totally cool.
I am going to get a rear door bus (when I get the scratch together) so I can put the primary bed up front on the passenger side behind the front door. My wife's back is so bad the doctor has her on mostly bed-rest for the support. Sitting up just kills her, no type or amount of padding helps, still waiting for artificial gravity...
Hopefully will be buying by November, and if I need help, I'll holler at/for you. Thanks for the offer.
Can't wait to see the floor plan and more construction pictures (You can just hear Das Mel hollering "More Pictures!!" right now, can't you?)
Good luck, and good livin.
Old 02-24-2015, 01:29 AM   #54
hi...
last year i also converse my van,she is permanent in wheelchair.There is a ramp to the left side of the van from where wheelchair can easily enter into the van...
cooperwood is offline   Reply With Quote
Old 02-24-2015, 06:09 AM   #55
There was a wheelchair bus conversion for sale here in FL.
The guy even had the drivers seat removed and had the bus setup to drive from a small joystick.
Pretty cool.
Old 06-11-2015, 04:47 PM   #56
Engine: Dt360
Rated Cap: 25000
I have been hard at work, have had computer problems, haha, my life... here are a lot of photos, I may only get one shot at posting what I have done so far... so here we go
Old 06-11-2015, 04:49 PM   #57
Engine: Dt360
Rated Cap: 25000
more of the flooring 3/4 over 3/4 foam insulation the pink stuff
Old 06-11-2015, 04:52 PM   #58
Engine: Dt360
Rated Cap: 25000
side wall 1 1/2 of foam
Old 06-11-2015, 04:54 PM   #59
Engine: Dt360
Rated Cap: 25000
I installed a closet in the 32 inch window I closed with a sheet of steel
Old 06-11-2015, 04:55 PM   #60
Engine: Dt360
Rated Cap: 25000
over the wheel we go
How did you get the wife/GF on board? Diesel Dan Everything Else | General Skoolie Discussions 26 02-17-2016 09:16 PM
If my wife would let me.... RavensOracle Classifieds | Buy, Sell, Swap 5 02-19-2012 09:20 PM
wife familyfun Conversion General Discussions 6 02-08-2010 12:27 PM
wife says do the veggie Train-train Alternative Fuels | Electric, Propane, Wood & Biofuels 2 03-22-2008 03:18 PM
Wife Swap on ABC Steve Everything Else | General Skoolie Discussions 2 02-17-2005 11:19 AM
