Old 06-15-2011, 12:19 AM   #11
MikeyBskunk's Avatar
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Re: Wild Blue
WOW you guys are zipping along! once you replace the floors you have smooth sailing!
MikeyBskunk is offline   Reply With Quote
Old 06-15-2011, 06:54 AM   #12
browncrown's Avatar
Rated Cap: 79 at Birth
Re: Wild Blue
Your window coverings look very nice!!
BC
Old 06-15-2011, 08:34 AM   #13
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Wild Blue
Agreed! Well done.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-15-2011, 01:34 PM   #14
Re: Wild Blue
so neat to be able to see your progress! Looks like you 2 are really getting a lot done! I'm actually pretty jealous looks like a lot of work but man it looks like fun! Can't wait to have you drive it out here and come visit . Anyways ill be watching your progress on here! goodluck! can't wait to watch it all come together! Luv ur sister
duckleswhite is offline   Reply With Quote
Old 06-27-2011, 11:27 AM   #15
Coachwork: Ford
Chassis: Carpenter
Re: Wild Blue
Looks great!!!!! nice job, the hard part is done!
Old 06-29-2011, 06:18 PM   #16
browncrown's Avatar
Re: Wild Blue
Beautiful job on the flooring
BC
Old 07-12-2011, 09:12 AM   #17
Re: Wild Blue
Excellent progress! And a very elegant solution to the old problem of fitting to a curved roof. Should make applying the ceiling material a breeze. Nice work!
Old 07-12-2011, 10:11 AM   #18
Re: Wild Blue
Are you concerned at all about condensation forming behind those foil backed panels? Is there a gap between the insulation panels and metal skin of the bus? I'm not sure, maybe someone else can weigh in on that... just something I'd keep an eye on before putting the walls on. Run some tests of having exterior/interior temperature differences to see if any condensation develops. You don't want mold/rust/wiring problems/etc. in there. Also any gaps inbetween the insulation panels reduces the R-value of the entire wall, so perhaps consider foam filler (cans of spray foam) for the gaps? The other thing is, don't try too hard to air-seal the bus up (like caulking all the windows 100%, tight fitting door, etc.) if you plan to use a woodstove or other combustion appliance, due to CO concerns (even if they are properly vented).
I hope to get a bus similar to yours ASAP, so I'm trying to think out all this stuff as well. I'm starting to think insulation is the most important consideration of the entire project. Anyway, good progress! Keep posting lots of pictures!
-Luke
Lucas is offline   Reply With Quote
Old 07-12-2011, 10:32 AM   #19
syke's Avatar
Chassis: All American RE
Re: Wild Blue
Moving right along. Looks great!
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 07-12-2011, 02:27 PM   #20
browncrown's Avatar
Re: Wild Blue
Great ceiling work! The more insulation up there the better.
BC
the wild blue yonder atcc77 Skoolie Conversion Projects 161 08-09-2014 05:16 PM
How wild is your A/V setup? NewSkewlHauler Conversion General Discussions 16 07-06-2010 01:13 PM
Into The Wild (The Movie) josetann Everything Else | General Skoolie Discussions 6 08-08-2009 09:44 PM
Question for Wild Goose Davilance Conversion General Discussions 0 11-25-2006 08:39 PM
The Wild Goose ? soused moose Everything Else | General Skoolie Discussions 1 01-21-2004 08:37 AM
