Old 02-18-2013, 11:22 PM   #61
Accordion's Avatar
Year: 1973
Engine: CAT 1160 V-8 Diesel
Re: Wild Blue
Beautiful job on your bus. The ceiling is awesome. I wish I would have done wood instead of carpet.
Old 02-19-2013, 03:11 AM   #62
Year: 1974
Engine: Detroit Diesel 6-71
Re: Wild Blue
Amazing bus!!!
Thank you for sharing your story, tips and solar info! I've been reading up on solar systems and I know we need it but I'm usually just scratching my head about it. Many thanks for the translation haha.
My question is do you remember the inner dimensions of your bus before your conversion and after? Did you lose a lot of living space with the insulation? When we get our bus, insulating is a high priority as we have family in MA and plan on spending time journeying across some of the Northern states, some of which will probably be during winter.
Again kudos on your bus, it looks line a great place to live!
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
Old 02-28-2013, 05:20 PM   #63
browncrown's Avatar
Rated Cap: 79 at Birth
Re: Wild Blue
Wild Blue, those cabinets are beautiful...really like your design work
BC
My Conversion Thread: https://www.skoolie.net/forum/viewtopic.php?f=9&t=3065
Old 02-28-2013, 05:31 PM   #64
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Wild Blue
All I can say is also wow! If you ever need another bus to work on, let me know. Mine sure needs some of your cabinetry magic.
Old 02-28-2013, 08:09 PM   #65
Re: Wild Blue
Great job!!!, a lot of inspiration.... I can't wait to start mine this week.
Project Niles Skoolie
https://www.skoolie.net/forum/viewtopic.php?f=9&t=55161
FOLLOW US ON FACEBOOK TOO!!!
https://www.facebook.com/NilesSkoolie
NilesSkoolie is offline   Reply With Quote
Old 02-28-2013, 08:32 PM   #66
Re: Wild Blue
Great lookin' cabinet work! Love the moon phase lighting.
Old 02-28-2013, 09:59 PM   #67
LuckyChow's Avatar
Coachwork: Phantom
Chassis: Gillig
Engine: Series 50
Re: Wild Blue
Very nice work. I can appreciate the time that went into this. The details make good work look great. I usually spend 3 hours planning to every 1 hour working. I'm not even going to get into the "re-do's" that come along every so often. Thanks for sharing your work with us. Your bus has been an interesting work for me.
LuckyChow is offline   Reply With Quote
Old 03-01-2013, 05:05 AM   #68
Accordion's Avatar
Year: 1973
Re: Wild Blue
That is some beautiful craftsmanship. I love the curves.
Old 03-01-2013, 10:58 AM   #69
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Re: Wild Blue
I concur. Wondermus.
Linda Kay
trans·mog·ri·fy Verb: Transform, esp. in a surprising or magical manner.
Shadoll is offline   Reply With Quote
Old 03-01-2013, 11:45 AM   #70
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Wild Blue
What they said! Thanks for the inspiration
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 03-01-2013, 01:29 PM   #71
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Wild Blue
There seems to be some debate about the necessity of priming. I did not prime my bus, except for a repair spot here and there but I did sand it all at least to scuff it up. I have not had any problems with my paint except for right around some crevices on my front grill which I probably just didn't reach when sanding or cleaning. I painted my bus in October of 2010. I used a cheap air sprayer with Rustoleum gloss white oil-based enamel thinned with acetone. I did have a hell of a time dealing with the galvanized sheet metal I used to cover my windows though. I'll never used galvanized metal again if I plan to paint it. I'm no expert on auto body painting, but that is my experience with painting my bus.
Gallery:
Conversion Thread:
Old 03-01-2013, 02:16 PM   #72
MikeyBskunk's Avatar
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Re: Wild Blue
i also did not prime my bus i did this in these steps,
1. washed my bus compleatly
2. wiped the bus down compleatly with an acetone soaked rag (by hand) haha
3. painted without primer 2 coats roof, sides, and rims
i think it came out great, the acetone is like a liquid sanding it smoothes and cleans the metal perfectly you can really feel the dffrence
MikeyBskunk is offline   Reply With Quote
Old 03-01-2013, 11:55 PM   #73
Re: Wild Blue
Another good alternative is "Liquid Sandpaper" --- It is a de-glosser and cleaner you can wipe on with a rag. Works well to aid in bonding new paint over old.
Old 03-02-2013, 10:55 AM   #74
Shadoll's Avatar
Year: 1979
Engine: 8 cyl gas
Rated Cap: 60
Re: Wild Blue
At some point I will need to repaint my bus, which will take some doing as I believe they painted it with a latex of all things. Sprayed but every little bump peels some paint off. But that will be at a much later date. Good to know on the how too's though. I'll probably have to really strip it first.
I'm suprised you got away with leaving yours yellow so long. Here when I went to the DMV the woman's first comment was ... it can't be yellow. After I had just got done saying it was the big blue bus outside. Don't get me started on our small town employee base.
I like the look of the blue and different rub rail color in contrast to the solar panels. And noted the chains.
Linda Kay
Old 03-02-2013, 12:57 PM   #75
Re: Wild Blue
Hey Shadoll --- I'm in about the same boat. Nearly all of my bus appears to have had the original paint blasted off at some point and was repainted with #@!%&#! water-based latex house paint. Just maybe the worst thing you could possibly put onto metal. Especially bare metal. It falls off in chunks the size of your hand and is chalky & flaking everywhere.
In the process of sanding & welding things I have discovered that everything that was painted with the latex has a layer of surface rust under it while any of the metal that still had some factory paint (orange for skoolies back in'46) was bright, shiny metal. I will definitely be re-blasting with soda whatever is left before I begin any of my exterior paint work. Thank goodness they left the interior alone and it is in remarkable condition to be over 65 years old.
Surprisingly, the undercoating on areas like the wheel wells has also held up incredibly well. I stripped and treated them both expecting to find a lot of rust but there wasn't any...inside or out, where it had been undercoated with whatever asphalt like material they applied at the factory.
Old 03-02-2013, 03:09 PM   #76
lornaschinske's Avatar
Rated Cap: 89
Re: Wild Blue
We already had a coat of white paint (drips and all) on our bus. I wiped it down, a section at a time, with a sander/deglosser. And then rolled oil based exterior house paint on, a section at a time. I tried to sand the drips out. I can live with the old drips.
Fulltime since 2006
Old 03-02-2013, 06:41 PM   #77
roach711's Avatar
Rated Cap: 19
Re: Wild Blue
From what I've read:
Latex over latex or oil over oil is fine (but clean the old paint really well first).
Latex over oil is usually ok with good prep work, meaning the surface is clean, clean, clean and de-glossed so the new paint has something to bite into. TSP was the most common suggestion for cleaning the old paint.
Oil over latex seemed to be what caused the most grief. The oil paint film is harder than the latex paint film and many had problems with the oil paint film cracking.
Given the nastiness of removing an entire coat of paint I'll be going big on the preparation phase. That's one job I really really don't want to have to do over. Consensus was that latex paint was a bad idea on vehicles.
The Roach Motel
Old 03-03-2013, 09:39 AM   #78
Re: Wild Blue
As a side note --- Detroit and many makers went to water-based primers several years ago to cut costs (not to save the environment). Net result...new auto bodies are rusting much worse than before the switch. It's still as simple as water + metal = rust. Properly applied over another type of primer or paint you can get away with it but water based paints are still not "there" as far as durability on metal.
Old 03-04-2013, 08:56 AM   #79
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Wild Blue
Originally Posted by ramblin.ruby
... What grit should I aim for? I'm totally new to auto painting. Any suggestions are a great help...
The grit you use will be mainly related to how nice you want your finish to look, tempered by how much work you feel like doing.
Personally, 220 grit finish sanding was good enough for me. My paint job had a fair amount of orange peel, but that was due to my lack of experience using a paint sprayer rather than my sanding decisions. Some areas turned out smooth, and if my whole bus had turned out like that I would have been thrilled.
Gallery:
Conversion Thread:
Old 03-04-2013, 09:11 AM   #80
Re: Wild Blue
If you have a decent compressor...blasting is by far the easiest and fastest way to deal with irregular shapes. And these days you can pick up a little gravity feed gun for around 60-75 bucks. And if you use baking soda instead of sand, you don't even need to tape off any glass plus you avoid inhaling silica dust. Still want to use a mask & eye protection, but soda is a whole different animal than sand. Northern Tool even sells a little portable Klutch (house brand) soda blasting set up for just over a hundred bucks. Worth that much in time & blister savings!
the wild blue yonder atcc77 Skoolie Conversion Projects 161 08-09-2014 05:16 PM
How wild is your A/V setup? NewSkewlHauler Conversion General Discussions 16 07-06-2010 01:13 PM
Into The Wild (The Movie) josetann Everything Else | General Skoolie Discussions 6 08-08-2009 09:44 PM
Question for Wild Goose Davilance Conversion General Discussions 0 11-25-2006 08:39 PM
The Wild Goose ? soused moose Everything Else | General Skoolie Discussions 1 01-21-2004 08:37 AM
