06-03-2019, 08:13 PM
#61
Chassis: GA39530
Engine: DT466E 215hp 620tq
Rated Cap: 40
My radiator
My radiator and charge air cooler is mounted to a frame that is bolted to the frame/cross member on the bottom and held in place on the sides by some rods that are bolted to brackets on the frame. The whole mount comes out or you can take the radiator out of this frame as well. The fan shroud bolts to this frame frame the back side of course.
06-10-2019, 10:12 PM
#62
Chassis: GA39530
Rated Cap: 40
Update
WE installed the solar panels this weekend. I need to figure out how to secure them and still be able to tilt them when we are parked. But its a start.
I finished all of the plumbing and sewage installation.
Installed all of the propane tubing and flexable hoses to the furnace, stove and hot water heater.
We also painted the roof.
Next we install all of the wiring inside the bus.
Getting close to being usable finished, I will still have to do cabinet work and finishing details. But I should have her up and going by the end of August.
Feels good to see progress and my to do list shrinking.
09-09-2019, 06:46 PM
#63
Chassis: GA39530
Rated Cap: 40
Some Updates
Its been a very long time since I posted any kind of an update for those who are interested.
Ive done some lighting with the installation of the LED marker lights and tail lights.
I finished up the dinette/lounge
I laid down the vinyl flooring
I Installed the charging and control station under the couch
I installed some gauges to monitor the HPOP system
And the greatest success was I finally got the engine and the tranny to communicate and to start on their own.
Word to the wise, if you are going to arc or wire feed weld on your bus disconnect the engine and transmission computers and the shift panel/pad.
I blew up my shifter pad which then would not communicate to the TCM and not let the engine start. Then I found out I fragged the engine computer which corrupted the calibration and is not engaging the engine crank inhibit circuit.
Long story short I did it to my self but I learned alot about how my bus starts.
09-10-2019, 02:58 AM
#64
Your interior sure looks nice!
That was a hard lesson to learn. Thank you for sharing.
09-10-2019, 07:54 AM
#65
Well crap, I've been doing a lot of welding lately. How hard is it to disconnect the computers? I can't seem to find any info on doing this for my type of bus.
09-10-2019, 09:39 AM
#66
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
I was told to disconnect the batteries before welding, not sure about the computers. Better look into that.
09-10-2019, 11:47 AM
#67
Chassis: GA39530
Rated Cap: 40
No batteries
I had no batteries in my bus when I did the welding but all the computers (4) were connected. The TCM was fine, the shift pad died and the ECM has a software issue that cant be explained with just a setting issue. I figure it was just enough EMF to cause my issues.
To disconnect the TCM was simple, 3 connectors with simple tabs to press and pull the connectors off the TCM.
The shift pad was just a squeeze of the connector and separate.
The ECM requires a little ratchet and a small socket, cant remember the size, then you can disconnect the 379 plug, its the one with the power supply and the main connection to everything on the body.
Next time i have to do any welding, like my main door construction, Ill remove/disconnect all those.
09-10-2019, 12:15 PM
#68
Being serious what machines are you guys using that has that much of an arch start ?
Millermatic 250 and good clean ground I have no issues.
My miller aircrafter 300 didn’t even blow an eco or pcm.
Are you starting your weld on the chassis side or material side ?
That is a common mistake is to start on the chassis side while grounded to the material side.
09-10-2019, 12:19 PM
#69
Year: 98
the next best thing is disconnecting the batteries and connecting the positive to the negative so that emf voltages get shorted. The other being that you and connection should be as close to your weld as possible.
Later j
09-10-2019, 03:16 PM
#70
Yeah, I don't want to fry your bus. Or my own, for that matter. Good thing I'm done for awhile and my bus is still working.
My logic might be as faulty as my preparation here, but all of my welding has been on the back of the bus, both the ground clamp and the material, so I think current flow affecting the computers in the front would be unlikely. I will happily be corrected on that assumption.
09-10-2019, 03:19 PM
#71
I've been doing it both ways while grounded to the bus body (although mostly material-first since the bus floor is rust and pitted in places and hard to start a weld puddle on that side). I didn't realize you should do one or the other. I'm a total welding newbie and would be happy for any other advice you can offer.
09-10-2019, 07:15 PM
#72
How are you mounting your generator?
09-11-2019, 09:53 AM
#73
Chassis: GA39530
Rated Cap: 40
Onan 4KW Generator
I used the Onan mount system bolted to the cross members of the floor.
09-11-2019, 09:58 PM
#74
That is a nice fit!
09-11-2019, 11:22 PM
#75
Others trying to convince me to not close it in under the body, ridiculous noise level they say.They said look at RV generators on slides, couldn't find any.
09-12-2019, 07:27 AM
#76
im thuinking disconnecting the batteries can do more damage than good with welding.. as it lets transient voltages float around without the ballast of the batteries toi keep it down... eso if the negative side floats up..
Joe;'s idea is good.. connect both terminals to the frame.. so it all floats together..
ive been playung with vehicle computers so long its second nature for me to unoplug them if im doing anything wierd.. they are pretty hearty.. However they COUNT ON a solid ground... if the ground is left to float up they are very vulnerable..
09-12-2019, 07:34 AM
#77
Do you know of a good tutorial or video on this process of unplugging the computers (in a bus of my type)? I'm done welding for a bit but I think I should be doing this next time.
Like, where do I do the unplugging? Is this under the hood somewhere or do I have to get into my dashboard?
09-16-2019, 11:07 AM
#78
Chassis: GA39530
Rated Cap: 40
Ceiling and Kitchen progress
I started on the ceiling tongue and groove planks this weekend and mounted the LED ceiling lights.
I finished the cabinet, overhead storage racing for drawers and cabinet doors next.
I cleaned out the bus in preparation to drive it for the first time around the block since I got the bus and did the in frame but the brakes are rusted to the drums so I need to do some brake work to free them up, its been sitting for a year and a half so Im not surprised they are stuck.
10-29-2019, 12:57 PM
#79
Chassis: GA39530
Rated Cap: 40
We're Rolling
So it has been a long time since I posted an update.
I got the plates finally, not nearly as hard as I thought it would be, printed pictures of the finished product with the basic living requirements and that was it, even got a compliment from the nice DMV lady, she said it looked nice.
Although it is late fall we are going to a local camp ground with my 4 kids to try it out.
I have been using 3 8D core batteries from work that still have some life left in them to test the panels and the rest of the electrical system as I go about connecting stuff like lights and other utilities.
Ive been driving it every chance I get to break in the engine and check for leaks or other mechanical issues, so far its all working really well.
I was hesitant about the gearing, power, cruising speed and highway cruising. After driving it I came to the realization that it works great, plenty of power, cruises at 65mpg at 1700ish rpm and pulls hills wonderfully for such a heavy machine.
It cruises at 170 degrees and pulls hills at 195 and EGT of 1250 degrees. adding the larger radiator and intercooler as well as the trans cooler was a great idea, well worth all the effort.
I still think a 6th gear would be nice for flat plains trips where 70 to 75 would not be a problem, this would bring my current engine rpm from 2100 to 1700 or so.
The interior isnt perfect but to the point were its usable and I can continue with the finer details such as paint on the interior and exterior come spring.
And I got the door working they way I wanted it, a solid road worthy door with a certified road worthy door latch, I could never understand installing a residential door or door latch to something that is moving, wind pressure, possible crash, I wanted something solid but that still looked like a school bus door, now it just needs paint, come spring.
I set my tire pressures to 90 psi and checked date codes, 1502, so February of 2015 on the steers, and the rears are Michelin MRS recaps which I have a great respect for their recap process and trust the shop did them.
My solar array can charge 3 8d batteries to full in 3 hrs of direct sun to half my roof, havent got the tilting mechinism figured out yet, but Im comfortable I have plenty of power production, Im hoping the deep cycle 8d batteries have enough storage to make it all work properly.
We tried the fridge and microwave off the 3000 watt Renogy inverter and it worked great.
Here are some pictures.
10-30-2019, 01:19 AM
#80
I agree with the person at the DMV ... looks nice!
