Old 07-22-2014, 10:33 PM   #11
Drgnnite's Avatar
Coachwork: Metrotrans
Chassis: Ford E350 Cutaway
Engine: 7.3L Diesel
Rated Cap: 25
Re: Attachment problem
I received a the board has reached attachment quota message, what can I do? Thank you.
"You're only given a little spark of madness. You mustn't lose it."
-Robin Williams
Drgnnite is offline   Reply With Quote
Old 07-23-2014, 02:20 PM   #12
Sara's Avatar
The limit for attachments has been increased, so you should be able to post the pictures you need.
Another work-around for the imposed limit on attachments is to imbed photo links into your post from someplace like PhotoBucket. This way you can post as many photos as you want within your thread, without the fear of reaching the limit. If you need a little guidance on how to do this, let me know!
Sara is offline   Reply With Quote
Old 07-31-2014, 04:05 AM   #13
Drgnnite's Avatar
Engine: 7.3L Diesel
Rated Cap: 25
Sara,
Thank you!
-Robin Williams
Old 08-01-2014, 01:53 PM   #14
Sara's Avatar
Sure thing! I hope that helped! Let me know if you need anything else!
Electrical Problem kirkndopp Electrical, Charging and Solar 7 12-12-2009 09:10 AM
Problem of flow recycler Veggie Oil | WVO | Biodiesel | SVO 2 11-23-2009 10:10 PM
Bow / Frame Member Attachment oldog12 Conversion General Discussions 0 08-08-2008 01:27 AM
Air Brake Problem dlor1 Everything Else | General Skoolie Discussions 7 10-26-2007 07:07 PM
Wall and flooring attachment rlogan2000 Conversion General Discussions 2 07-08-2004 11:21 PM
