Old 02-01-2008, 10:18 PM   #1
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Search function broken?
Hi-
Just tried a search on the keywords "heater propane" (no quotes) and got the following msg:
The following words in your search query were ignored because they are too common words: heater propane.
Umm...not sure how I can make them less common...?
If it's user error, please let me know.
THX
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 02-02-2008, 11:50 AM   #2
Chassis: All American RE
Engine: Cummins 8.3
Re: Search function broken?
You can do those searches by using Google. If you add the string:
site:skoolie.net
to your search it will return hits only from this site. Like this:
http://www.google.com/search?hl=en&q...heater+propane
hth - Tony
dentarthurdent is offline   Reply With Quote
Old 02-02-2008, 01:24 PM   #3
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Thanks for the replies.
I've used the google search method on other sites, usually to get around the 4-character search minimum. But thanks for the reminder that I can use it here.
Sean
Old 02-03-2008, 09:42 PM   #4
Steve's Avatar
Fixed!
It wasn't supposed to be doing that and I had to switch to a different indexer, I will have to re-index the site so if the search doesn't work for you try later after it has finished.
Proper way to tow a broken bus jbus Conversion General Discussions 14 02-22-2018 10:35 AM
Kohler Generator Switch Function? Huskie1 Mechanical and Drivetrains 1 06-23-2014 08:58 AM
Full-Timer + Broken Bus? gbstewart Conversion General Discussions 4 02-24-2011 08:56 PM
BROKEN DOWN ON ROADSIDE... help? zim Cummins Drivetrain 5 07-06-2010 10:45 AM
Broken Window Latches Eric von Kleist Conversion General Discussions 6 10-21-2005 01:14 PM
