Old 11-29-2003, 07:16 AM   #11
Vern1's Avatar
Greetings,
Hey Les, glad to see ya over here!
How's the conversion coming?
I find this type of forum much more user friendly than the Yahoo groups and will come here more often as I don't have to put up with the adds and other junk.
First, when I said personal choice depending on cycle useage, I _MENT_ starting or storage, but didn't get the point across.
I provided a link to the Poop Sheets to clear up the confusion.
Thanks for taking the time to explain.
Happy bussin'
Cheers,
Vern1
1976 International Wayne - ON THE ROAD!!
http://www.pettypb.com/bus
Vern1 is offline   Reply With Quote
Old 11-30-2003, 07:10 PM   #12
lapeer20m's Avatar
starting batteries are meant to do just that.....start. They are not meant to have a load drawn from them for a long period of time, but are meant to give lots of amps for a short period of time. STARTING BATTERIES ARE THE WRONG TYPE OF BATTERIES TO RUN AN INVERTER.
Deep cycle batteries however ARE designed to have a load drawn for long periods. Most are rated for a certian number of amps over 8 hours. There is a limited number of times any battery can be cycled (discharged/recharged). Golf Cart batteries (or even better, Fork lift batteries) can be cycled many more times than a regualr starting battery and are some of the best batteries to use as "house" batteries to run the inverter or 12v loads in your rv or bus. golf cart batteries are far superior to most other deep cycle / rv batteries. Ideally for longevity you should never use more than half of the usefull energy stored in your batteries. Someoen listed earlier the "poop sheets by phred" that's an excellent source of information on this and many other RV topics.
Spend the money on new batteries. It would be most frustrating to have the nice shiney inverter that won't work because you wanted to save a few bucks and buy used batteries.
12V Deep Cycle Batteries Docsgsxr Electrical, Charging and Solar 5 03-05-2014 02:57 PM
REDSNECK DYNASTY Six Four Skoolie Conversion Projects 60 07-22-2013 09:56 PM
Bus Air Conditioning Refrigeration Cycle roach711 Short-Bus Conversion Projects 0 10-03-2012 09:23 AM
Using the alternator to charge deep cell battery bikeforthelight Electrical, Charging and Solar 4 10-14-2009 11:05 AM
Charging deep cycle batteries JonCBrand Conversion General Discussions 13 01-27-2007 01:21 PM
