Old 01-21-2014, 04:47 PM   #1
Chassis: bluebird
Rated Cap: 20
12V electrical to house and start batteries
Can someone explain to me in layman's terms how to wire a bus to run off batteries other than your starting batteries. I have the bus wired now to hook up to a land line from the house, generator or campground using a 30 amp hook up. It would be nice to run off a couple extra batteries that would charge while driving without discharging my starting batteries but would run everything on the bus mainly a tav and a few lights. I know I would need an inverter but how would I hook that up with my existing breaker panel to do this? I just hate having to run the generator all day at tailgates. Thanks
John Brothers is offline   Reply With Quote
Old 01-21-2014, 06:07 PM   #2
Re: Electrical
http://www.expeditionportal.com/foru...y-setup-for-50
Check out this thread first couple pages are good
Old 01-21-2014, 11:17 PM   #3
turf's Avatar
Re: Electrical
nice diagram bansil.
you need to design your electrical system by figuring how much you are gonna use while tailgating.....then times it by a bunch.
list out your appliances and the hours you want to run them....
then build a battery bank big enough
120v appliances will need an inverter and gets fancy... but anything is doable
this calculator helped me a lot.
http://www.altestore.com/store/calcu...ad_calculator/
there are a ton of good threads on electrical.
like this:
http://jackdanmayer.com/rv_electrical_and_solar.htm
Turfmobile Build Thread
Old 01-22-2014, 04:02 PM   #4
Chassis: bluebird
Rated Cap: 20
Re: Electrical
Thanks for the help
Old 01-22-2014, 04:14 PM   #5
Re: Electrical
can you edit title of your post?
Maybe something like:
"12V electrical to house and start batteries"
it might make searching in the future easier
Old 01-24-2014, 11:20 PM   #6
Engine: 190hp 5.9 Cummins
Re: Electrical
Good Ida bansil. That way others can use this info in the future.
Old 02-07-2014, 11:54 AM   #7
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Re: Electrical
If you're considering solar panels, read this:
http://handybobsolar.wordpress.com/the- ... -puzzle-2/
Actually, even if you're not considering solar panels.
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: https://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 02-09-2014, 12:46 AM   #8
Year: 1974
Engine: Detroit Diesel 6-71
Re: Electrical
YES.
And thanks from here as well for the link Bansil
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
Old 02-27-2014, 12:56 AM   #9
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Re: 12V electrical to house and start batteries
I found this on Amazon. It is a really informative and easy to follow book.
Managing 12 Volts: How to Upgrade, Operate, and Troubleshoot 12 Volt Electrical Systems
http://www.amazon.com/gp/product/096473 ... UTF8&psc=1
-Doc
House batteries placed inside? jkronmiller Conversion General Discussions 3 12-25-2012 10:18 PM
House Batteries Stuff Electrical, Charging and Solar 12 06-06-2012 08:52 AM
Electrical Problem - Can't start CyberHippie Everything Else | General Skoolie Discussions 11 12-07-2008 12:02 PM
Where to get house batteries cheap?? JonCBrand Conversion General Discussions 12 01-06-2005 10:44 AM
House batteries JonCBrand Conversion General Discussions 2 11-30-2004 09:30 PM
