Re: 1994 bluebird turn signals not working
My first guess would be a dead flasher. Check the chassis fuse panel, I believe on those it's a panel on the flat part of the dash (I could be wrong, it's been a while since I was in a TC). If not there, try the electrical panel under the driver's window (should be a lever near the floor under/behind the switch panel to unlatch it). The flasher would be a small square or round plug-in type, and can be replaced with one from any Napa or Wal-Mart type store. It's a cheap enough part, but a quick way to test is to remove the flasher and jump the terminals it plugs into, and see if the turn signals then come on steady without flashing. If they do, you've got a bad flasher, if not, you have a wiring issue somewhere else.
