03-21-2013, 09:22 AM
Chassis: IH
Engine: 444E
1998 D444E not turning over
Hoping someone can give me an idea on what the problem can be. I purchased a 98 Thomas on a IH chassis in September 2012. I started it weekly until the temps got into the 30's and the batteries could not hold a charge. Some unexpected surgeries caused the bus to sit a couple months. Just put two new batteries in that I purchased from a IH dealer and when I try to start it all I get is the clunk of the relay to my left and the motor sits motionless. The rpm and spedo start their pre-run diagnosis but only sweep once then on the return to ''''0" and then the rpm needle quickly drops to pointing straight down for a sec before returning to 0. Lights and other electrical seems to work fine. Any help?
03-21-2013, 09:41 AM
Re: 1998 D444E not turning over
if batteries are connected correctly,sounds like they need to be charged, just cause they are "new" doesn't mean they are charged
You said lights work, does this include headlights? how about the horn?
03-21-2013, 07:25 PM
Rated Cap: 19
If your headlights come on bright the batteries are likely fine.
If you have a volt meter, check voltage at the batteries. You should be seeing 12.7 or so from a fully charged battery, 12.1 from a half discharged batt. and 10.5 from a dead battery. They should hold a charge even with low outside temps. My two starting batteries will easily go three months between charges. When yo do your periodical startups let the beastie run for a while to top them off again. Diesel glow plugs suck a lot of juice out of starting batteries and you don't want to be drawing them down further and further with each start.
An easy way to check battery voltage is to test it at the cigarette lighter socket. That will test voltage up to the dash area.
I've heard that most school buses have a rear door interlock that kills power so make sure your door is closed.
03-21-2013, 11:12 PM
Engine: 3208 na boat anchor
.... and for sh*ts and giggles you could bar the engine over, and see if it turns.
03-22-2013, 09:17 AM
Chassis: IH
Engine: 444E
I will try to bar the starter and see if it turns over. We have about 6 or 7 inches of snow on the ground with another 5 expected today so it may be a day or two. I had pulled the new batteries into the house when it didn't turn over so I checked the voltage and both show 12.68 volts - so the power is there, just nothing doing anything with it.
03-24-2013, 05:24 AM
check the connection to the starter. the quick way is to click the key quickly a few (dozen) times. The right way is to look at it to see if it had corrosion or rust on it.
03-24-2013, 08:07 PM
Moderator
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Originally Posted by Part-time
Sounds like your solenoid might not be making contact. It happens when they have been sitting for a while.
The clunk you get to your left is most likely the solenoid that turns the power on to the heaters, dome lamps, wipers and whatever else goes off when you turn the key off.
That solenoid screwed up on mine yesterday so all the stuff I noted above would not come on even after the bus was running.
A little "tap" with a screwdriver and everything was back to normal.
If you trace the wires the big cables from the batteries to the starter there will be a solenoid somewhere along the way, or at the starter (I don't remember off hand where they are).
Get someone to turn the key to the on position and see if there is power on the starter side of the solenoid. If there's nothing there just try giving the solenoid a tap and see if it makes contact.
Another way is to conect the two large poles of the solenoid together with a screwdriver and that will make the motor turn over even if the key is off (it will make sparks when you touch both poles, that's normal ).
The solenoid was the problem with my diesel Excursion. You can try jumping the solenoid to see if the engine turns over before you buy a new one. Did anyone mention whacking the starter with a hammer?
03-25-2013, 01:07 AM
And some people say that you can't fix an electrical problem with a hammer...
You can, but you need to have the perfect size hammer! :lol
03-25-2013, 02:03 AM
Moderator
Go ahead and laugh. You'll be buying me a couple of beers if whacking the starter starts your bus.
03-25-2013, 11:29 PM
True story! Just as the contacts in a solenoid corrode when they sit unused, so goes the contacts in a starter. I have a shitrod of a truck that I got for free. It had sat for about 3 years when I got it, in need of an oil pan (and some other piddly stuff). After I got the oil pan and other piddly stuff in it, it would start maybe 1 time out of 10 just because of corrosion. Fast forward 6 months and I've been driving it a couple times a week and it starts each time. The problem was corrosion in the movable pole shoe starter. Sure, I could have returned the lifetime warranty starter to NAPA, but that would have required me getting under the truck and changing the thing out.
Here's my recommendation. "Bar" the engine over to make sure that a leaky injector or head gasket has not filled a chamber with incompressible liquid. Once you've assured that, beat the hell out of the starter while someone turns the key (assuming fully charged batteries). What do you have to lose?
03-26-2013, 10:52 AM
Chassis: All-American R/E
Sounds more like a bad ground to me.
03-28-2013, 09:49 PM
Starters are grounded through the block and the current only flows one way through them. You would never see a difference in behavior from an open/compromised ground versus an open/compromised power side. This is different from other things like power windows which reverse current through the switches or computers which, lacking a proper ground, can overlay voltages on network wires to other modules on the vehicle.
A loaded voltage drop test will quickly diagnose a bad ground or power. With someone turning the key to the "start" position (VERY important...current must be flowing for this test), put the red meter lead on the battery positive post and the negative meter lead on the huge battery cable on the starter. You have created a parallel path so you should see no voltage. Any voltage that is present is voltage taking a path of lower resistance. I wouldn't be surprised if you saw .5 volts on the power side but if your meter is indicating more you have excessive resistance on the hot side. If it reads battery voltage your solenoid is not working, be it because of a lack of signal from the key or a faulty solenoid itself.
If the power side passes, perform the same test on the ground side by putting the red meter lead on the body of the starter (get a clean spot) and the black lead on the negative post of the battery. Again, .5 volts or so is normal.
03-30-2013, 03:27 PM
Chassis: IH
Engine: 444E
OK, the weather finally has given me a break. So reinstalled the batteries and every light, horn and accessory worked but still would not even try to turn over. Shorted the starter, and other than it throwing some major sparks nothing. Applied my trusty hammer and still nothing. Did a little thinking for a change and though what if it was just a car and it did this. Long story shot the gear selector said it was in neutral but when I tried to move it - it was frozen. Went down to the tranny shifter lever and move it a bit and it fired right up. Apparently it was not making contact with a safety switch. Live and learn. Now to find a replacement cable! Thanks everyone for the help!
04-01-2013, 09:31 AM
Rated Cap: 19
Every problem is a potential learning experience.
04-23-2013, 04:00 AM
Moderator
So what you're saying is you used a hammer on your neutral safety switch. I win. When can I expect the beer?
