Old 03-13-2013, 08:30 PM   #1
roach711's Avatar
Rated Cap: 19
20 year old Coleman stoves
I know this is way off topic but this evening I dug out my two Coleman stoves out of the garage attic, one is a backpacker stove and the other is a standard two-burner camp stove. They'd both been stored up there for 20 years, both were stored away full of fuel, and both fired up fist try without a hiccup. I'm impressed!
The Roach Motel
Old 03-14-2013, 09:52 AM   #2
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Re: 20 year old Coleman stoves
they are working cause they are 20 years old. New stuff probably wont last that long
Old 03-14-2013, 12:35 PM   #3
roach711's Avatar
Rated Cap: 19
What surprised me was that the FUEL was still good. If I had left my lawnmower stored full of gas that long the carb would have been full of brown goo.
The Roach Motel
Old 03-14-2013, 05:18 PM   #4
bapos's Avatar
ethonol is the devil in gas. glad it lit up and is useful
Old 03-19-2013, 01:49 PM   #5
I have a three burner Coleman stove that's over 36 years old and it lights right up. I just recently used it a little over a week ago. It only gets used once every other year and I store it full of fuel. One bad part of regular fuel are the additives (including ethanol) and dye that turn old fuel into a varnish like substance that plugs small orifices. Coleman fuel is pretty pure, for the most part, so it doesn't suffer quite as bad, however, it must be kept where it can't absorb moisture.
I have used five year Coleman fuel without any ill affects. I can't say the same thing about automotive gasoline, where I have seen it gel in just months, especially if it can attract moisture. That's why I ALWAYS use a fuel stabilizer, like Staybil, in all my fuel containers as soon as I fill them. Fuel left in my commercial mower, lawn tractor, generator, and other small engines (chain saws, string trimmers, blowers, etc) all have fuel stabilizer added.
Steve
scooter56 is offline   Reply With Quote
Old 03-19-2013, 03:37 PM   #6
lornaschinske's Avatar
Rated Cap: 89
We used to have a Coleman White gas catalytic heater (bought in 1979) that we used when tent camping and then in the pop-up. We kept a sealed/never opened 1 gallon can of Coleman fuel stored for several years as a back up. The fuel can was getting rusty so we decided we needed to use it. That was a really good space heater. What we did not like about it was we had to light it outside. They don't make this great heater any more.
Fulltime since 2006
Old 03-20-2013, 07:22 PM   #7
Yeah, I have one of those too and it has kept me from freezing before while tent camping in temps below 20 degf (very cold for a Texas boy). You are right about lighting it outdoors. Not only that, but it shouldn't be close to anything that could catch fire while it was lighting. Yes, it kept me warm, but what I didn't care for was the hydrocarbon odor it put out. Not enough to keep me from using it when it was really cold, though. I like the propane ones better, but I worry about the ones I have tipping over.
Steve
Old 03-21-2018, 02:15 PM   #8
I had to replace the packing in the generator shaft (where the fuel adjustments are made) on my now 14 year old Coleman dual fuel stove, other than that, and a good clean up / repainting, it works perfectly.
I have 2 same vintage dual fuel lanterns. No issues at all.
And 2 1969 vintage white gas heaters. No problems at all...
The fuel I have in them all is from 2005
dbhost is offline   Reply With Quote
Info about Coleman Polar Cub 9200btu A/C? sdsknifeworks Heating, Cooling and Appliances 26 05-22-2014 10:14 PM
Wood Stoves? chev49 Everything Else | General Skoolie Discussions 1 06-04-2012 11:11 AM
FS: 2 coleman mach 3 13,500 BTU rooftop A/C units baadpuppy Classifieds | Buy, Sell, Swap 7 07-28-2009 02:56 PM
Coleman Powermate Pulse 1850 Generator phillbus914 Electrical, Charging and Solar 5 12-10-2008 06:26 AM
Coleman LP Furnace manual lornaschinske Heating, Cooling and Appliances 1 06-23-2004 08:12 AM
