Old 08-07-2012, 06:34 PM   #11
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: 5.9 Cummins governed out @65?
u know i was worry the hole trip,but ran flaw less, 10 mpg ,in the mtns and 13 mpg on the flat, ,, i toke the muffer off and ran a stright pipe.. next we going to put a cold air box , and a jake break...
keith is offline   Reply With Quote
Old 08-10-2012, 09:33 AM   #12
Year: 99
Chassis: TC1000 cab over 9 window
Rated Cap: 24
Thanks for all the replies guys, ive been busy workin on it alot since i got it out here to ohio. I was pretty nervous about the ride out to oh from pa cause it was one of the hottest days of the year but the 99 tc1000 did great rt 80 where i was driving has lots of long uphill grades and i worried about bogging down to 35mph and over heating but no such trouble! i was passing big rigs chugging about 60 goin up those mile long grades ME HAPPY. im not concerned about gettin more speed out of her any more, it actually governs out at like 67, will hit 72 goin down hill. no need to worry about a speeding ticket.
pictures to come soon!!
Circle the wagons!!!
BuffaloStampede81 is offline   Reply With Quote
Old 08-10-2012, 09:40 AM   #13
crazycal's Avatar
What does it sound like with the straight pipe? Can you put a video up? I was thinking about doing that also if it wasn't too loud.
I'm hungry!
You Gotta Let Me Fly
Old 08-10-2012, 10:11 PM   #14
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
sound like a big rig with a425 cat.no loud at all nice melow sound,,,,take it off at the muffer an run the pip back to in fornt of the rear wheel and face it out,
Old 08-11-2012, 08:31 PM   #15
Year: 99
Rated Cap: 24
i was thinking about straight piping my exhaust, what are the advantages? i too was afraid it would be louder? mine would be easy to cut off b4 the muffler and pipe out the side...
Old 08-11-2012, 09:10 PM   #16
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
more hp and u need to run it out in fornt of the rear tire,elbowing it down to face the ground..
Old 08-12-2012, 03:04 AM   #17
crazycal's Avatar
What happens if it is run all the way back?
I'm hungry!
Old 08-12-2012, 08:22 AM   #18
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
that will be ok too, i did mine like that because i wanted to use the space where the tail pipe ran,,,,
Old 08-13-2012, 10:17 AM   #19
Diesels breath better without the muffler or cat converter
i need to punch our or remove the muffler on my cat engine.
Have already removed the cat converter on my diesel pickup... muffler will be next.
Tuning up the diesel engines for higher hp and removing restrictions in the exhaust is good for the engines and gets you better fuel mileage if you drive sensibly...
Just what i have learned over the years.
However, not much i have ever done on a 8v71 or 8v92 has ever helped much with my 2 coach busses... (6-8mpg)
Old 08-19-2012, 09:32 AM   #20
Coachwork: Ward Genesis
Engine: DT466/MT643
Originally Posted by BuffaloStampede81
i got to drive my bus this weekend cause we finally got plates for it. 2 questions for any who dare answer:
1. i got the bus (it has yet to be named) cruising down a hill and after chugging up the other side of the hill @ 35 i wanted to get some momentum to get up the next one. when i hit 65 going down hill it seemed to govern out. the RPM's just went to idle with the accelerator pedal pushed down. what gives? can i adjust this to say 80mph? i assume its because its a school bus... its not like i was red lining it...maybe 2600RPM's?
2600 for a 5.9 ISB in a Bird is about right, actually. Assuming you have 265/70R19.5 tires, I'm guessing you have 3.54 gears. If so, that is as tall as they get. My friend has a 1998.5 TC1000, he has the same setup...it will run 65MPH (~2300RPM, IIRC) all day.
Jarlaxle
SKOOLIE - Governed or Geared? heathnlaura Conversion General Discussions 30 06-26-2013 08:04 AM
WVO in Cummins ISB-07?? greyguzziart Veggie Oil | WVO | Biodiesel | SVO 0 07-19-2009 11:29 AM
anything have a Cummins 4BT? nearhomeless Short-Bus Conversion Projects 8 07-14-2009 08:56 PM
8.3 Cummins reprobate Conversion General Discussions 7 05-07-2009 07:51 PM
8.3 cummins dlor1 Everything Else | General Skoolie Discussions 6 01-13-2008 02:27 AM
