Old 06-21-2011, 11:17 AM   #1
Year: 1983
Chassis: Carpenter
Engine: 8.3
55 gal drum heater question
Has anyone considered this for a way to heat water when hooked into shore power? Looks like an easy solution to me...
http://www.hotwatt.com/drum.htm
seth
"grease buddy" and all around nice guy
madpsalmer is offline   Reply With Quote
Old 06-21-2011, 11:34 AM   #2
GreyEagle's Avatar
Re: 55 gal drum heater question
I did not see a price, but sure seems like overkill for camping, most RV water heaters are 6 gallon Great idea, but I think about 10 gallon would be more than the average camper uses at any given time, ie wash dishes, shower etc....
just my thoughts.....
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 06-21-2011, 02:37 PM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
I use one of those to heat up WVO before filtering; it raises the temperature of 55 gal of veggie oil by about 10-15 degrees per hour of heating time. Of course my barrel is in an insulated box (R13).
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-22-2011, 06:53 PM   #4
lornaschinske's Avatar
Rated Cap: 89
In the RV, we have an AC/LP water heater. We usually have electric included in our site rental.
Divide cost of Propane per gallon by 22 to get equivalent cost of electric. If propane is cheaper, then use propane. If electric is cheaper, then use electric.
Our old water heater (which sprung a tank leak so we had to replace it) was an AC/LP unit also. If you have a LP heater, then you can add either a Hott Rod or a Lightening Rod. These electrical units thread into the anode rod hole in the LP water heaters.
http://www.hottrod.net/
https://www.makariosrv.com/products/...ment-Only.html
Lightening Rod is generally cheaper but Hott Rod is easier to find. I have seen the Lightening Rod at the local ACE Hardware.
Fulltime since 2006
b600 1983 ford drum brakes and overheating issue autoqual Conversion Tutorials and How-to's 0 08-17-2014 10:41 PM
plastic drum threaded bung fitting help needed bansil Plumbing, Water and Waste 10 03-12-2014 04:01 AM
Split rims drum removal Soundman1 Mechanical and Drivetrains 8 08-18-2013 08:21 PM
55 gallon steel/poly drum for fuel tank? kc_4_jc Conversion General Discussions 3 06-23-2013 12:54 PM
Hurri-Hot heater question scooter Short-Bus Conversion Projects 7 06-29-2010 11:22 AM
