Old 12-10-2017, 12:25 PM   #21
Robin97396's Avatar
I do have enough explosive gas for that.
Robin
Nobody's Business
Old 01-18-2018, 02:10 AM   #22
yello's Avatar
Coachwork: Crown Supercoach Series II
Engine: Detroit 6V92TAC
Originally Posted by Iceni John View Post
The second photo is the four air tanks' drain valves, but what is the fifth valve on the right for? It looks like it's connected to something - what? Those are not the original valves: Crown used Bendix truck valves, and yours look like gas valves. I used my unused fifth position for a new bulkhead fitting and valve to connect my on-board electric air compressor to the Accessories tank and to three air outlets around the bus, and I now can also connect my Accessories system directly back into the wet tank, useful if I need to fully air up the whole bus from external air.
Bringing this up because I haven't looked at some threads that I started. I think that last or 5th valve was just like an auxiliary. Maybe I can put that to use cleaning up dust. I have a 150 psi tank discharged laying on it's back in basement storage but I wouldn't mind unloading it to a garage when i have a permanent parking spot.
yello is offline   Reply With Quote
Old 01-18-2018, 05:29 AM   #23
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Those should be replaced with proper DOT valves. They look like Home Depot water heater valve.
Old 01-18-2018, 11:34 PM   #24
Jdawgsfanasty's Avatar
Originally Posted by Robin97396 View Post
We'd have to assemble multiple buses into a megabot to defeat the decepticon. With my luck my bus will be the butt.
You get to make all the noise...
Jdawgsfanasty is offline   Reply With Quote
