Old 06-01-2017, 11:02 PM   #1
7.3 powerstroke fuel filter location
I can't seem to find it, someone told me it was under the hood of my airporter style shuttle bus, but is obviously not there. I think it is under some kind of cover, but if I have to take the dog house off, what area to look? Thanks
Bluespoet is offline   Reply With Quote
Old 06-02-2017, 01:26 AM   #2
Robin97396's Avatar
I'm unfamiliar with your specific bus, but if you follow the fuel line from the tank you're bound to find your filter.
Robin
Nobody's Business
Old 06-02-2017, 06:03 AM   #3
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Right in the middle of the engine-where you would expect a carburator would be. Its not a screw on style-there is a plastic cover usually with a 1/2" sq in it to stick a 1/2" rachet in.
There may also be one along the frame rail.
Old 06-02-2017, 06:22 AM   #4
yes thats the fuel filter in the picture.. that cap unscrews.. on my 444E I think it was a 3/8 ratchet.. mine was stuck on pretty good so I helped it along by also using vice grips on one of the "ribs".. and it came loose.
be careful of the O-ring, your new filter element should come with a new one.. but if it doesnt, be careful it does rip easy.
